Question about Mitsubishi WD-57734 57" HDTV
I recently replaced the lamp - part # 915P061010. But the TV powers off about every 20 - 30 minutes / red status lamp is illuminated. At times the TV will remain on for hours. But eventually the TV powers down again / red status lamp is illuminated.
    Sergeant:
  • 171 Answers
It looks like your ballast board is going bad, this is a common problem for DLP TV's the ballast board is the power source to the lamp and if for any reason this board does not send enough energy to the lamp it will turn off, It looks like your ballast it starting to get weak it gathers enough energy to turn on but gets weak again and turn back off you have a new lamp and it requires for the ballast to be working at it's full potential
Posted on Sep 13, 2010
Testimonial: "Makes sense. Thank you."
DLP powers down after 1 minute; no sound or audio
REPLACE LAMP IF PERSISTENT REPLACE THE LIGHT ENGINE COS THE COLOR WHEEL IS WORN OUT
Jul 07, 2013 | Televison & Video
Lamp 915p061010
You can get that replacement lamp along with free installation instructions from www.tvrepairworld.com under the Mitsubishi DLP lamp catagory.
Oct 26, 2012 | Mitsubishi 915p061010 Tv Lamp 915p061010
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
Black screen no picture and red lamp lites on
Hi,Is your tv close to 3000-4000 hrs 1-2yrs.If
its it might be time to replace the lamp.Your
part # is 915P061010 Make sure you get the
Philips lamp because it last longer 6000-8000 hrs.There's other components that
tend to go bad like the ballast which is the
board that powers the lamp.When that is
bad it will make continuous clicking noises
or attempts to light up the lamp.But if you
dont hear any of that then most likely its just
the lamp that needs to be replaced.Have a
blessed one!
Feb 19, 2010 | Mitsubishi WD-65733 65" HDTV
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi 57734 shuts off occasionally
Hi,if your tv is between 1yr-2yrs maybe its time to replace the lamp.This will be the part # 915P061010 you can find it on discount-merchant with the Philips lamp which last longer 2-4 yrs 6000-8000 hrs.
Sep 24, 2009 | Mitsubishi WD-57734 57" HDTV
I have a LG RU-44SZ61D DLP TV and recently replaced the bulb. After about two months the TV went really dim and then started shutting off. The problem increased to the point where you couldnt have the tv...
DLPs have flow chart trouble shooting techniques to pinpoint exactly why your set isnt completeing the boot sequence. If you would like the service manual for your model let me know and i will post a link where you can purchase a complete one.
Apr 06, 2008 | Televison & Video
Mitsubishi WD-57734 57" HDTV Logo
852 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
