Question about Sportline 345 Electronic Pedometer
I have a pedometer 345 Sportline and I need assistance to reset it using the reset, set and mode key. Thanks for the help EHR
EXPLANATION OF BUTTON FUNCTIONS:
BUTTON A – RESET:
This button has three functions:
1. To change from miles to kilometers measurements.
2. To reset pedometer back to zero in STEP, DISTANCE or CALORIE modes.
3. To increase hours in CLOCK setting mode.
BUTTON B – SET: Used for setting stride length, weight, and time of day. Also used to increase minutes in CLOCK setting mode.
BUTTON C – MODE: Allows you to choose the MODE you want in the sequence of STEP, DISTANCE, CALORIE and CLOCK
Click on the link view the Pedometer 345 Sportline owners manual
http://www.sportline.com/manuals/345.pdf
Posted on Sep 13, 2010
I have a new sportline belt clip pedometer. It has 3 buttons: mode,set and r/s. How can the length of stride be entered into it so an accurate mileage reading is possible?
I have an older Sportline pedometer with the same three button arrangement.
My pedometer is set as follows:
First press Mode to get the unit in the Distance mode. Note if the unit is in Kilometers or Miles. (Press and hold Reset for 5 seconds to switch the setting. This will reset the entire pedometer.) Press and hold Set for 2 seconds. The current (or default) step length will appear and flash. Press Set repeatedly until your step length is displayed. It changes by 1" or 1 cm at a time. Then release the Set button. (The pedometer will return to the normal operating mode if you do not press a button for 5 seconds.) When you reach the maximum step length, the unit will advance to the lowest step lenght when you press Set again. Since my step length is actually not a whole number, I rounded down.
A different Sportline step and distance pedometer (the 340) is set slightly differently. To switch from Miles to Kilometers, press and hold Mode when in the Step mode. Then switch to the distance mode and press and hold Set until the step length flashes. Press Reset to advance the current step length by 1" or 2 cm. Then release the button when you have the correct step length displayed. The pedometer will return to the normal mode after 5 seconds with no button presses.
Many Sportline pedometer manuals are available from the company's web site on the product site: http://www.sportline.com . You can look up the model number.
If you add your Sportline pedometer model, I'll be glad to give the specific setting procedure for you.
I hope this helps.
(on her third Sportline pedometer, two had the plastic spring clip fail. They all had similar programming details.)
Aug 18, 2011 | Sportline step and distance Pedometer New...
How do i set the stride for the sportline 2007 model 4202
5. Press MODE button to reach the MILE MODE.
6. In MILE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these
5 seconds, you will have to start step 3 over again.
7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will
increase continuously. Release when the display shows the Stride Length for you.
8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to MILE MODE.
Sep 20, 2010 | Accufitness SportLine Electronic Pedometer...
Set time and date on a sportline 240
Do you mean the 240 Econosport sports watch (stop watch)? The manual is available for download here: http://www.sportline.com/product.php?prod=26
To set the date and time, press the center button (Mode) on the top three times. Press the left button (Split/Reset) to select seconds, minutes, hour, day, month or date. Use the right button (Start/Stop) to change the value of each selection. Hold the Start/Stop button to change the value rapidly. (When changing the seconds, you will only be able to set the value to 00.)
Press the Mode button to return to the Time Display.
I hope this helps.
Jul 04, 2010 | Sportline 345 Electronic Pedometer
User manual for sportline 342 pedometer
The manual for the Sportline 342 pedometer is available here: http://www.sportline.com/product.php?prod=12 . Click on Manual.
The 345 manual is at http://www.sportline.com/product.php?prod=15
I hope this helps.
Jun 15, 2010 | Sportline 345 Electronic Pedometer
I have a sportline 345 pedometer. I replaced the
I was looking for instructions for a different model when I found the instructions for the 347 here: http://www.sportline.com/manuals/345.pdf
Aug 07, 2009 | Sportline 345 Electronic Pedometer
Pedometer # 4202
The Sportline 4202 has three buttons, Top MODE, Right S/R (RESUME/STOP), Left SET.
MODE - press once to alternate between Steps (how many steps you taken) and Miles (how many miles walked).
S/R - Clears the count to 0 for any mode by pressing one second. To change from Kilometers to Miles or Back Press S/R for 6 seconds.
R/S press one sec and then press SET one second to set "goals" for both steps and miles.
To change length of stride: press the buttons one at a time in the following order- R/S-SET-MODE.
It may take several attempt to get into the set stride and it may take you into other menus such as Goals in the process, just keep going in circles until you get to stride and change length with R/S and set with SET.
Feb 22, 2009 | Sportline 345 Electronic Pedometer
Reset distance mode in miles/not km
to change from km to miles or from miles to km... press and hold the reset button for (at least) 5 seconds (while in the distance mode.) This will reset your already walked info.
Jan 12, 2009 | Sportline 345 Electronic Pedometer
Sportline 345 Electronic Pedometer Logo
210 people viewed this question
Top Sportline Sport & Outdoor - Others Experts
Are you a Sportline Sport and Outdoor - Other Expert? Answer questions, earn points and help others
