Question about Water Tech Pool Buster Pool Cleaner
I have a Blue Diamond Robotic Pool Cleaner that only runs for about one minute and shuts down. I've emptied the filter bag but this did not solve the problem.
    Top Expert:
  • Water Tech Master
  • 8,143 Answers
Bad motor
Posted on Oct 03, 2017
I want a pool cleaner WITH NO HAMMERHEAD They are useless after every leaf they stop THanks Eva
If it's a leafy pool try a robotic cleaner with a bag. Dolphin or similar. They run for three hours then turn off
Jan 04, 2017 | Pool & Spa
How do you clean the filter on aquabot
I have a small stream nozzle on my hose that puts out a good but of pressure. I turn the filter bag inside out and spray it til it's white. I then turn it back in and spray water from the inside out. The bag is also machine washable if it still isn't clean.
Jun 18, 2014 | Aquabot Pool Rover Above Ground Robotic...
It immediately shuts off after I press the "on " button!!
The power converter is bad and needs to be replaced. Check and see what warranty the manufacture might supply. ( I deal with this all summer long at our store)
Mar 25, 2014 | Water Tech Blue Diamond Pro Robotic Pool...
Will not clean shallow end of pool heads directly to deep end
Make sure that the Floating Handle is locked diagonally across the top of your Aquabot's body.
Clean the Filter Bag thoroughly so that the fine particles of dirt that get trapped within the fibers of the
Filter Bag are removed. To test if the Filter Bag is inhibiting the
Aquabot's performance simply remove the Filter Bag and operate the cleaner without it. If the Aquabot then pumps
water strongly, and climbs the walls properly, the Bag most likely requires a thorough cleaning
Sep 12, 2011 | Aquabot In - Ground Robotic Pool Cleaner
My robokleen vac runs for a few minutes then just stops. I checked the wheels nothing is stuck in there. Any suggestions?
With these pool cleaners, there are several things that you should check. Make sure that your filter bag is not full and does not have any large debris that would hinder movement. Make sure that your impeller is not jammed or broken and check the entire drive system for objects that might have become lodged.
Aug 25, 2010 | Smartpool Dolphin Robo - Kleen Above...
Doesn't run
With these automatic pool cleaners, you can usually do some basic maintenance to get it to move. First, check to make sure that the cable is completely uncoiled and is not restricting flow. Next, make sure that the filter bag is clean and the impellers are not blocked. Finally, make sure that the axle bearings of the front and rear wheels are clear of debris/leaves.
Jun 16, 2010 | Smartpool Dolphin Robo - Kleen Above...
Robo Kleen pool cleaner troublshootong
One thing that you might want to try on these pool cleaners is removing the limit screw on the axle for greater angle of tandem wheels. Make sure your filter bag is not clogged or partially clogged because this cause restrict movement. Check for debris jammed in your drive system (wheels, axles, etc.)
Aug 16, 2009 | Smartpool Pool Hog Ig Robotic Automatic In...
Pool cleaner Won't move
For these automatic pool cleaners, make sure that the filter bags are clean and free of obstructions. Check your impeller. Sometimes hair and other materials can get caught in the impeller and can cause the unit not to move. Finally, make sure that you are getting adequate pressure from your return lines.
Jul 30, 2009 | Smartpool Dolphin Robo - Kleen Above...
Water Tech Pool Buster Pool Cleaner Logo
296 people viewed this question
Top Water Tech Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Water Tech Pool and Spa Expert? Answer questions, earn points and help others
