Question about Acer Computers & Internet
My power suply have been pushed away from the right position and I want to open the computer to put the suply back to the right position. but how can I that. I can't find a special manuel for opening the cabinet. thank you for taking the time to help. Christoffer Jakobsen
  • 183 Answers
Dear ,
you can find nuts at side edge of back plane you have to unlock that first then do push side panels towards back side if your cabinet cd drive panel is front of you.
you will with care.
Posted on May 15, 2008
No power suply
Do you mean what power supply to install inside of the computer? There is no power supply that plugs into the back of a desktop computer. If you are talking about what power plug goes into the back, Then any pc 3 slot female plug should work. The link below should give you an idea. If the link doesn't show, Then search for "computer power cords"
Nov 24, 2013 | Computers & Internet
Computer won't power on right away
Wll it could be your pci controller is damaged.. (In thic case the only solution is to buy a new board)
Or you bios might need flashing..
Unplug your system
Open up the system,
put back in your network card
remove the battery on the main board
hit the power button 7 times
replace the battery
plug it back in and try to boot now
When it boots, you need to enter the setup and load your default settings then save and exit..
Jan 24, 2008 | Intel D915PCY Motherboard
My akai lcd 32.5" tv will not stay on and all it does is flash the blue screen with akai then turns right back off and i was thinking power suply might be bad. what could it be?
You could be right it sound like the power suply, has it got a AC adaptor power suply,bit like a laptop charger? goes from mains to a black box then from box to the TV?
does it stay on at all?
Oct 01, 2010 | Akai LCT3285TA 32 in. LCD Television
Amilo A7600 - where do I install two upgraded RAM
Turn off your computer.
Disconnect the AC power.
Remove the battery.
Take a small screwdriver.
Open the access-door on the bottom of the computer.
You'll find the existing RAM chip.
It's held in place by two "fingers" -- one at each end.
Push the two fingers "away" from each other, and the RAM chip will partially lift away from its slot.
Remove the chip.
Look for two "slots" for RAM.
Put the two "new" sticks into the two slots.
Push down on the RAM until those "fingers" click, and hold the RAM in the correct position.
Feb 03, 2010 | Computers & Internet
When i power on a led is blinking next to the mb power suply and apears two errors 82 and 98 i have tried diferrent power suply, ram, vga card
remove the bios battery for 20- 25 mins.small flat round battery on the motherboard then put it back in. start up computer
Aug 05, 2009 | Abit AB9 Pro Motherboard
I have an HP Pavilion a384x. It will not turn on
First with the computer turned off make sure the switch on the power supply is set to 115v.
If you turn the computer back on and you still get a flashing green light on the back of the power supply and a constant light on the front of the computer with no video, then try replacing the power supply with either a new one or a known working good one.
If that doesn't do it then it has to be the motherboard at that point.
Keep in mind normally on those power supplies, the green light should be constant. So it has to be either the power supply is bad or the moterboard is bad and you'll know when you put a new or known good working power supply in the computer.
Aug 03, 2009 | HP Computers & Internet
Cd tray is stuck in open position on my HP computer
In Some Cases The Button May Be Stuck In Causeing It To Keep Pushing It Open In Other Cases The Arm May Just Be Stuck To Extending The Tray Out. I Recommend Seeking A Computer Technician If You Do Not Know Anything About Computer Componants
May 12, 2009 | HP Computers & Internet
Yesterday, I left my computer to talk with a
I would need some more information to completely help you. When you say you walk away and the pc shuts down and starts back up, does it close down (reboot) or does it go into screen saver / sleep mode? What button did you push for the power button light to blink? Have you put the PC into sleep / hibernation mode by pressing the power button once.
Apr 07, 2009 | Gateway MX3225 Notebook
It wont start up or turn on
This would be your power supply causing this - It's not putting enough power to the motherboard. Change out the power supply, and your problem will go away.
Mar 12, 2009 | Compaq Presario SR1000T (568657) PC...
About 2 weeks ago my sister's computer(emachines t3589) shut down I first thought that was the power supply,so I replaced it ,but the problem didn't go away,then I put the old power suply back on the...
The CPU fan is working?
The power button is working?
Did you connect the cables right?
If none of above fix your problem, seem to be a motherboard problem
Oct 04, 2008 | E-Machines Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
