Question about HP Office Equipment & Supplies
Error 321 when using HP 4500 manual fax - HP Office Equipment & Supplies
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Trying to buy English language manual for HP
Go here
You can download a manual directly from this link..for free...
heatman101
Posted on Jun 16, 2011
How can I get a parts manual for Hp officejet 4500?
the challenge is that many of the parts are not available at all so a manual would likely be of no use. You can check a site like this Feedroller HP Feed Rollers Printer Parts HP Laserjet Feedrollers
but I do not think they have inkjet parts.
Jul 25, 2015 | HP Officejet 4500 All-in-One -...
Parts manual
Hi richmusa42,
Although I don't know what part you are looking for, I did find the HP PartSurfer link for you:
HP PartSurfer
I hope this helps. If you can't find what you are looking for, you might consider calling us. What you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
Step 1. Open link: h22207 www2 hp com
Step 2. Enter Product number or select to auto detect
Step 3. Scroll down to "Still need help? Complete the form to select your contact options"
Step 4. Scroll down and click on: HP contact options - click on Get Phone number
Case number and phone number appear.
Best of luck.
I work on behalf of HP.
HP Officejet 4500 scanner does not work
there is a service manual for this family here http://www.maisiemanuals.com/product_info.php?products_id=4975
It might help you to solve the problem
Jan 02, 2015 | HP Officejet 4500 Wireless All-in-One...
HP officejet 4500 - "incompatible print cartridge"
please replace your cartridge then not solve this problem please check your printer settings correct countrie set, after not solve this problem please replace your carriage unit for your printer
Jul 22, 2014 | HP Officejet 4500 All-in-One -...
What is the problem and solution to error code 420 or 321
Are you able to send fax to another # ?. Error 420 & Error 321 is mainly due to transmission of signals or incompatibility issue.
Try reducing Fax speed and turn off ECM from Fax menu and check.
Regards,
Sean
May 15, 2014 | HP OfficeJet D135 All-In-One InkJet...
I have an HP 8500A printer/scanner/fax. Everything works but the fax. I can receive but I can't fax out. I get error 348, 321 & 358.
Hello and Welcome to FixYa!
Sir/Ma'am these error are basically due the Communication error of Receiving/Remote Machines. But each error shows different meaning.If during fax you receive the Error 348 then it may be because of several reasons like:-
  1. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise,Other reasons can include power outages and other power-related problems.
  2. When The call-waiting service can cause this error or the remote user pressed the Stop key while the reception was in progress.
You can solve the Error 348 by the following
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
If during fax you receive the Error 321 then it is because of:-
  1. There was a communication error with the receiving fax machine due to poor telephone line conditions.
You can solve the Error 321 by the following:-
  • Set the receiving machine to receive at a slower transmission speed
  • If the session fails after sending several pages of a large document, resend the document as several smaller documents.
If during fax you receive the Error 358 then it is because of:-
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
You can solve the Error 358 by the following:-
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
I hope this solution helps you and you have clear picture in your mind.
Let me know if you have any confusion in your mind
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Dec 05, 2011 | HP Photosmart 2710 All-In-One InkJet...
Error code
Hi Mike,
The error message "A communication error has occurred during the fax transmission" normally indicates that for some reason the fax call was interrupted or there was some interference on the telephone line during the fax transmission. Some possible interruption/interference on transmission(s) are:
1. the telephone line is not a dedicated fax line - there could be an extension which was inadvertently lifted/used during a fax call;
2. noisy/dirty telephone/fax line - corrosion on the terminal, joints, connectors, pins, plugs, jacks, telephone outlet or even on the provider's system. This could be determined by using the handset of the fax machine, dialing a single digit (to make the dialtone disappear) and listening to the phone's earpiece. There should be no crackling sound or static but a clean/dead air. In some cases where the telephone/fax line is shared with the DSL, then it could be the filter/splitter used;
3. some phone lines can still accept an incoming even though in use (call waiting) - the ringing of the 2nd call is more than enough interruption/interference;
4. RFI (radio frequency interference) - an electronic device that transmits a radio signal such as a two way radio, a WiFi router or mobile phone; and/or
5. noisy/dirty power AC mains -the outlet/AC power line where the fax device is plugged in has some other appliances/devices that draws power from it that can cause static/transients/spikes along the power line. Examples are water dispensers with built-in cooler/heater, dehumidifier, aircons, refrigerators and any other that switches itself on/off. A simple solution would be to use a different outlet and/or use a surge suppressor.
As to the "error code number 321*", pls post back the make and model of your fax device. Alternately, you can reference this site. If your fax machine/device is an HP brand (and/or the receiving end's fax machine is), pls check this link.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Office Equipment & Supplies
372 people viewed this question
Seeker5211
Seeker5211
