Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Washing machine motor not turning when loaded but turning when empty, and it's getting hot.
  • Whirlpool Master
  • 8,220 Answers
Inspect the rotor position sensor for loose or frayed wires. The washer tub and motor are all suspended on 4 rods. See page 59
More about the rotor position sensor is on page 57 of your service manual.
Whirlpool Cabrio Washer with 6th Sense Technology.pdf
Google Docs. 16 megs. Printable version.
Was this helpful?
Posted on Sep 13, 2010
Siemens xlm1600 drum doesn't turn - motor running - full load of wet washing. Inlet/outlet checked and cleaned - ok. Won't even turn when empty. Whats up?
something jammed between outer drum and inner drum or bearings jammed, if any off these then belt will be burnt Re: Jeff
Apr 12, 2012 | Siemens Washing Machines
Will spin empty but with a load will not spin.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine will not spin. It will spin slowly but not fast enough to empty tub
Get the motor checked.Its either getting weak or the motor coupler is cracked.Also see if the drum is turning freely and nothing is blocking it.Any small cloth or any object blocking the drum. Thanks.
Jan 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine makes clothes get black stains Kenmore front loading Heavy Duty 2 way tumble machine.
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 02, 2009 | Kenmore Elite 45986 Front Load Washer
Bosch washing machine wont spin or empty
PAV2300 Top Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 20, 2009 | Maytag PAV2300 Top Load Washer
Washing machine WK61420GB drum does not turn
replace the brushes in the motor ( approx £5 parts)
Dec 30, 2008 | Siemens WK61420GB Front Load Washer /...
Washing Machine Smell and Stopped Working
thatss what it sounds like to me the motor simply turned off on overload( giving that electrical, almost burnt rubber smell.) either that or it was overloaded as well as overworked. i wouldnt see any reason for concern, unless was happenig on regular basis
Apr 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine fill but won't go through cycle.
Too empty your machine reset the programmer to Final spin. the machine should empty normally.
If you have a fast flashing light its most likely to be 1 of 2 things.
1. The belt from the motor has broken. (price for belt is less than 20 pounds.)
2. The brushes in the motor have worn down too much to make the drum turn. Look underneath the washing machine to see if black power (Carbon) is deposited under the motor.
(Price for set of brushes is less than 20 pounds)
Labour should be no more than half an hour by anyone decent.
Regards
Feb 22, 2008 | Hotpoint WMA46 Front Load Washer
Washing Machine fills and emptys but does nothing else.....
sounds like the drum belt has come off the pully or at worse broken.quite simple to mend.good luck.
May 05, 2007 | Bosch Exxcel WFO 2465 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
123 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
