Question about Motorola AP-5131 802.11a/b/g Wireless Access Point
I have 2 AP5131 AP's on the same network with different IP's. I have been told they need to have separate "channels" in order for the hand held scanners to be used with them. How can I change "channels" on one of them?
    Problem Solver:
Go to http:\\ip-adres-of AP5131
wait for login (java must be on your computer; otherwise click on link and install)
enter username : admin
enter password: ????
go to: Network configuraion => Wireless=>Radio configuration=>
and select a chanel.
Make sure when both AP's are to function on one network (+roaming) the channels on both should be different (f.i. choose channel 3 & 6). SSID and key;s should be the same
Make sure to save the changes on the AP.
Posted on Aug 24, 2011
Configuring NetGear N750 for Seperate Network
I recommend separate channels and different SSIDs for each router. Connect each device to each router you wish. Same channels with same SSIDs will create interference, your devices will not know which router to connect. Set up each router with a unique SSID and if you need a device to connect to both routers, ensure it connect to only one at a time.
Jun 13, 2013 | NetGear N750 Wireless Dual Band Gigabit...
I can't access the configuration page. I've tried everything: disable the firewall, ping the IP 192.168.1.245 with no answer, when i run the command ipconfig, it doen't show the default gateway of te AP....
If it is not showing as the gateway on an ipconfig then the router is not, for some reason, handing out IP. Have you tried resetting the router and if so, are you plugged directly into one of the 4 port LAN's in the back. You may have a bad router or may just need to flash it with some firmware. Is your IP in IPCONFIG a DHCP (192.168), or is it windows internal (169.254) If not 192.168 then you just very well may have an adapter problem. There are so many variables to diagnose on different levels of networking, but it appears that you have enough knowledge to figure this out. Also....try to hard wire a different computer to diagnose an adapter problem with the one you are using.
Jan 25, 2011 | Cisco WAP200 802.11b/g Wireless Access...
How do i connect my symbol ap-5131 to my computer?
exist 2 ways to do it...
first if you now te ip address and the user and password of admin, conect the ap at the ethernet port of you pc and configure it with a ip in the same range that the ap, put the ip direcction in the web browser.
the second way is conect the ap to the serial port and run the hyperterminal if you have windows, maybe you need configure the values of the conecctions.
Sep 15, 2009 | Symbol AP-5131
Wirless connection wont connect to network.
On the WLAN world, exist a encryption key for connection. You will be able to see the "antenna", but until you enter the key you will not be able to access the network or the internet. First, disable the wireless security and try. Once you have verified the connection to internet then you add security. Use WEP.
Jul 06, 2009 | NetGear WG602 802.11g/b Wireless Access...
Cant get accesss to the configuration window
In order to get to the AP, and assuming you just plugged it in, you need to put everything in the 192.168.0.x domain. The AP defaults to 192.168.0.50, so you need to make sure that the router gives out IP addresses that does not include 0.50, or change the IP address of the AP. Likewise, the computer you are trying to log into the AP needs to start in the 192.168.0.x domain, with x being anything but the gateway address (normally 1), or 50.
My guess is you have a router built into the modem and it is giving out different addresses. You can set your network address by hand to be 192.168.0.pick a number like 5 and plug into the ethernet port of the AP (may need a crossover) to get to it.
Post back and let us know what you found.
Carl
May 15, 2009 | D-Link Air DWL 700AP (DWL-700AP) 802.11b...
Self-assigned IP address and may not be able to connect to the Internet
if its a wireless network it assigns yyou an ip immediately solong as you are not connecting directly so dont bother about the ip just connect and see what happens.
Oct 27, 2008 | Lucent ORiNOCO AP-500 (8485878380)
Creating MESH on AP5131
you must setup ap as repeater see manual
Dec 11, 2007 | Computers & Internet
Dlink 2100 ap
If you default the unit, does it still reboot?
If so, it looks like the unit is faultly.
If not, you might have a IP conflict, or channel problem. Check the two units are on the same channel, but have differant IP address.
Nov 12, 2007 | Computers & Internet
DWL-G710 and DWL-700AP compatibily problem
when using the AP you have to make sure you set the SSID, channel & wireless key in the AP the exact same as the router and make sure when configuring the Ap that you set the default gateway as the IP address of the router.
Nov 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
Motorola AP-5131  802.11a/b/g Wireless Access Point Logo
341 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
