Question about GE Dryers
I have a ge gas dryer mod.#dx4500ge1ww the ignitor comes in and the burner comes on for about 3 min and the burner turns off
    Master:
    Sergeant:
  • 449 Answers
Have the flame sensor checked if your hsi is the flame sensor replace the hsi (ignitor)
Posted on Sep 14, 2010
AMANA GAS DRYER, MOD.#LEA1OW/LGA10AW . CLOTHS WILL NOT DRY-IGNITER LIGHTS, BUT GO OUT BEFORE BURNER COMES ON.NO HEAT.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Amana Dryers
Gas dry will not heat
Do this first
Remove all exhaust vent tubing and clean it out thoroughly.
Any lint build up will prevent the burner to operate
A moister sensor stops the burner when it senses lint build up
Reattach the vents now and proceed to the next steps below
If thoroughly cleaned & no build up is present start the dryer and listen for the spark ignitor to click. If it does not click the ignitor is bad. If it does click and no heat appears to come through the dryers drum within 30 seconds the moister sensor is at fault
May 17, 2010 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer
GE Dryer DDG7580B does not heat. vents are clear, dryer tumbles, just no gas ignition. Other gas appliances working well. Help!
Replace the ceramic ignitor WE4X444. An easy fix. Nut is on the gas valve (not the line) to remove the burner assembly to replace the ignitor.
Good luck..
Jan 31, 2010 | GE Dryers
Starts drying for about 15 mins then stops
Sounds like this is a gas dryer. Look at your burner after the dryer stops heating .Does the ignitor come on then go off without the burner firing?If so replace the 2 coils on top of gas valve wp #279834 msrp $20.00. Please rate my solution :)
Nov 14, 2009 | Dryers
Kenmore gas dryer mod.110-73942. burner comes on as normal. After 5-10 minutes running Cycles off, igniter ( new) glows but no burner ign. Also replaced the sensor adjacent the igniter.
The gas valve coil is bad. When the ignitor is glowing the gas valve should open and allow gas in to be ignited. Change the gas valve.
Aug 05, 2009 | Kenmore 63942 Dryer
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
GE gas dryer, no heat, new ignitor
Hi!! make sure that you have 120 volts going to the glow ignitor.the gas valve will not turn on the gas if the ignitoe wont glow..if it glows the check yout coil boosters they are round and are located by the gas valve.then if not you have a bad timer.they are usually round and are black..good luck..
Jan 03, 2009 | Dryers
Electric starter gas oven model jgrp17 won't heat
more than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
Nov 13, 2007 | GE JGRP17 Gas Single Oven
GE RANGE MODEL #JGBP35BEA2BB
Sounds like that ignitor is weak.  When the ignitor glows it builds up resistance to the gas valve for gas to come in.  If it sometimes takes 10 min then the proper resistance isn't there and this will give you that gas smell.  Replace the ignitor and this should solve your problem.  Can expect to pay $80 - $100 for the part.
Oct 14, 2007 | Kitchen Ranges
Dryers Logo
50 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
