Question about Kenmore Refrigerators
Kenmore Model 63111: older unit not used in some time. When plugged in (set on 3), I accidentally pressed defrost button. I notices an oily substance leaking from freezer coil... plus refrigerator did not cool. I didn't hear the motor starting either. Light did come on.
  • 958 Answers
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
Posted on Jun 25, 2008
SOURCE: Kenmore 20 porcelain plus refrigerator
5' 6" Tall
32 1/2" Wide
28" Deep
I bought that old fridge at a garage sale for cheap. It's been enjoyed for me for just over a year. :)
Posted on Aug 21, 2008
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
  • 1218 Answers
SOURCE: Have just been experiecingetal or
Good day,
Unusual problem. It's possible that the dual water valve in the bottom back of the machine is at fault, but only a guess. Changing it may be your first option.
I would also check where your water supply line is tapped into the house supply.
If it's a horizontal line, and the tap in is done on the bottom of the line. I would reinstall the tap in to the 3 or 9 o'clock position or the top if that's possible.
As well, if no luck, I would consider calling your water dept. and have them check for possible water contamination.
Posted on Nov 26, 2009
  • 2180 Answers
SOURCE: defrost heater does not cycle on
you didn't send the full model number,starts with 110.or similar,you have a defrost problem,it could be a couple of things so you need to read out some parts with a meter,you could have a bad defrost thermostat the timer or adaptive defrost board depending on model number,bad heater,if it has a timer you need to advance it by turning the middle with a screw driver until you hear a click and the fan shuts off in the freezer,now you have it in defrost,see if the heater is on,if it is you have abad timer,if it didn't come on check the t stat,if it has plug in connectors on the wires disconnect the t stat and plug the wire derectly to the heater or if you have to cut the wires cut them and bypass the thermostat,if the heater comes on then you know you have a bad t stat,also pull the wires off the heater and check the heater,if the heater is bad it's a good idea to change out the t stat anyway,if it has an adaptive defrost board check the tech sheet that should be behind or on the bottom kick plate,remove it and look it will tell you how to put the fridge into defrost,i think you push in the both door switches 5 times at the same time,if it doesn't go into defrost could be the board,you'll have to still read out the heater with a meter,also if you read out the thermostat it has to be cold,if it warms up it will read open but it still could be good,if you need any more help with this let me know and send model number so i can help better
Posted on Feb 19, 2010
Testimonial: "Would have helped to know where these controls are located. The refiderator is located in a close area and hard to move. The model begins with 106."
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
Washer kenmore elite washer model 417.41102000 displays LOC and won't turn on. how to reset and unlock the controls?
Control Lock (Press & Hold) To lock the controls between or during cycles, press and hold the Add Steam button for 5 seconds. ' will be displayed if you attempt to wake up a "between cycle" locked unit and ' will alternate with cycle time remaining in a "during cycle" locked unit. Repeat to unlock the controls when you are ready to operate the washer. Use this feature to reduce the likelihood of accidental operation by children. 41741102000 KENMORE ELITE WASHER Manual Sears PartsDirect
Hope this helps?
Mar 29, 2016 | Kenmore Washing Machines
Samsung RB215LABP ice in bottom of fridge but freezer won't get over 35
Step 1:
You almost certainly have a defrost issue with this unit. Your best bet with a Samsung is to call a qualified service tech to complete your repair. If you want to try it yourself here is what you would need to do to test this unit. If your unit is not defrosting it can not circulate the air and will cause the unit to warm up.
Step 2:
Unplug the unit and remove the back cover on the unit where the compressor is and you will see a white box on the right hand side. Remove the screws holding that box in and pull it out and open it up, that is your main pcb for this unit and all tests will be done from here.
Step 3:
Using a multimeter set to Ohms for measurements unplug the connector on CN70 (pnk, skyblu, org, wht, brn) and on the plug check for continuity from the white wire to the orange wire (Refrigerator Defrost Heater) and from the Brown wire to the orange wire (Freezer Defrost Heater) if either of those show open then that is your problem, replace the heater.
Step 4:
Plug CN70 back in and the plug the fridge back in. Using needle leads on your multimeter set to DC volts check for power on CN30 from Orange wire to the Brown wire (do not unplug the CN30 connector) your voltage should be from 2.3v - 4.2vdc (freezer defrost sensor). Also check the purple to the brown wire 2v - 4.2vdp (Refrigerator defrost sensor). If you are outside of that then you would need to replace that sensor.
