Question about Amana Dryers
Amana dryer nde2330ayw loud squeal. Been happening for a while
  • Amana Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical consol with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Sep 13, 2010
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: I have an Amana NDE2330AYW dryer. It squeaks
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS If your a Handyman then this will be no problem to you. Your problem sounds like drum rollers have flat spots on them or in need of lubrication. If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Jan 05, 2010
Yes and a pretty big job.. but look on the back to see if there is a panel around your vent that comes off this would be much easier
Aug 19, 2013 | Dryers
Amana CLOTHES dryer squealing and squeaking
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 25, 2011 | Amana Dryers
Have an old Amana dryer Model # LE3402w - hasn't been used in a while. Heats up great but makes a awful loud noise while on. What can be the problem
The belt tensioner pulleys bearing is dried up squealing while turning. My advice is to replace the belt & the pulley on the tensioner
The top and front panel will have to be removed to access these parts
Jul 16, 2010 | Amana Dryers
The problem I am having with my Amana model NED7800AYW makes a loud noise when running
heatman101
fgs453q2
May 15, 2010 | Amana NDE7800AY Electric Dryer
My dryer is squealing very loud when it is on.
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 07, 2010 | Frigidaire Dryers
Jan 04, 2010 | Amana NDE2330AY Electric Dryer
My Amanda NDE2330AYW dryer makes a terrible loud screeching sound through most of its drying cycle. My wife read somewhere that if the belt is causing trouble, some soap applied to the belt can provide a...
Call the company or a parts warehouse that sells replacement parts in your city for washers and dryers. You need to buy some replacement sliders. You can try googling this as well they are a small inexpensive part and can be installed very quickly.
Dec 03, 2009 | Amana Dryers
Squealing dryer
The dryer drum support on the rear of the drum is worn and must be replaced.
It is a ball and cup design. It is worn out.
Feb 21, 2009 | Frigidaire GLER341A Electric Dryer
Dryers Logo
217 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
