Question about NexxTech 4-Port Ethernet Broadband Router (N4PROUTER)
Hi! I've got the Nexxtech 5port 10/100Mbps Ethernet Switch Model N5PSWITCH and it got separated from the power supply. There's nothing on the switch that says what DC power to run it at- just "DC IN". Can you tell me the voltage and power requirements? Thanks! TresGeek
7.5v 1A- selling one on ebay with switch
Posted on Dec 17, 2010
I have Sony Bravia KDL-46HX800 3D TV. My Ethernet connection stopped working. I can't get IP, my Sony blueray player doesn't have such problem (it is connected to the same net. switch). TV say
use a straight thru to connect directly to the router. Cross overs are typically used when connecting PC's directly together or daisy chaning routers or switches. Try a different port on the switch? Also from a pc, go to the DOS prompt and try and ping your TV. If your TV IP settings are all correct, and your network equipment is working, your should get a response from pinging your TV. If you don't, I would suspect a problem with your TV Enet port.
Jan 05, 2013 | Sony BRAVIA KDL46HX800 46 1080p LED 3D TV...
GS605 v4 netgear
Move your primary Internet connection to port number 5. Although it is not mentioned in any of the documentation, Port 5 is the uplink port.
Feb 25, 2012 | NetGear GS605 5Port Gigabit Ethernet...
Sd205 reset
Find the "RESET" button on the back, and press and hold it down while the device is powered-up for 15 seconds.
Feb 16, 2012 | Cisco SD205 5Port Ethernet Switch...
How do i install?
This device is a plug and play device and doesnt need any configuration before installation.
You need CAT6 ethernet ( copper LAN cables) to connect the switch to the other device from where you want to extend/expand your ethernet.
Best Regards
Dec 31, 2010 | Dynex DXESW5 5Port Ethernet Switch
How to set up a Nexxtech wired router?
Hi, manny_khera This could be a bit complicated...or not? First we'd need to know the make and model of your comcast modem as it may be a "modem/router" if so, it will need to be set to bride mode before your new router can work properly - to avoid "double natting" (both devices attemting to preform the same fucntion - network address translation.)
Jun 06, 2009 | NexxTech 4-Port Ethernet Broadband Router...
Power supply , small plug hook up?
That plug is for the fan RPM monitor, it is not needed for normal operation.
Mar 06, 2009 | Enermax (by Coolergiant) EG495P-VE SFMA...
Nexxtech DVD Slimline model DP3222
Could be an open internal fuse or power supply failure
Jun 04, 2017 | NexxTech DP3222 DVD Player
NexxTech 4-Port Ethernet Broadband Router (N4PROUTER) Logo
141 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Prashant M
Prashant M
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
