My Kariba Model 802 Washer/Dryer Combo goes thru its cycles but doesn't agitate. Can someone help me>(kjbus101@cox.net)
  • kjbus101 Sep 13, 2010
    where do i find a manuel for this Kiriba model 805 washer/dryer combo unit
  • 10,865 Answers
Hello. This is not a good thing. When agitation ceases, it is always a costly repair. i will tell you the things to check but before I do let me say that if the machine is over 3 years old you may be money ahead to replace as opposed to repair.
If your washer doesn't agitate, check these: Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley. Transmission The transmission may have a worn or broken gear, or some other internal problem. If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it. Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Posted on Sep 14, 2010
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link to diagnose your problem when you unit wont agitate :-
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntagitate
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 13, 2010
I need a water pump for a Kariba WD 802 washer/dryer combo.
Joan, just enter the name and model of your machine into a web browser, i.e. google, bing, yahoo et al, and the words spare parts, spares, or the like along with your state, / county / city / town and hit the search button, this should throw up plenty of results that you can trawl throygh and select your preferred supplier.
Jun 08, 2016 | Splendide RV Combo Washer Dryer - Vented
Why doesn't Cabrio washer wash the clothes?
This model has gone through different control board revisions, could be control board related, service mode would have to be accessed to have machine run thru self-diagnostics. if it does not agitate on self-diag mode, unit needs board
Apr 03, 2013 | Whirlpool WTW6400SW Cabrio Washer
Washer is not agitating in whites and slowly in colors. What and how do we troubleshoot?
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Aug 05, 2012 | Frigidaire FEX831CS Top Load Stacked...
Splendide Model WD 802 . Would not drain water.
I have a Splendid Washer/Dryer combo Model # WD802.
The water is not draining. I have taken the filter out, cleaned it, still does not drain. Gets to the drain cycle and does not go any further. Same in every cycle.
Anyone with suggestions for repair ? Thanks
Aug 01, 2011 | Washing Machines
Kenmore top loader washer. Goes thru cycles but agitator will not turn. Can't turn by hand.
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. Here is a video this will walk you thru checking and replacing the agitator dogs . You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Apr 07, 2011 | Kenmore Washing Machines
I am looking for a manuel for Kariba washer/dryer combo
Hi, Can you provide the model number, i.e. WD1043. It should be right on the front panel. I have some lierature but not much, so let me know and I'll watch for your reply. Macmarkus :)
Mar 24, 2010 | Washing Machines
Kariba WD 802, need a part number for the Wash/Dry Selector Timer. The machince works properly when manually rotating the timer, it will not advance on it's own.
head over to repairclinic.com and enter your model # for a complete parts list.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Splendide 2100 Vented Washer-Dryer
Kariba washer/dryer
I HAVE A (KARIBA) WASHER AND DRYER COMBO,, MODEL# WD802 , AND LOST THE MANUEL TO IT. CAN SOMEBODY FIND ME ONE
Dec 23, 2008 | Washing Machines
Supra SW5L30D parts
You can get parts for the Supra SW5L30D from EdgeStar (can't figure out if EdgeStar bought Supra, or if Supra just changed their name or what). 866-319-5473. I've been able to get the parts I've needed, though they're not the most efficient operation. One time I had to wait for someone to get back from vacation before the part could ship...
Jan 26, 2008 | Supra SW5L30D Front Load Washer / Dryer
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
