Question about Whirlpool Duet GHW9150P Front Load Washer
Its saying F 71 and will not start no lights turn on
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F71 is User Interface Heartbeat failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit. To resolve this issue you’ll have to:
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
Airbag light code 71
Air Bag Code, Symptom 71, Passenger Presence System Invalid Serial Data. System is not getting reading from pass side seat occupant detection sensor. May be able to calibrate
Apr 10, 2014 | 2000 Toyota Tundra
Check engine light flashes 4-3-7-1 what will be the code number
I would guess 2 codes--43 and 71. 43 says starter signal not reaching ECM. Are you push starting the truck? If not, might be a bad wire from the ignition switch to the computer.
71 is low EGR gas temp. Could be the sensor signal is not reaching the computer but more likely the EGR valve is not opening. May be stuck/clogged, has torn diaphragm, or is not getting vacuum. I believe the vacuum is controlled by a thermal valve. Check to see that the thermal valve is getting vacuum from the intake manifold and opening to deliver vacuum to the EGR valve when the engine reaches operating temp.
Dec 04, 2011 | 1991 Toyota Pickup
1994 4Runner V6 (non-4wd) error code 71
2.4L code 71 - EGR Gas Temp Sensor
3.0L code 71 - EGR Gas Temp Sensor
There is a test procedure to tell if bad sensor or wiring problem, can email diagram to you if like need an email address to send to
Feb 08, 2010 | 1994 Toyota 4Runner
My 03 explorer will only start when we cross the cylinoid with a screwdriver. when we try to use the key, all the lights and everything works, it just won't start. it won't turn over
Does the cylinoid "click" when you turn the key? if not, replace it. If it does, check your Ignition fuses, there are 2 or three. Look in your manual for locations. Hope this helps
Jul 05, 2009 | Pro-Fit Pro.Fit Fo 71 02 Ford...
Turn it on it says Set UP using stylus. But nothing happens.
The digitizer is defective and needs to be replaced.
You can find digitizer parts in ebay or other on-line companies, at reasonable prices.
Regarding the labor cost, depending of the repair shop you choose, it may be cheap or expensive.
Best regards,
May 28, 2009 | Palm Zire 71 Handheld
2004 Chev Colorado Z-71 4WD ABS "chatter"
Did you ever find a solution to this problem? My 2004 Colorado just started doing the exact same thing!
I can be reached at garyru21@juno.com
Thanks!
Mar 09, 2009 | 2004 Chevrolet Colorado
Problem with my nokia e-71
Hi simply turn on the phone and press from you keypad
*pw+CODE+1# it will say restriction off...if not do the same method but apply 7 instead of 1.........that will unlock
thanks
Shaan
Jan 27, 2009 | Nokia E71 Smartphone
Panasonic cf-71
You should be able to turn your wireless on by going to connection preferences in your Start Menu.
Sep 13, 2008 | Panasonic Toughbook 71 Notebook
TV turns on by itself
Just change all the buttom (switches) including: volume, channal, power, and menu buttom. That is the only problem
Nov 20, 2007 | RCA D52W15 TV
Whirlpool Duet GHW9150P Front Load Washer Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal De
