Question about Rheem Paloma Tankless Water Heaters PTG-74PVN Tankless RTG-74PVN
No hot water this AM. I unplugged and reset the Paloma 7.4 NG unit, bled the gas line, tied in the remote (which I didn't use before), cleaned the water filter, and increased the temp to 110. The unit goes on most of the time, however there are times that is flashes "76". Is that the temp of the water going into it? Sometimes lose the hot water.
Need to convert Paloma gas heater from natural gas to lpg in qld.
You can't!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Among other things besides having to reprogram modulation, you'd also need to re-jet it and that's not possible in the field. NG and LPG jets are not the same due to vastly different operating pressures.
Some brands can be field converted but not Paloma/Rheem/Richmond/Rudd Tankless units!
May 18, 2014 | Water Heaters
I have a paloma tankles water heater model #ptg-42pvn i am getting an intermitent error code C4,12. what is the problem?
Copy following link for Rheem-Paloma tankless troubleshoot and error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
If unit worked before: Maybe bad PC board. Maybe lack of required yearly maintenance.
Common error codes can be caused by not following maintenance protocol such as cleaning combustion parts, checking gas pressure, checking venting, and air intake, bleeding gas line etc.
Too bad Rheem-Paloma manuals do not show HOW to conduct this maintenance, leaving customer with many unknowns, and no way to oversee that maintenance performed by hired technician is complete, and matches recommended maintenance.
Sell unit on ebay, and install tank-type gas water heater.
Mar 20, 2013 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Error 13 paloma tankless hot water system. no hot water
Before calling service technician, open following links for error codes, Rheem/Paloma chat and tech support, and possible manual:
http://www.fixya.com/support/t3444443-paloma_tank_less_water_heater_flashes
Error codes are considered start-point for troubleshooting.
Tankless manuals recommend yearly service including burner cleaning, gas pressure and plumbing check, de-liming etc to prevent problems and so technician is familiar with that specific unit.
Aug 05, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have an error code of c2 11 on rheem model number ptg-74pvn-2 I will get warm water for about 5 seconds and then it goes cold
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner -Lou
Dec 10, 2010 | Rheem Tankless Hot Water Heater...
Paloma C-7 error
Remove power source from the unit. If remote control is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support.
If this helps, please indicate so.
Mike//jzklipper
Sep 14, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have the same issue - random hot water
You have a bad igniter, and the sensing switch is shutting the fan off because the igniter is not functioning properly.
The average cost is about $150 for the part.
Aug 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Tankless Paloma NG hot water heater shuts down
have you checked the error codes on the heater?
you can do this by powering off the controler and pressing the up and down keys for a few seconds. this should take you into the diagnostics mode scroll using the up and down keys till you find the one that has the letter E on it and that will give you the last 8 error codes write them down and get back to me
Jul 16, 2009 | Rheem Tankless Hot Water Heater...
76 C8 error display on control board
Call Paloma and they will send you a new circuit board. We had the same problem. Our heater is a little over 2 years old. They said the error "76" is a circuit board issue where the tank is not communicating properly with the remote. The other solution they told us was to disconnect the remote and just let the heater run on the default.
Jul 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Hot water shuts off at random times.
yep, got the same problem, try unpluging the unit for five minutes and the reset the temp.
Jun 08, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem RTG 53 PVN with fault codes C4 or C7
I had the same problem with my tankless waterheater (flashing c4 76 alternately). I called Rheem
tech support and they had me 1 power down the remotepanel 2 unplug the unit from the wall 3 remove the cover 4 remove the wires for the remote panel from the circuit board and pull the twisted pair that goes to the remote out from the bottom of the unit. 5 reinstall the cover 6 plug the unit back
into the wall and turn on the hot water see if it works. It did in my case and they are sending me a new remote panel. I hope it helps.........
Nov 21, 2008 | Rheem RTG-53PVN Indoor Natural Gas...
Rheem Paloma  Tankless Water Heaters PTG-74PVN  Tankless RTG-74PVN Logo
66 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
