Question about GE AGL10 Air Conditioner
Fan from my air conditioner start work noisy looks like same thing touch
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 251 Answers
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
How do i fix a noisy indoor unit fan motor
I have a 40 year old Sears fractional HP dehumidifier that gets noisy from time to time and I solve this by applying some oil to the motor shaft next to the bearings on the motor. The other possibility is the fan blades may be slightly touching something.
Sep 20, 2016 | grunaire GSI091HXB / GSU091HXB 9,000 BTU...
Kenwood KW85 is noisy
Hi, have you tried moving it to somewhere else as it can be noisy depending on what type of surface its on, as this can cause it to vibrate
May 14, 2008 | Kenwood KW85 Air Conditioner
NOISY BLOWER FAN
bearings bad in fan motor
Apr 15, 2014 | Coleman Mach III Air Conditioner
Noisy fan
Either a defective bearing, loose fan motor, fan motor mounts, broken fan impeller, or debris. Could be rubbing against something. Remove the cover and take a look.
Aug 20, 2013 | LG LP0910WNR Air Conditioner
Air Conditioner fan problem. AC fan very noisy and doesn't blow with full power
bushing in motor is probably shot,or some critter put it's nest in there ,either way the motor has to come out.
Jan 11, 2012 | 2003 Chevrolet Malibu
My sharp comfort touch air conditioning 12,000 BTU FS-S125FX-A does not cool any more. It's running but at room temp.
Can work the external drive and you see that turns the fan but look at the compressor he works; logically not working if the fan brings the temperature domatiou.antikatestise external capacitor again if the air conditioner does not work then the compressor is stuck.
Aug 07, 2011 | Sharp Comfort Touch AF-R120EX Air...
A have a vaillant ecotec boiler and when it fires up the fan is very noisy is this right
most likely no. there might be a obstruction in the blades, dirty filter, the motor might have a bad berring , the fan blades might have bent and now are touching the housing prob should call a trained tech boilers aint no joke
Aug 06, 2011 | Heating & Cooling
My three year old Frigedaire window air conditioner is noisier and not cooling like it did before.
A noisy Air Conditioner is caused by a few things.
1. The most common failure is the blower fan hub has cracked and the blower wheel is dragging on the internal chassis area. You will have a very low air flow and lots of noise.
2. The evaporator coils are clogged with dirt. An air-conditioner that is used around the clock should be thoroughly cleaned every 90 days.
3. The condenser coils are clogged in the back of the unit on the inside.
4. Dirt has caked up on the fan blades and the motor is now driving both the blower fan and the condenser fan in an out of balance condition due to the dirt build up.
These are all things that cause a noisy air-conditioner.
If you need more assistance after this just respond here.
Thanks for using FixYa.
Kelly
May 20, 2010 | Heating & Cooling
Window type condura aircon noisy
check fan or blower is unbalancedor touch the frame or fan motor bearings or sleeves defective.
Aug 28, 2009 | Carrier 52CE-307-3 Air Conditioner
GE AGL10 Air Conditioner Logo
75 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
