Question about Kenmore HE2 Plus Front Load Washer
The meaning of error code 24? - Kenmore HE2 Plus Front Load Washer
  • 2,382 Answers
Hi, F24 error code a water temperature sensor error or enought hot water to the washer.
check to see you have both valves are turned on. Also, the water inlet valve on the washer has a screen and it is known to get clogged and restrict water flow. Turn off the hot water valve. Pull the hot water hose off where it attaches to the back of the washer.
Even if you are getting good hot water flow, inadequate water temperature can cause an F24 error code. Check the temperature setting on your hot water heater. It should be set at 120 F. You should reach this hot water temperature at your washer within about 1 minute.
If you are getting a good hot water flow, you may one of the following failures:
1 loose or dirty connection at the temperature sensor or control board.
2 The temperature sensor could be out of range. Bad or shorted sensor
3 Control board failure.
The temperature sensor should have a resistance reading of 6.6k ohms at 104 degrees F and should drop in Ohms as temperature rises,
The temperature sensor is located at the back lower section of the tub with 2 small black wires. It would require a ohm meter to measure the resistance of the sensor. .
Posted on Sep 13, 2010
Magiccard Rio printer is giving error code 24:24
Error code 24:24 means that the sensors need to be replaced. This requires sending the printer back to MagiCard for them to replace the sensors.
Mar 01, 2013 | Magicard Rio Card Printer
Error code 24
2,4 is one of 5 error codes and means:
2blink-then 4 blink---------vertical circuit problem
The set may have a loss of sweep or even Glycol may have leaked from the picture tube above it onto the board in that area.
Vertical circuit is on middle board at front right edge.
Jun 16, 2012 | Mitsubishi WS-55311 55" Rear Projection...
1993 subaru legacy fault code error 2 slow flashes then 4 fast flashes what does this mean ?
it means 24 Code 24 ISC solenoid valve fault, go to any auto parts store and they will tell you the fix for this problem code. auto-zone etc.
Mar 15, 2011 | Subaru Legacy Cars & Trucks
Code F 24 what does it mean The washer dose not allow me to do anything when I push start. All the areas light up and flash with code F 24
The F24 error code indicates a problem with the water temperature sensor. code meanings should be under lower cover, remove panal.
Jul 13, 2010 | Kenmore HE2 Plus Front Load Washer
OBD Error Codes
I get an error code of 052 on the A/C control unit in my 2000 Mercury Grand Marquis. Does anyone know what this error code means?
May 26, 2010 | 2000 Mercury Grand Marquis
What does f-24 mean?
inside the machine should be repairmans instructions. this includes explanations for all the error codes.
you will have to remove the front access panel
May 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
1992 Jaguar XJ6..vcm error codes
code 24 is the ignition amplifier circuit
Sep 08, 2009 | 1992 Jaguar XJ6
Airbag error code 24. What does it mean?
Common fault on FORD
Usually due to a poor connection in the YELLOW PLASTIC CONNECTOR underneath the passenger seat.
Just push it together properly and it should clear the AirBag fault
May 28, 2009 | 2004 Ford Expedition
Code: C 2 ??
C2 error code means, that the drain is clutched.
Removed all dishwasher water with a cup.
Added a gallon of boiled water, waited 10 min and it worked again( so far).
Regards
Sigurd
Jan 28, 2009 | AEG 24 in. Favorit 80800 Free-standing...
Kenmore HE2 Plus Front Load Washer Logo
659 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
