Question about Sport & Outdoor - Others
20 hp tvt-691 tecumseh wont run without the choke on. I've replaced the plugs,has good gas in it. It ran good earlier this summer,but the last couple of times i've tried to mow this problem started. won't run any different with or without the filter . has good fuel flow.
  • 41 Answers
SOURCE: engine runs rough when we throttle up
Hello, It could be ele. If you have ran cheap fuel in it and it has sit for a while, I would clean gas tank,lines, carb again, and run prem gas in tank.
Posted on Nov 25, 2008
  • 41 Answers
SOURCE: 1996 bayou runs for short time ,keeps stalling out
Hello, I would start first, make sure ex pipe is open . Then I would check the pick up coil, ohms should be 390-590 on a 300 KLF. Do this test before u start the bike Then start the bike and when it quits running check the pick up coil ohms. If good move on to the coil, If good then I would say good chance CDI is bad I hope this helps
Posted on Nov 26, 2008
SOURCE: 2004 Kawasaki Prairie 700 wont start
Never mind guys, i figured it out, the valves actually tightened up and pushed them off their seat, no compression, so i got the feeler guages and fixed it, lots more power now:P thanks anyway.
Posted on Jan 31, 2009
  • 49 Answers
SOURCE: engine keeps flooding out
Recommend completely draining the fuel system. Tank, lines, and carb. Make sure everything is clean and dry. Clean or replace fuel filter. Always try to store it with a full tank of fuel. It is common to get condensation when the weather goes from warm to cold and back.
Posted on Feb 05, 2009
SOURCE: kx 125 wont start
Try to clean out the Carberator. I had the same problem someone told me to clean my carberator which I never did before but i looked it up on youtube and tried it. All went well
Posted on Apr 01, 2009
Tecumseh 20 hp tvt691 only runs on full choke
Sounds like your fuel jet is plugged. if you have a fuel cup on the bottom of your carb remove it and clean it out real good.The fuel jet should be the little screw tat holds the cup on Take it out and blow it outwith an air compressor or put a real fine wire through it if you do not have air pressure. You should be able to feel air if before you put it together you blow through it.
Might be a good plan to dump your old gas out and make sure your fuel tank is clean and put fresh gas into it.
A large percentage of when the engines have to be choked all the time the jet is plugged or partly plugged. Do not mess with the float when you take the bowel off or you could have other issues to get it put back together properly.
Aug 21, 2016 | Tecumseh Garden
20 hp tecumseh, won't run unless choke all the way out and gas lever all the way up, also backfires. spark plugs good and seems to be getting plenty of fuel. Any ideas?
If the choke has to be on its not getting enough fuel into the engine. The carby and fuel lines etc have to be cleaned out. Regards Phil
Apr 12, 2011 | Tecumseh Garden
1995 Yardman 7 hp Snow Blower wont start. Ran fine last year and I drained the gas out. I cleaned out the carburetor, (tecumseh HSK70) 632371A. The top screw was 1/8 out from closed and bottom screw...
my 7 hp tecumseh yardman snowblower wont shift into gear worked fine but shifted hard (20 below) then wouldn't shift at all (loose) I noticed a rod that goes through the area where it shifts is loose (not connected) what is this rod. thanks for your help.
Jan 21, 2011 | Yard Machines Garden
Our HMSK 80-110 electric start snowblower starts up right away, but the idling is very rough. It runs very smoothly when it is engaged in snow throwing.
The Tecumseh snow motors are notorious for idling rough. Especially the last few years of production. Most service techs just say "live with it" But there are a couple of things you can do to help.
It is not a carb adjustment issue. It's usually a fuel, clean carb issue.
First, use a premium grade fuel without ethanol and a fuel stabilizer. This will give you the best fuel mix.
Second, Remove the carburetor shield and clean the inside and outside of the carb with carb cleaner. Even though you can't see the carb usually, they do get varnish build up and cleaning it will help some.
Third, Put the recommended amount of fuel system cleaner in the gas. I use Sea Foam brand. Over a tank full or two you will notice a difference in how the engine idles.
Fourth, Use a high quality spark plug and use a new one every year. Make sure the gap is correct.
Good Luck! Feel free to as any other questions you may have. Don't forget to rate this answer!
Jan 14, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
19 hp Murray garden tractor won't run
no sounds like your carb needs a real good babtising! good look!
May 19, 2010 | Briggs & Stratton Garden
Sport & Outdoor - Others Logo
167 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
