Question about Sony Televison & Video
I have a Sony KDL32D300 Digital 100HZ Lcd Tv that I bought 3 years ago for around £800. The television no longer displays a picture, just a series of vertical coloured lines that cover the entire screen. I tried unplugging all connections and rebooting with no joy though. I can't even access any of the on-screen menus as this is effected in the same way. This meant I couldn't even ttempt to try and restore factory settings. Can anyone help me by telling me what the issues might be or give me so ideas of what to try? My guarantee expired 5weeks ago. Thanks
  • shauncallow Sep 13, 2010
    Thanks for this v useful. If I wear to attempt to fix this, where might I find the multi-wireed cable? Would I have to unscrew the back of the TV? Have you got any directions on this.
    thanks once again for your help.
    Cheers,
    Shaun
  • 201 Answers
Unfortunately the vertical colored lines usually indicates the lcd panel is faulty. Replacing that part is usually more expensive than just replacing the TV. If you want to try a fix there is a multi wired cable that plugs into the panel. there is a slim chance that reseatting cable on both ends could help.
Posted on Sep 13, 2010
Testimonial: "Thanks so much for this - very useful."
  • Chi Chu Sep 16, 2010
    No outside truama to the LCD screen panel like by a person or an object like hitting it?Yes, colors lines on the LCD screen panel is fixable.The T-con board is dead.This T-Con board sit at botton right in the middle of the LCD screen panel.Try Ebay.com to buy a refurbish T-con board for the replacement,make sure the T-con board u buy from a European tv PAL siginal frequencies.U in the European contries right?
  • shauncallow Oct 14, 2010
    Yes - I'm in England, UK. I'm still struggling to find a t-con board that is suitable for the TV. I'm informed that part no's 1-789-796-11 and 1-789-796-12 will do the job, but I can't find anywhere on line that sells them. Any ideas?
My Sony TV Model KDL-40EX520 digital colour had a discoloration problem on LCD panel is problem a major one and factory defect. Just bought and used more than a year. How to find for replacement if no
its a comman problem in sony lcd please there is a problem in system board near lvds jack replace common mode coiles which are very near lvds jack these coils are open after replacing your tv become ok
Dec 30, 2013 | Sony 40 KDL40EX520 LCD TV
Tip
How to set 100hz or Motionflow/Trumotion Effect on Panasonic 42X20 Plasma or...
To those who want to have the Motionflow/Trumotion effect on this Plasma Flat Panel TV or similar models, do the following:
1. Set your media player / source (PS3, Xbox 360, Western Digital Media player, Apple TV, etc) at 720p@50hz / 1080i@50hz / 1080p@50hz.
Note: not all player supports 50hz read your source manual if your source/media player can support 50hz
2. Go to the TV's menu and select Setup
3. Select Other Settings
4. You will be able to change refresh rate to 100hz for a Motionflow/Trumotion effect that they have on LCD/LED (if you don't see the 100hz setting that means your source is at 60hz not 50hz)
Note: 100hz refresh rate is different from 600hz subfield drive.
on Mar 26, 2011 | Televison & Video
We have a Sony Bravia KDL 52 xbr9 tv. It is about 1 1/2 years old. We bought it Nov 29, 2009. For the last few weeks when we turn the TV on, the picture is distorted and dark (there are horizontal...
The board that call the T-CON board it is dying and dead soon.That why it is causing horizontal or vertical lines and distoted pictures.This T-CON board sit in at the bottom in the middle of the tv LCD screen panel and it only job are to decoded pictures pixels before it go onto the tv LCD screen panel.Tries websites Shopjimmmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.
Jul 20, 2011 | Sony KDL-52XBR9 52 in. LCD HDTV
I bought my 46" samsung
The Capacitors on the Main Power PCB are failing which is why it's taking 3 attempts for them to charge before the TV will switch on.
These could be replaced for a few $ if you know someone with the technical ability and equipment.
Failing this it would require a new PCB at around $120 + fitting.
Jun 11, 2011 | Samsung LN46A650 46 in. LCD HDTV
Our phillips tv 100hz digital scan 29pt9418/79 won't power up
Yes,it about 90% of the times,it the power supply board.U can look around the power supply board for puff up bulge capacitors,replaced these caps will get ur power back.10% it ur Tuner signal board.If find no defective caps in ur power supply board.Tries websites Shopjimmy.com.Ebay.com to buy ethier refurbish power or tuner boards for the replacement.
Apr 04, 2010 | Philips 26PF9966 26 in. LCD Television
Digital
If the set is an LCD, yes, it is "Digital" but that only refers to the display. To receive digital off-the-air broadcasts, the set must have a digital or ATSC tuner, otherwise the set has a standard tuner that will no longer work. If the set is "digital ready" a digital satellite/cable/off-the-air converter box must be used, and fed to the set's video input(s).
Did you get fooled? Hard one to answer. It more than likely was the result of the sales person's lack of technical knowledge. "Digital" and "Digital Ready" designations have confused just about everyone since "digital" was first introduced to television.
Hope this clarifies some of the mystery, rhais.
Jun 19, 2009 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Akai LCT3201AD 32 in. LCD picture stretched around the corners
This set has several differant aspect ratios, could you have unwittingly change it to a zoom or expand by mistake?
Feb 07, 2008 | Akai LCT3201TD 32 in. LCD Television
Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Aug 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
793 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
