Question about Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD Television
How do I change the lamp in my Sharp 45 inch LC45gx6u TV?
  • Sharp Master
  • 736 Answers
This television doesn't have lamps to change. Perhaps you need a Backlight Inverter/Inverter Board? If you aren't sure what exactly the television needs it would have to be evaluated. The television would have to be serviced by someone familiar with the boards/parts to ensure the actual problem is corrected if correction is possible.
Posted on Sep 13, 2010
LC45gx6u power wont stay on turns off
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 21, 2015 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
I have a sharp 32 inch and the green flashes and when i hold down the input and channel down it shows red then i push down the power button hold it goes orange then green it comes on then shuts back off
You don't want to keep doing that because you can make it go into a coma and not turn back on again. It may not work to perform a factory reset INIT (industry initialization) but call sharp aquos 877-322-7867 (87seeaquos) to get a case file created and be walked through an INIT including resetting the lamp errors. If the rep has you read the number of lamp errors and it is not zero then you should be scrolling down and resetting them to zero before changing screens to turn INIT on.
Sep 29, 2011 | Sharp Aquos LC-C3234U 32 in. LCD TV
Sharp aquos 45 inch tv power light blinking
Please let me know if you can get any sound at all out of your unit.
solution
I had a similar problem. I had a 52" RCArear projection tv. It would do this when I initially turned on the television, but then after a few "on/off, on/off, on/off" cycles it would stay on. Eventually it started doing it more; until finally there was a spark and that was it. The tv was dead.The bloggers called it "the blinking green light of death" (because of green light on the panel).The power board is going out.ALSO holding down the Input and Menu buttons afterward will give you some diagnostic information via 2 sets of blinking indicator lights.
You may very well have issues with capacitors on this set being that it is or very similar to the V26 chassis. Since I have spare test lamps laying around, I would normally try that first. If the lamp still would not stay lit, I would then suspect the electrical chassis (capacitors). When I suspect the chassis, I can usually verify it by pulling it out and partially disassemble it and find blown capacitors
Jan 12, 2011 | Televison & Video
Need a lamp bulb for Sharp 65 inch tv
You could buy it from :-
http://www.purelandsupply.com/56DR650-Bulb-Sharp-TV-Replacement-Bulb.html
Good Luck!!
Thanks!!
Aug 17, 2010 | Sharp 56DR650 56" Rear Projection HDTV
My sony wea lcd 60 inch television goes blank with no sound every 5 minutes or so for about 30 to 45 seconds then the picture and sound come back the set is just over 3 years old
Symptom shows TV needs new lamp and existing lamp is getting weak / dying.
Replace lamp in TV and procedure is written in user manual.
Let me know model number of TV if you need user manual copy.
Thanks.
Oct 02, 2009 | Sony Televison & Video
My sharp tv displays 'please wait' but no picture. and my source input display menu will not come up. model sharp acquos 32 inch.
You will have to replace DIGITAL PCB ASSEMBLY to correct the problem, I assume, that your TV is lc32d40u?
Sep 26, 2009 | Sharp AQUOS LC-45D40U 45 in. LCD...
Green light is on but screen is black
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp 68 inch tv will not turn on
If the tv has never had a lamp put in it, that is the first place I would go. You can refernce your owner's mainual to find the exact location, but usually the lamp has easy access so that you can check it quickly. If the lamp is OK, the ballast is probably an issue. I hope this helps. Check you lamp first
Dec 07, 2008 | Televison & Video
65 inch Sharp DLP TV
You likely just have a bad lamp. It is possible the light engine itself is causing the problem but the easiest way to determine which one is giving the problem is to replace the lamp. If the problem still persists the light engine is likely bad. The light engine is about $1000 plus installation. The lamp is $349.
Feb 08, 2008 | Sharp 65DR650 65" Rear Projection...
Have a 56 inch projection tv nothing happens....
Most likely the lamp is defective and see your owners manual for lamp replacement instuctions.
Jan 12, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD Television Logo
177 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
