Question about Canon ZR700 Mini DV Digital Camcorder
My Cannon ZR700 will not turn on. The batteries is charged.
After charging the battery and the green light says its charged. I put it into my camera and it doesn't turn on
Do you have another battery you can try? The battery should be charged, must have a dead camera if that is the case.
Jan 08, 2016 | Cannon EOS Rebel XT 8 Megapixel Digital...
How do you reset a Cannon Power Shot A560 camera
Lens errors are usually caused when there is something interfering with the extension mechanism , or your camera been dropped with the lens extended, or your batteries ran down . try the ff. procedures hope this helps
  • replace a fully charged batteries / battery pack
  • check out this link
Do It Yourself Digital Camera Repair
Aug 27, 2014 | Cannon Cameras
What's your problem?I have a inca universal charger model rm-17 for cannon G11
Did you work this out? What should the screen read when it's charging? I'm trying to charge my LP-E6 in the inca RM-17 and the screen reads RE regardless of if the battery is in it or not.... I'm sure the terminals are touching
Jun 13, 2012 | Televison & Video
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
Can the canon zr600 use an 8 gb sd memory card
According to Canon's specs, the ZR600 uses DV tapes, not memory cards.
May 20, 2011 | Canon ZR500, ZR600, ZR700, and ZR800...
What is the maximum capacity of the memory card which the zr600 can accomodate?
You can find the information in the manual And you can read this ZR600 manual online page 124 in the bottom few line of words
I went to charge my canon FS100 camcorder than went to turn it on and it not working now what can be the problem?
have the same prob this morning, check the charging unit for the serial no. (will begin with CA) mine is CA590E, the 590 is a known problem to cannon, it will either discharge the battery pack (pray this is the fault) or it will internally damage the camcorder. mine is only 18 months old used a max of maybe 10 times. I will reply again this afternoon when i've tried a new battery charger, just waiting for my cannon dealer to open.
Mar 01, 2010 | Canon FS100 Flash Media Camcorder
Cannon camera will not turn on
Dear Trish,
There are a couple of things that will usually cause this. A few are simple to check.:
1. Make sure that you battery is inserted properly and that your battery door is closed completely.
2. Make sure that your CF card is inserted properly and that your card slot cover door is completely closed.
3. Make sure that your battery is charged (charge it for 90 minutes) and that your charger works properly during the process. Your charger's light should go from red to solid green during a full charge. If possible test a fully charged battery on another camera. If you don't have access to another camera take your battery down to a local store that sells Rebels and ask to try it on one.
4. If these aren't the cause then you likely have an electrical issue with your camera and you should call Canon's tech support at 1-800-828-4040 to do a little troubleshooting and possibly send the unit in for service.
Hope this helps.
Sincerely,
HeavyDLB
May 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon ZR700 Mini DV Digital Camcorder Logo
67 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
