Question about Sunbeam 5965 Electric Kettle
Sunbeam kettle model # 3234-33. The kettle still works but it's the electrical connection seems has become finicky. It has to be wiggled to get the light and power tp stay on and sometimes turns off if it's not sitting just right.
4 Suggested Answers
  • 4 Answers
SOURCE: Tefal kettle - electricity not getting to kettle
it is shotcircuted
Posted on Aug 20, 2008
mc1bean
  • 3053 Answers
SOURCE: Sunbeam electric kettle: model 5739-33
In this case i think the element went out. Common with those. Yes i believe in this case it is not worth the cost and trouble to even attempt to fix it. Here is the cheapest place I found from a trusted store to get another one, and of course can have it shipped if you want. Target on line, For your convenience i put this link below and they have some that are a close out, that you cab get for $17.99 I hope this helps you , to bring the Joy Back :) Just copy and paste that link in your browser, should take you to the right section. Thanks Mike from fixya
http://www.target.com/s/180-4435579-9261449?keywords=sunbeam%20electric%20kettles&CPNG=rtcs%20coffee,%20tea%20&%20beverages&adgroup=rtcs%20%20electric%20kettles%20sunbeam&LNM=Sunbeam%20electric%20kettles&MT=broad&AFID=google&LID=26p2274095&KID=161e9907-52ea-f229-e371-00007fe2bb43&ref=tgt_adv_XS000000
Posted on Jul 09, 2011
jerryg50
  • 1667 Answers
SOURCE: where can i purchase a replacement heating element for my Sunbeam classic electric kettle
Do a google search on the web for Sunbeam support. Get in touch with them to find out where they have a dealer that can sell parts for their products.
You will need the proper crimp tools and connectors to connect the new element.
Take note that some of these appliances were designed to not be serviceable. When you call Sunbeam, they will be able to tell you that, and if they can see replacement parts for your kettle.
Many times when I had a bad heating element in a kettle, I found the therm fuse also had to be changed.
Jerry G.
Posted on Jun 26, 2012
Where can i purchase a replacement heating element for my Sunbeam classic electric kettle
Jerry G.
Jun 04, 2012 | Sunbeam Kitchen Appliances - Others
My sunbeam electric kettle will not work
I can sympathise, I have had three go wrong in the last few months! In every case it was the element, I suspect it will be the same with yours and there is not much you can do except replace the kettle.
If the plug has a fuse, you could try changing it, but it didn't make any difference with mine. Try to keep the element free of scale, that shortens their life even more. I don't believe it is worth buying an expensive kettle, they don't seem to last any longer than the cheapies.
Aug 24, 2011 | Sunbeam Heating & Cooling
Sunbeam electric kettle: model 5739-33 is just out of warranty.Went to use this kettle this morning, no blue 'on' light and no joy.Opened to cover to be sure all wires are connected, everything looks okay....
Jul 09, 2011 | Sunbeam Kitchen Appliances - Others
My electrical water kettle does not heat water...how to solve the problem?
Check the kettle at another socket to ensure the socket isn't the problem.
Replace the fuse in the plug.
If the power flex is removable from the kettle, check the terminals in the connector havn't become burned.
The chances are that the element may have burned out in the kettle and in this case it probably isn't worth repairing.
Mar 11, 2011 | Sunbeam Microwave Ovens
How do i get a manual that i can print out
I am looking for a manual on an Ice Tea Maker - Mr. Coffee Model 3.5
Jul 05, 2010 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
Rust coloured spots on insie of kettle
We buy DeBruce Polish at debruce polish.com, this stuff really works.
Mar 19, 2008 | Sunbeam 3211-2 Electric Kettle
How do I clean the contact points between kettle and platform?
PROBLEM:
My problem was similar for the Cuisinart KUA-17.  I clicked down the on switch and it stayed down.  However, the light and power together seemed finicky.  That is, the light came on if I positioned the kettle in the base correctly, but then it sometimes went off without triggering the switch to pop up.  When the light went off while the switch remained down the water never boiled, but when I was lucky to position it such that the light remained on, the water did boil and the switch popped up ... as it should have.  It seemed to be getting more and more finicky and difficult to position correctly ... so I took it apart.
SOLUTION:
First of all, the base has screws that take a triangle screwdriver which I don't have.  So I found a small flat-headed screwdriver (like one you'd use for glasses) that just fit along one side of the triangle.  I was able to get three base screws out this way and since I expected to need to do this again in the future, I used my dremel to grind a larger flat-headed screwdriver slot in each.  It's been about a year and a half since I fixed it last time and this time I was glad I had the slots.
Once you get the plastic base off, you'll see the mechanics of the switch.  There are two wires that both turn on the light and power the heater element.  Where the wires connect to the switch mechanism, there are two metal tabs that stick out in opposite directions from the center.  When the switch is pushed down, you can see these two tabs move.  They are each moving to touch a contact and complete the electrical circuit.  My problem was they were not making a good contact.  The contacts are hidden behind the tabs.  All I had to do was bend the contacts one millimeter closer (i.e. as little as possible) so that they would make a good contact.  The only other trick was I had to remove the switch mechanism from the bottom of the kettle to do this.  Then I just used the same small flat-headed screwdriver to bend the contact as in the picture below.
Nov 11, 2006 | Cuisinart KUA-17 Cordless Electric Kettle
Sunbeam 5965 Electric Kettle Logo
157 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