Step 5:
If the above steps check good then you will need to put the unit into defrost and check for power at the heater. To put the unit into defrost, from the user interface panel on the front of the unit press the power freeze and power cool buttons simultaneously for 8-12 seconds until the display quits blinking. Press the the freezer button 3 times (wait 5 seconds between button pushes) to force the unit into defrost.
Step 6:
Go back to the main pcb and using your multimeter set to VAC check for power at White and Orange (refrigerator defrost heater) should be 110-120vac. Also check from brown and orange (freezer defrost heater) should be 110-120vac. If you do not have power then you have a bad main pcb.
Mar 25, 2013 | Samsung Refrigerators
I have been using a Sunbeam Model 5891 Breadmaker for over a year without trouble. Today I loaded the machine like always and selected the settings I usually set and hit go. Nothing happened. The lights...
The Sunbeam 5891 is a disposable type for there are no user-servicable parts.
Here's more:
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 17, 2011 | Sunbeam 5891 Bread Maker
Why do I need to defrost every week?
Hi and welcome to FixYa, I am Kelly. I had to do a reverse lookup of your model number and think I am close with this model number: 106.72102100 and can be found using the www.searspartsdirect.com website. Your defrost timer is item 4 of this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10672102100/0582/0166000/P0109056/00002?blt=06&prst=&shdMod=
detailed view:
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/482493/0046/106/Model-10672102100/0582/0166000?keySuffixId=NA&productTypeId=x&searchModelNumber=10672102100&subCompDesc=Liner&brandDesc=KENMORE&modelDesc=TOP-MOUNT-REFRIGERATOR&blt=11
It should automatically cycle your refrigerator into the defrost mode as often as 3 times a day. When the defrost timer or the defrost element (item 4 this link: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10672102100/0582/0166000/P0109056/00006?blt=06&prst=&shdMod=
fails you will have to do a manual defrost. In addition a failed bi-metal thermostat (item 2 same link) can also cause the unit not to cycle out of the defrost cycle once it begins.
You can manually rotate the defrost timer using the 2 tabs if you kneel down and look into the overhead of the fresh food compartment. You will see a circular hole with the inclined tabs on it. Rotating this SLOWLY until the compressor shuts off or you hear a noticable click will start the defrost cycle. (Due to the inclined tabs you can only rotate it ONE direction.) The defrost cycle should self terminate after abiut 45 minutes. If it does not self terminate that indicates a problem with one of the 3 main defrost components. Timer, element or bi-metal thermostat.
Thanks for choosing FixYa,
Kelly
Dec 30, 2010 | Kenmore 64802 Top Freezer Refrigerator
Divider between fridge and freezer is heating up a lot.
Between the freezer and fresh food compartment is where the evaporator coils are. Frost free refrigerators aren't really frost free at all. Every 12 hours or 24 hours, a timer turns on a set of heating coils in the evaporator to melt the ice on them. If your refrigerator is otherwise functioning normally (normal cooling), it could be that you simply felt the divider it when the unit was self-defrosting.
Most refrigerators go through the defrost cycle unnoticed. When the cycle starts depends on when you plug in or turn on the refrigerator. If you'd prefer to change the time of your defrost cycle, simply unplug the refrigerator for an hour or two then plug it back in. Every hour it's unplugged will delay the defrost cycle one hour. To avoid having to remove food from the refrigerator, you might want to do this over several days, but it's cumulative so each time you unplug it for whatever length of time, it further delays the defrost cycle that length of time.
Your refrigerator has no idea what time it is (unless it's an electronic model with a built-in clock), so setting its timer to self-defrost in the middle of the night is an exercise in trial-and-error.
The other alternative... That the heater is turned on all the time... Would DEFINITELY affect the cooling capacity of the refrigerator and you'd notice that WAY before you'd notice the heat coming from the freezer/refrigerator compartment wall.
Jun 27, 2009 | Kenmore Refrigerators
Freezer/kenmore
the settings usually are:
off - on - superfreeze. you just want "on"
Nov 16, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kenmore refridgerator model #50522100
Is it still working..If so it probable doesn't have a problem.My guess is that it went into the defrost cycle.When you unpluged it in 2003 it was time for the defrost cycle, so when you pluged it in it went into the cycle..
Sep 28, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore Elite Refrigerator error er dh
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 21, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Refrigerators Logo
24 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
