Type of cable from wall cable outlet to tv plus what imput to use Thanks
  • 201 Answers
Coax cable and the input on most sets is "TV" use the input button to cycle through the choices. You may need to programm TV to see cable. Go into TV menu look for channel setup. there will be reference to whether you are using air(antenna) or cable. also you must "autoprogram" so TV will lock onto channels that are available.look for that option as well in setup. good luck
Posted on Sep 13, 2010
How to get video from dvd to tv
Use HDMI wire if you have that option than simply tune TV to HDMI 1 or HDMI 2 etc depending which one you connect it to .
OR. analog ( R C A ) cables analog. Output from DVD player to imput tv """ red is right white. Is left sound. Yellow is video pay attention to where you are plugging on TV.video 1 or 2 or 3 Since you will have to go to ( video. Or imput ) on your TV to access the DVD player. Another words your cable box is a TV imput . You're doing is also a TV imput You have to tune it to be able to watch it
Feb 16, 2015 | Universal 40-42 Inch Flat Screen Panel...
How do i setup my tv through surround sound without a cable box?
Unfortunately Without the cable box you will have to screw the coax cable into the coax input on the tv or You can screw the coax cable into a vcr and then plug the Audio / Video RCA plugs from VCR out to TV RCA input (You will have to control the channels from the VCR and the volume from the TV remote)
Dec 27, 2013 | Samsung Televison & Video
Mitsubishi TV WS-55909 only has 1 HD component imput spot; I have 2 HD devices?
look on the internet for a hub like usb ones the computers use.
Nov 29, 2012 | Televison & Video
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
We lost power the other night when it cam on there was no power to my cable box or tv the outlets still work because i plugged something else in them is there a reset button on the tv
Is the TV connected directly to the outlet in the wall or through a power outlet on the cable box? If so connect the TV directly to the wall and see at least if it does power up. If it does than the cable box is bad and will need to be replaced. If neither the cable box or TV power up when connected directly to the outlet then the possibility is you had a power surge that damaged both.
Nov 17, 2009 | Televison & Video
I can't insert the DVD into the slot on the TV.
Check wall outlet for current if it dont come on, go to anoter outlet, if the unti fails to turn on its a power supply unit fuse inside deeds to be replaced thanks
Apr 23, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
The screen on my 1 year old 42 inch Akai plasma tv suddenly went blank although I still have sound. Any clues?
Reset the cable/sat box and tv by turning them off, unplugging them both from the wall outlet, and replugging them after 30 seconds. See if you get pictue back when they get the correct handshake. also, make sure that there are no loose cables going into the TV or into the cable/sat box. You can try using a different type of connecting cord from the cable/sat box to the tv to make sure it is not a bad connecting cord.
What type of cable is connecting your cable/sat box to the TV? Is it HDMI?
Are you using a video game system on the plasma?
Mar 07, 2008 | Televison & Video
Imput channel or imput switch
if you scan down below channel 2 doesn't video show up? otherwise there should be a input / video button
Dec 31, 2006 | Zenith B27B40Z 27" TV
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
Electro Med Services...
