Question about Carrier 52PQ307 Wall/Window Air Conditioner
How to reset FL on carrier aircons - Carrier 52PQ307 Wall/Window Air Conditioner
My aircon wasn't produce cool air?
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Check us out online at AC Service Delray Beach Fl
Apr 19, 2016 | Heating & Cooling
I need to find a control circuit board for this Carrier aircon. Any ideas?
You need the model number and serial number of your unit.Then call or go to your local Carrier dealer or the local appliance parts house.
They should be able to help you.
Nov 09, 2015 | Carrier Heating & Cooling
I have a Carrier Aircon. Model 42QH12-C and it is displaying error code 5. The aircon stays on for a while (anywhere between 10-60mins) and then turns off and displays E5. If I just press the 'on/off'...
E5 Outdoor activation of compressor over heatprotection or motor lock
Please clean the condenser coil. And also check out door fan motor rpm. Rpm may be less due to weak capacitor. Replace it.If motor locked you have to replace new motor only.
If helpful, please write.
Dec 20, 2010 | Carrier 38CKC042 Air Conditioner
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
Not turning on
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If it wont work replace your Room Air and Coil Thersmistor or test the thersmistor with mulitester. The resistance reading of thermistor is 10 kilo ohms @25deg. C room temp. If it is shorted or open the unit wont operate.
Hope this can help :)
Dec 30, 2008 | Carrier 36KCARMS Air Conditioner
Sudden brownout
hi,
it has a small microcomputer which will shut off if /or error if the voltage parameters are too far out(brownout,surge) carriers are a higher end machine, better parts, should be fine..
jm
Jul 27, 2017 | Carrier Heating & Cooling
What FL stands for?
FL means change filter media
Sep 13, 2007 | Carrier 38CKC042 Air Conditioner
Carrier 52PQ307 Wall/Window Air Conditioner Logo
386 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
