Question about Casio Sea-Pathfinder SPF40-1V Wrist Watch
I have a Casio 1346 module that will not start running after battery replacement. The new battery shows good on a battery tester. Any ideas on what I might be doing wrong?
4 Suggested Answers
  • 19 Answers
SOURCE: replacing the battery..
Ok Mdane
This is going to be tricky not have seen that watch before at all. BUT like most Casio's there screwed casebacks.
All you have to do is undo the 4 screws (usually) and take of the back gently remove the battery? Sometimes it has 2 small screws if you gently unwind one a few turns and the other take compleltely out and set aside. Remove the battery and take it your local battery shop (sorry from australia so I don't know where you get your batteries walmart perhaps?) and replace it in the reverse order. Sorry if its so vague I haven't seen that watch before
Hope it helps
Posted on Jul 14, 2009
SOURCE: Casio module 2273 battery change
did u ever figure out how to get the retaining clip?
Posted on Mar 13, 2010
  • 17 Answers
SOURCE: I need O-ring seal for CASIO 1346 water resistant
Bring it to a watch repairman, or into a watches/jewelery store to order it.
You also can try to order online through Casio website (Many watch company's websites only sell replacement parts through watches/jewelery stores or repairmen, not to individual.)
Posted on Feb 19, 2011
My Waveceptor time is not being updated by a radio signal. It appears that I am not receiving the radio signal. I have tried outside but still no reception. Ideas?
Probably the battery is running low. That way the radio signal reception maybe too weak. You can try to manually receive the signal.
Download the manual from the link below (the module number is on the back of the watch).
Timepieces Watches Manuals CASIO
Dec 27, 2015 | Casio Waveceptor Atomic Radio Controlled...
How do you change battery on casio 1346 module watch, I notice in back of watch there are six slot.
Harbor Freight sells a low cost watch wrench but in a Robinson Crusoe situation you can CAREFULLY use square nosed needle nose pliers(Lowes or The Home Depot won't object if you try out one of theirs); hold watch in wash cloth to protect your hand, put the square blades in the watch back indentations and slowly turn with maximum pressure, after it opens use a quality Japan Maxell SR621W silver oxide, do NOT use a China alkaline version as they leak and have less run time. Use a Q-Tip with light Vaseline around the sealing edges when reassembling. Sincerely batteryBob
Jan 02, 2013 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
I need O-ring seal for CASIO 1346 water resistant (from year 2001). Where I can bought it please?
Feb 19, 2011 | Casio Watches
Mar 13, 2010 | Casio PRG-40T-7 Pathfinder
The digital display shows the correct time but the hands do not.
hi there when you replace batteries in wave ceptors all hands have to be set to the home position (straight up at 12 oclock), as the instructions vary wildly from watch to watch you will have to download the manual from www.casio.co.uk you will need to put in the module number (found on the back plate of the watch), this will be in PDF format, you can download adobe reader for free from www.adobe.com to read PDF files. good luck
Aug 20, 2009 | Casio WVA105HDA Wave Ceptor watch
After battery replacement of casio sea-pathfinder
If it has "AC" written on the module you may need to short between the AC point and + battery. Also check voltage of battery. It may just be too flat.
Jul 25, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Battery replacement
You can do it yourself. Unscrew watch caseback and undo the contact on top of battery. Read the writings on battery and buy exactly the same one. Do not mind manufacturers (Casio, Maxell, e.t.c.), just make sure the numbers are the same.
Some watch casebacks can be opened only if the watch band is removed, so, remove it if needed, just don't forget to memorize where every part and screw was fitted. Memorize how the battery is fitted and do not put the new one the other way around as this can damage your watch.
Actually there is nothing difficult - only you have to put everything back exactly the same way as it was. If your watch will be left without battery for more than 3 minutes, you will need to reset your watch after replacing a new battery, but it's easy if you've got users manual.
Good luck.
Do not forget to rate, please.
Mar 11, 2009 | Casio PRG-40T-7 Pathfinder
Casio 4305 runs 5 minutes slow.
No reason to panic as your watch hands can be advanced to desired time. Her is the link for your watch users manual download:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4305&submit.x=52&submit.y=12
Save it on your PC and follow instructions how to set the time.
Don't forget to rate, please.
Jan 05, 2009 | Watches
Casio Sea-Pathfinder SPF40-1V Wrist Watch Logo
206 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
