Question about Bosch Exxcel WOP 2400 Top Load Washer
Bosch wok 2001
I have the above machine which I assume is an old version of WOP2400. It has been brilliant but just went wrong. When I press the START button for any programme the lights all flash and "07" appears in the minutes window. The user manual says this indicates the drum has not been closed properly, but this is not the case. Do you please have any ideas about what else could cause this? Thanks Julia
  • Anonymous Aug 26, 2008
    We have exactly the same problem. What steps canw e take?
Our Bosch washingmachine also suddenly went wrong and gave the code 07. According to the fault book the drum was not shut properly. This was not the case. The brushes of the motor had worn, these needed replacing. It now works again.
Posted on Aug 31, 2008
Fill the whole system with hot water and add a bottle or two of mr muscle lime scale remover, leave to soak then drain via the bottom
Posted on May 27, 2008
Feed dogs will not move fabric
So right! You are brilliant!
Jul 03, 2015 | Sewing Machines
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
Bosch varioperfect washing machine error E18
No solution just a HUGE THANK YOU Chrismoyler as you've written a brilliant explanation on how to fix my washing machine!! Kids clothes stuck in it at 9.50pm and needed for school tomorrow. You saved the day!
Aug 11, 2012 | Bosch Washing Machines
It won't drain and says F4 on display, I have checked the filter at the front and it is clear, it is plumed in into the sink and that is not blocked? Pls help I can't afford a new washing machine...
That fault code is to do with the drain pump either its jammed or not working remove the front plate at the bottom of the machine undue the filter and check to see if it is either a blockage or something jammed in the pump.
Hope helps.
May 11, 2011 | Bosch Exxcel WFO 2264 Front Load Washer
Hi, I have a Bosch SMS 4012 dishwasher. It's about 20 years old but looks (inside anyway) as good as new. It's only the design that ages it really, it's been brilliant and I'm loathed to replace it but I...
Hello Pauline,
The handle and latch/lock are sold separately but both are still available direct from Bosch. This model was sold in the UK and Australia, but I'll assume for the moment you are in the UK and provide details for for ordering parts in the UK.
Plastic handle for Bosch SMS4012
Bosch part number: 056219
Price: £5.12
https://www.bosch-eshop.com/eshop/bosch/gb/prodls.htm?eshoptype=A&matnr=000000000000056219
Lock for Bosch SMS4012
Bosch part number: 056218
Price: £19.13
https://www.bosch-eshop.com/eshop/bosch/gb/prodls.htm?eshoptype=A&matnr=000000000000056218
Both parts are in stock and ready to ship. Bosch have a standard delivery charge of £5 per order.
You probably only need to order one of the above parts. You said it wont open/close, so you probably only need the lock unless the plastic handle is cracked/broken as well.
With regard to replacing it yourself, it's fiddly and requires some dis-assembly of the door and control panel but it can be done on a DIY basis if you're patient, practical and you know the difference between a pair of pliers and a screwdriver ;) (you'll need both)
It's not the most difficult job on the washer but it's not the easiest either so you may want to consider calling a professional. You could also order the parts yourself and pay someone to fit them as this usually saves a bit of money, but you should inform them beforehand that you will be doing so. Some engineers make extra profit on the parts and aren't keen on having the parts supplied!
Either way, the parts are still available so the dishwasher can be repaired. If you are not in the UK please let me know, but the part numbers should be the same wherever you are.
If you decide you want to try replacing it yourself, I can provide further guidance, but this washer was made before I started repairing dishwashers and I don't see many of these washers now. It's one of those repairs I could do if I had the machine in front of me but providing step by step instructions without being able to see it is a little more difficult - but not impossible! You will probably have to figure out one or two bits for yourself . . .
Hope this helps. Please let me know if you would like further assistance.
Regards,
BElectric
Mar 16, 2011 | Bosch Dishwashers
Washing machine, Bosch WOK 2401 Doesn't wordk 3 lamps are flashing: wassen , spoelen , centrifugeren/pompen. (wash,rins, pump?)
Washing machine, Bosch WOK 2401 This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 09, 2011 | Bosch Washing Machines
Bosch Classixx 6 1200 express has an error code F21 what is it
it is a motor or pcb fault this is a reset code as follows,
turn dial to off 12 0clock position then turn to 6 oclock,
press and hold the spin buttonat same time turn it to 7 oclock,continue to hold the spin buttonfor 5 seconds,release button,turn off.
next time you turn on the error code should have gone ,
if it does not work go through the proceedure again i had to try it 3 times but it does work
Mar 10, 2010 | Bosch Classixx WFO 2866 Front Load Washer
Bosch Dishwasher will not take in water
Either the pressure is too low, or turned off by accident. Otherwise it could be a faulty inlet valve
Please leave feedback
Thanks
Rob
Feb 13, 2009 | Bosch (1619EVS-RT)
Bosch Exxcel WOP 2400 Top Load Washer Logo
765 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
