Question about GE Refrigerators
I have model PFS22SIDSS, serial no. TMO3470. I cannot get the icemaker to work; the green light is on, the power is turned to the I position, and the water dispenser is working. Please help.
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
SOURCE: water dispenser in fridge door
I have same problem with GE monogram 42. ice maker works, water dispenser not. It does click but no water. Help.
Posted on Feb 23, 2008
aborcass
  • 2651 Answers
SOURCE: ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Posted on Mar 25, 2008
tech master
  • 120 Answers
SOURCE: Water dispenser not working
2 things i want you to try before you call a tech out first under frezer door there is a connector where the 2 lines connect disconect both off now actuate the water at door if you get water out the line that means your line inside door is frozen 2 if you don't get water that means your water reservour is frozen so to solve problem cheapest way is to derost it by unpluging it for maybe 2 days and if it was frozen it should go back to normal and this time keep your temps in right settings refrigerator section at 37% and freezer from 0 to 4 % at all times that will keep lines from freezing
Posted on Oct 12, 2008
  • 151 Answers
SOURCE: Ice Maker just stop making Ice. The water still
Check the bar that's used to sense when the tray is full, is in down position.
Posted on May 14, 2009
Ice maker not working on a whirlpool french door fridge
Is the cold water dispenser working? If not, does the filter need to be changed? Do you actually have water supply to the fridge?
Is the Ice bin empty? Is this your fridge, or are you renting and this was in place? If yours, do you have an Owner's manual with the troubleshooting tips? No manual, try manualslib.com Make model possibly year and serial number. If not yours, there should be a switch that turns the Icemaker on or off. A green light on the front of the drive mechanism near this switch should mean it does have power. No light, no power. There should be a mechanical switch that stops the Ice maker. If the bin is empty, the ice detection arm should be down If it is not down, It is stuck in the "bin is full" position. If these are not the problem, It may be the electrical valve for the Icemaker water supply is not operating, or has been disconnected, or is bad. I have found that one of the online "appliance parts store or sites" have been quite helpful in diagnosing problems and recommending parts and how to fix.
Apr 01, 2015 | Whirlpool Whirpool 26 cu. ft. French Door...
Canon IP2600 Ink absorber replaced and i am still get the error message. I have been told that the count needs to be reset. this is done with a button sequence on the printer. Does anyone have this...
Try these:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time
the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
Function Procedures Remarks
Service test print
- Model name
- ROM version
- USB serial number
- Waste ink amount
- CD-R sensor correction
See "Service mode operation procedures" below. Set a sheet of A4- , letter-, or larger-sized paper.
For print sample, see 3-4. Verification Items, (1) Service
test print, <Service test print sample>.
EEPROM initialization See "Service mode operation procedures" below. The following items are NOT initialized:
- USB serial number
- Destination settings
- Waste ink counter
- CD-R correction value
Waste ink counter reset See "Service mode operation procedures" below. If the waste ink amount is 7% or more, replace the bottom
case unit, or the ink absorbers.
Destination settings See "Service mode operation procedures" below. Other than Japan: iP4000
Japan: iP4100
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage returns and locks
in the home position.
1 time Orange Service test print See 3-4. Verification Items, (1) Service test print.
2 times Green EEPROM information print See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting
5 times Orange Destination settings Proceed to the step 5), and follow the Destination settings
procedures.
6 times Green Print head deep cleaning
7 times Green CD-R test print Not used in servicing.
8 times Orange CD-R print position correction
(horizontal) Not used in servicing.
9 times Green CD-R print position correction
(vertical) Not used in servicing.
Hope that helps!
Jan 10, 2011 | Canon Pixma iP2600 Photo InkJet Printer
No water in ice maker
Hi Binh. Welcome to FixYa. I am Kelly
First I want you to look at the 2nd link below and check item 22 for ICE buildup. (Use your finger) If there is ice buildup in that area use a hair dryer and melt the ice there until it is completely gone.
A quick way to find out if the icemaker is in an ice harvest cycle is to touch the bottom of the icemaker. It it is warm or hot to the touch then it is in the harvest mode probably due to ice build up.
Here is a link to test your icemaker and water valve assy.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The link is step by step
"How to" information. When it has you jumpering the terminals to start the troubleshooting process it may take longer than the 2 - 3 seconds it states in the procedures.
Parts for you icemaker can be found here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150689&diagram_id=930039#d930039
If you need further assistance then just respond here and we can go on from there.
Thanks for using FixYa.
Kelly
Apr 19, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Freezer making grinding noise ice maker not working
Sounds like the icemaker may need to be replaced. When you open the freezer drawer it cuts power to the icemaker.
Jun 18, 2009 | Maytag MBL2256KES Stainless Steel Bottom...
Icemaker will not turn on
The very best place to start is with mini manual located inside the kick plate pull it off its the brown/yellow one
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Amana side-by-side icemaker buttons on door not working properly
I have an idea whats wrong but it amy be kinda hard to explain to you but here goes.
looking at the selector buttons does it look like the plastic overlay is cracked or worn from where you have made selections over time? what happens is when these selectors crack it causes teh switch to hange in one position. in your case it would most likely be the water button that is the worst culprit. the repair is very simple. you need to replace the overlay which is the sticker that labels the crushed/cubed ice and water. you can order this part through amana using your model and serial number, or post a good model and serial number here and I'll look up the part for you. thx peyton
Jan 28, 2009 | Amana ARS2464B Side by Side Refrigerator
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
Click in circuit board Light in Icemaker dim bright Warm both sides
I didnt understand what you meant by refer(refrigirator???) and IM..??
Jun 26, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Noisy refrigeration without a icemaker.
Lift the arm up on the icemaker to shut it off some models have a switch on the side of the ice maker you can turn off as well a green indcator light
May 10, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
