Question about Vacuums
I have a Everstar canister vac 1200 (owned for about 4 years) and the hose broke apart. I taped it together and have used it for about a year but it has failed. The telephone # in the manual no longer belongs to Everstar (if it ever did). I bought this vac from Home Depot but no longer have a receipt. Any ideas on where I'll get a new hose?
  • 7 Answers
SOURCE: pwr cord rewind reel
You have to pop the grey button off for the cord rewind. There is one more screw under there. You have to be very careful, because you can break one of the tabs that hold the button on. In fact, it is almost a garuntee. There are three tabs that stick off the button that hold it in place on the orange hood. There's a long tab about 3/4 inch long on the inside corner of the button you need to be careful of. Good luck!
Posted on Jan 09, 2008
  • 132 Answers
SOURCE: Samsung Quiet Storm 9048R hose break
OK ART THE FITTING THAT CONNECTS TO THE HOSE SHOULD HAVE TWO SMALL SQUARE HOLES OPPOSITE EACH OTHER YOU NEED TO PUSH TWO FLAT HEAD SCREW DRIVERS IN AT SAME TIME TO RELEASE THE SECTION THAT THE HOSE SCREWS INTO POP THIS APART THEN REMOVE THE SMALL PIECE OF BROKEN HOSE AND SCEW HOSE BACK ON REPLACE INTO FITTING SO THE SQUARES POP BACK INTO PLACE AND START VACUUMING HOPE THIS HELPS GLENN PS ANY VACUUM SPECIALIST WOULD BE ABLE TO HELP WITH THIS SMALL PROBLEM IF YOU WANT TO MEET ONLINE ABOUT THIS I WOULD BE MORE THAN HAPPY TO ASSIST
Posted on Nov 15, 2008
  • 55 Answers
SOURCE: canister will not release
I've done that.
There is a stem that runs down the center of the cyclone that releases the bottom. You didn't get that stem back in place. The only thing you can do is pry it open, hope is doesn't break, and put that cyclone back together correctly.
I've never broke one, but I had to pull pretty hard. Thought I was going to.
Good Luck
Posted on Nov 26, 2008
  • 134 Answers
SOURCE: troubleshoot a problem with central vac - not in the vac hose
The only thing you can use really is a plumbers snake.
Not sure if thats what its called in the States. Its a long flexible metal spiral spring that plumbers use to clear blocked drains
Rob in the UK
Posted on Mar 07, 2009
CorvetteKing
  • 108 Answers
SOURCE: Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Posted on Jun 05, 2009
How to put back togeather a electrolux el6989
Did you take it apart, or did somebody else? Those can be tricky. Take it to your local vac shop and have it assembled. I've been working on vacs for nearly 30 years and I can tell you, that is one of the worst ones to get together.
Feb 18, 2015 | Electrolux EL6989A Bagged Canister Vacuum
DYSON DC 17 CLIP THAT HOLDS CANISTER BROKE
some options for this are craigslist, search >dyson>broken>vaccuum>DC 07
Options 2> we used duck tape for a year and it worked fine, then when a broken DC07 was posted on craigslist we bought it for parts.
Jan 03, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Filter queen vac 2 years old suction poor cleaned hose canister and filter
Hi, Did you change both the cone and the filter on the top lid? If so, ther may be a leak in the machine breaking the air tight vacuum. When you put it together make sure its in properly and tight. Let me know if this does not help, I will look at something else. Chris
Feb 09, 2011 | Filter Queen Majestic Canister Vacuum
It stopped working while I was using it . I tried to plugged in different electric outlets but it still dead. What should I do or look into in order to get it back to normal?? thanks
I would start by taking the wand apart. Be sure vac is unplugged from the wall outlet! You should be left with two pipe pieces, and the beater bar. I would also pull the hose from the canister unit itself. Once all the pieces are pulled apart, check the two or three prong wire connectors on each piece, both the female and male ends. If you have any dielectric grease, use a dab on each electrical connection. Once you reassemble, and still not powering up, wiggle the wand back and forth at the connection near the canister, and after the hose near where the switch is. If the vac cuts on after wiggling it, then you have a loose connection, and will need to tighten the female ends on the electrical connections, by squeezing them together slightly with a pair of pliers. Please rate if this works or does not work. Thanks!
Jan 03, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
My vaccuum cleaner is an EVERSTAR 1200. I turned it on - everything appears OK until I realize that it is not suctionning. I cleaned out the canister - made sure the vacuum was not obstructed. Still no...
First clean the filter on top of the canister, do not wet it, blow it and get all the accumulated dust out. Then check the hoses for obstruction. There should be an emergency valve on the rear part, if it is open, you better ck the hoses.
Aug 29, 2010 | Vacuums
Lost suction
TOSS IT and forget it! I have never used a hand vac that worked that was worth the effort of turning it on .... I suggest they are all junk ... I found very few vacuum cleaners ... actually **** especially anything made by dirt devil ... I do have a bagless Bissell 6579-2 that I purchased 4 years ago at walmart for $49 ... It outperforms any vacuum I've ever used, including my worthless Shop-Vac that I paid a lot more for ... this Bissell vac SUCKS ... It could **** the barnacles from a steamship!
Apr 28, 2009 | Dirt Devil Vibe AllPurpose Hand Vacuum...
I want to take the vac apart to clean around the motor ?
likely a break in your cord somewhere. if you have a ohm meter check it otherwise tale it to a vac repair shop
Oct 25, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Kenmore Cannister Vacuum Model 26312
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=109396&thid=552260
Kenmore Canister Vacuum Model 26312
Posted by Alecia Rojas on Apr 28, 2008
Kenmore 23612 Progressive PowerMate Canister Vacuum
Vacuum is not sucking. It is just over a year old.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds like you have a clogged hose or a full bag, or dirty filter. The best way to check your electric hose id to run a marble or steel ball thru the hose and if it goes thru all the way then check the bag and filter, most times it is the vacuum hose. If it id the hose you can try to pull apart the clog from both ends using another central or canister vacuum. If not and the ball stops mid way thru the hose then you can use a broom handle with a round hook on the end so that it does not puncture the hose is any place and the round hook can loosen or break up your clog and then your suction will return, if you poke a hole in the vacuum hose there are repair kits that go on the outside of the hose that will slide over the hose and then you use a heat gun and shrink the hose repair kit down to size therefore plugging the leak. (Hose repair kit). So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Princess III Vacuum
Here is a picture of the dome taken apart, not too hard, take out the 3 screws on top, then the pic should show the rest.
Nov 15, 2007 | Filter Queen Majestic Canister Vacuum
Vacuums Logo
322 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
