I have a Seagate ST300003U2 external hard disk that no longer seems to power up. When I plug the cable in and switch on the power, all that happens is the green LED power light flashes. Any suggestions? Many thanks Jason
Teckies
  • 226 Answers
SOURCE: Seagate 300GB ST3300601U2-RK
usb cable provides power to your hard drive.
try to use new cable.
hopes it works.
pls. confirm
Posted on Jan 30, 2008
SOURCE: Seagate FreeAgent External 500GB HDD - Data Recovery
well firstly if u wana recover ur data u have to make the external hdd power up but thats the major area of issue that its not powering up. the difference in plug doesnt make a difference cuz u can use the same plug,the voltage is same thorugh out in ur place from the substation. so it might be a possibility that when u connected ur hdd,the power ON/OFF switch was awredy ON IF hdd has one. so wat i feel is dat u can try opening the hdd and then connect the hdd to ur desktop with help of the BUS CABLE used to connect the HDDs in desktops. so in dat case i would suggest that u go through the manual of ur external hdd to see how to access the the casing in which the hdd is there.then if u happen to get thorugh n it turns on then u dont have to recover ur data. it would still be there. HOWEVER,its recommended that u dont try these things personaaly if u are'nt too tech savy. u shud consult a tech or a freind who knows abt this.
Posted on Oct 06, 2008
  • 28 Answers
SOURCE: seagate external hard drive green light blinking
that problem means that it is acsessing the files on it. it is not a worry for you.
Posted on Sep 14, 2009
SOURCE: Flashing green power light
Spoke to maxtor. The blinking green light on the power cord is a problem with the external casing for the hard drive. Several of the posts talked about taking the case apart and connecting it to the pc to download information. I thought they were crackpots. After talking to the service tech on the website it looks like that is the only fix. So... based on all the posts with the same issue I may avoid this product line int he future. Hopefully it is truely a backup for you in which case toss the old one and buy a new ext. HD. If it isn't a backup take it apart gingerly, download the information, replace the hardrive.
Posted on Dec 19, 2009
Crankstart
  • 696 Answers
SOURCE: seagate external hard drive is flashing blue light
Sounds like you have either bad voltage from your power adapter or a failed enclosure.
First thing to do is check the ac adapter your using, find the output Voltage, should be between 5-16V and the output Amperage, should be between .25A and 5A depending on the type of seagate enclosure you have.
Now look at the stickers on the outside of the drive enclosure to verify that it uses the same voltage and amperage. If it doesn't you're using the wrong adapter(easy mistake after a move). If it's the correct adapter then you may have had a failure in the enclosure.
The next thing to try is to take the drive to your local PC shop and ask the technicians there to transfer the hard drive inside it into a new enclosure for testing. If this works buy the new enclosure and you're on the way. If this also fails, something has failed in the drive itself and you will need the help of a pro. Have the technicians either return it to the original enclosure or pack it in a static free bag.
Now you have a couple options. I can refer you into one of several professional facilities depending on your needs. The most common one I use is www.armor-it.com They are the least expensive on average but average 4-5 weeks for non rush orders. If you need a faster turnaround and don't mind spending a few extra bucks, reply back and including your Country, City and State and I will refer you into an appropriate facility near you.
Crankstart
Posted on Jan 08, 2010
Seagate raw drive
Your data is already gone. The drive is raw. No partition no format.
here is a link to a free data recovery program, this probably wont work but may be worth a try
http://getdataback-data-recovery-for-ntfs.soft32.com/free-download/?lp=dsa&tg=us&kw=_cat%3Asoft32.com&mt=b&ad=35354358678&pl=&ds=s&gclid=CIa78aSmk74CFc5ffgod9gEAlA
just be sure to opt out of all garbage they want to infest your computer with.
Jun 05, 2013 | Seagate U6 (ST340810A) 40 GB Hard Drive
My external hdd has is not detecting
Seagate is a company that manufactures external hard drives.
These hard drives can be used to house large files or even to backup an entire hard drive.
When your Seagate external hard drive is not working properly, you might ready to send it into the company for repair.
Before you send it away, you can troubleshoot the problem and potentially save yourself a lot of time and grief.
Look over the power cable going from the wall outlet to the back of the Seagate hard drive. Make sure that there aren't any breaks or tears in the electrical wiring.
If there are breaks, replace the power cord.
Look over the power cable and make sure that it is plugged into the wall outlet in your home as well as plugged into the back of the hard drive.
Plug the power cable directly into the wall outlet or into a surge protector.
Do not plug the power cable into an extension cord.
Seagate Data Cable
Disconnect all of the USB devices that are plugged into your computer's USB ports except for your mouse and your keyboard.
Disconnect the Seagate external hard drive from your computer.
Unplug the power cable from the back of the Seagate external hard drive and restart your computer.
Wait until your computer has fully booted and then plug the power cable back into the hard drive.
Look over the USB data cable to make sure that there are breaks or tears in the cable.
Look over the ends of the cable where they meet the computer and the hard drive.
Make sure the pins are straight.
Replace the cable if needed.
Plug the data cable into the back of the hard drive.
Plug the data cable into your computer.
Hope this helps.
Nov 23, 2012 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Hi I Have an I O Error On My External Hard (500 GB Seagate) and I can't open or copy my files. Please Help Me. Thank You
  1. Unplug both the power cord and USB cable from the external Seagate hard drive.
  2. Restart your computer
  3. Plug back in both the power cord and USB cable from the external Seagate hard drive.
Comment back if this doesn't fix the issue.
Mar 01, 2011 | Seagate FreeAgent Pro 1TB External USB...
ST300003U2 hard drive powers up ok, power light on, message on pc "usb device not recognised " .one of the usb devices has malfunctioned and windows does not recognise it.
Try to plug it in to another PC to see if you get the same message. See if you can run a scan disk on it from Windows to see if it's bad or going bad too.
To be honest, device not recognised is a bad sign. :(
Dec 22, 2010 | Seagate (ST3320820U2-RK) 320 GB USB 2.0...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate barracuda external 500 gb hard drive usb not seen any longer,cables and power okay , tried on three computers
Verify what Drives have been detected by your Operating System by using Windows: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk(s) will be displayed with all existing partitions and any assigned drive letters.
Your external (or internal) drive must be recognized as having formatted partitions that have a drive letter assigned to each required partition.
Hope it helps: let me know how you go!
Dec 30, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I can't find my adaptor/power supply cable. can
Most are 12V for the FreeAgent drives, like the power inside your pc.
Oct 12, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Oct 06, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I wanted to know whether ASUS A7S266-VM/U2 will support seagate 7200.10
M/Boards support all makes of hard drive
Are you sure you connected it correctly
The wide ribbon cable that goes in the rear of hard drive should
1) Be connected to M/board in the No 1 connector with the stripe on cable to the No 1 pin
2) the stripe on cable should go next to the 4 pin power plug on hard drive
Also ensure your BIOS is set to Auto detect of driives
Aug 30, 2008 | ASUS A7S266-VM/U2 Motherboard
Open Questions:
Computers & Internet Logo
577 people viewed this question
David Payne
David Payne
