The bobbin is held in a removable bobbin case. If the bobbin case is already out of the machine, place the bobbin in the bobbin case such that the thread will come off clockwise. Leave a couple of inches of thread loose. Then pull the end of the thread down into the cross slot and thread it through the tension spring and into the delivery eye.
Next make sure the presser foot is up and the needle is in the highest position. Push the slide plate up. Hold the latch in the center of the bobbin case and place it over the center stud with the finger opposite the notch in the shuttle race. Release the latch in the center and press down on the bobbin case until you hear a click when the latch catches the groove. Leave a 2-3" length of thread extending out of the bobbin case and push the slide plate down. (Reverse the steps to remove the bobbin case.)
To thread the needle, place a spool on the spool pin with the needle bar fully up. I try to place the spool on the pin so that the little catch is out of the way. (The catch holds the end of the thread when the spool isn't in use.) Bring the thread through the guide loop on the top of the machine and then down through the thread guide on the right side of the tension discs. Bring the thread back up on the left side of the tension discs through the check spring and through the thread guide. Bring the thread through the hole (eye) in the take up lever (from right to left). Then bring the thread down through all of the guides down the face of the machine to the needle. Finally thread the needle from left to right. Pull a few inches of thread through the needle. (I find the threading of the needle to be easiest if the thread has been cut at an angle after threading the machine.)
The manual for the White 765 is available from Singer's support site. The direct link to the manual is
http://www.singerco.com/uploads/download/827_white-765-x.pdf . See page 6 of the manual and the subsequent pages for pictures.
I hope this helps.
