Question about XO Vision GX1211 XOVision 12" Roof Mount TFT LCD Monitor
How to wire an lcd tv roof mount ? it is a eiger vision brand, model evp-104FL, the color of wires are, orange, red, black, white, yellow and 2 thicker white wires w/ inner wire inside. first white wire has green inner wire and second white wire has blue inner wire. (I'm thinking these 2 white wires are the input/output but not sure)
4 Suggested Answers
SOURCE: wiring diagram
getting no singnal to my back monitor
Posted on Apr 13, 2008
SOURCE: installation of a XO vision GX6103
can you send me the instructions
Posted on Oct 16, 2008
SOURCE: EVP 1048 D sound issue/no response from Eiger Vision
Called the manufacturer
Posted on Feb 12, 2009
Color diagram for a clarion radio
If this is a factory radio - the year would be required.
However just before 2000 model year... and for a couple years after - the following wiring colors are prettymuch constant....
Constant 12V+ Red/White Switched 12V+ Red/Yellow Ground Black Illumination Green/Red Dimmer Red/Yellow Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Blue Left Front (-) Yellow Right Front (+) Green Right Front (-) Gray Rear Speakers 4" Roof Mount Left Rear (+) Orange Left Rear (-) White Right Rear (+) Orange/Blue Right Rear (-) Orange/White
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 07, 2010 | Clarion Car Audio & Video
Tip
How to measure Voltage in Transforme for Fitness Treadmill
Transformer Test Procedure:1). Make sure that transformer wire connections (CON1) to the drive board are secured. Turn unit on.2). Put multimeter to the AC voltage setting. Insert meter probes into the transformer primary (red)wires as shown. Normal reading: 110V. This shows that there is power to the transformer.3). Test transformer output by probing on secondary (output) wires: black and black, white and white,orange and orange, yellow and yellow
Transformer Test Results :1). If there is no voltage across the primary (red) wires, inspect F1 fuse on the drive board and power to the drive board. 2). If there is voltage across primary wires but none across secondary wires, the transformer is bad.Replace it.
Transformer Wire Colors Normal Voltage Value:
Red and Red 110 VAC.
Black and Black 11-13 VAC
White and White 11-13 VAC
Orange and Orange 27-29 VAC
Yellow and Yellow 10-12 VAC
on Oct 26, 2011 | Exercise & Fitness
Tip
How to measure Voltage in Transformer for Fitness Treadmill
Transformer Test Procedure 1). Make sure that transformer wire connections (CON1) to the drive board are secured. Turn unit on.2). Put multimeter to the AC voltage setting. Insert meter probes into the transformer primary (red)wires as shown. Normal reading: 110V. This shows that there is power to the transformer.3). Test transformer output by probing on secondary (output) wires: black and black, white and white,orange and orange, yellow and yellow.
Transformer Test Results:1). If there is no voltage across the primary (red) wires, inspect F1 fuse on the drive board and powerto the drive board.2). If there is voltage across primary wires but none across secondary wires, the transformer is bad.Replace it.
ValueRed and Red 110 VAC
.png
ERNESTO CUADRA
MANAGUA, NICARAGUA. C.A.
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
Need a wiring diagram for the audio system in a 2002 Holden tf Rodeo???
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Red/Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Yellow
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Gray
Car Audio Rear Speakers Size: 4′
Car Audio Rear Speakers Location: Roof Mount
Left Rear Speaker Positive Wire (+): Orange
Left Rear Speaker Negative Wire (-): White
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Orange/White
should be the one
Oct 21, 2009 | 2002 Isuzu Rodeo
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
1996 eagle vision radio wiring
1996 Eagle Vision Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Black/Yellow
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Light Blue
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Pink
Car Stereo Antenna Trigger Wire: Orange/Red
Car Audio Front Speakers Size: 3 1/2′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 23, 2009 | 1996 Eagle Talon
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Need help with wiring a pioneer deh-5
You do not have the entire Pioneer model number listed, so I cannot provide you with the wiring info for it.
Bu here is the wiring info for your jeep.
Constant 12V+ Pink/Yellow  Switched 12V+ Red/White  Ground Black  Illumination Orange/Brown  Dimmer Black/Light Blue  Antenna Right Front  Front Speakers 6 1/2" Doors Left Front (+) Dark Green  Left Front (-) Brown/Red  Right Front (+) Purple  Right Front (-) Dark Blue/Red  Rear Speakers 5 1/4" Roof Mount Left Rear (+) Brown/Yellow  Left Rear (-) Brown/Light Blue  Right Rear (+) Dark Blue/White  Right Rear (-) Dark Blue/Orange **from the12volt.com
Best of Luck.
Oct 31, 2007 | Alpine CDM-7874 CD Player
Car Audio & Video Logo
81 people viewed this question
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
