Question about Zyxel Prestige P-330W Wireless Router (P330W)
Can I change the Zyxel P-330w Firmware for the dd-wrt?, in that case... ..can I have a little more -db? Thank you
jeicrash
  • 320 Answers
SOURCE: wrt150n dd-wrt firmware slow loading pages
First off thanks for using fixya.com
Second, I too am a dd-wrt user and found a similar problem when using dd-wrt with my IPCOP. You may want to go into the "Security" section of your dd-wrt and disable any fire walling or access-restrictions. Since you are already running zonealarm. Or remove zonealarm if you plan to use dd-wrt as your firewall.
Running multiple firewalls will slow down your network/Internet traffic.
Hope this helps you out.
Jei
Posted on Dec 15, 2008
Roynice152
  • 88 Answers
SOURCE: Wrt150n, Flashed with DD WRT.
You probably need to update a newer version of firmware. Here is a link for you.
http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
Posted on Feb 13, 2009
  • 54 Answers
SOURCE: How can I secure my zyxel Router P-330W at home?
hi...
you need to go to the computer which is connected wired to the zyxel box,in the computer click on start,run,type in cmd,and hit enter,on that black box type in ipconfig,hit enter,you wil get a list of result check default gateway(eg of default gateway is 192.168.0.1)go to internet explorer page,in the address box type in the default gateway without http or www,it will open the zyxel page for you,it might prompt you to put in the user name and the password,if it does then donot put anythingin the name of username and put 1234 as password,in this page you will see an option that says wireless,click on wireless and then click on advanced,under you will see the wireless security option where you can go ahead and make you wireless connection secured.
http://us.zyxel.com/upload/download_library/P330W_UG_V_1%201(5).pdf..this is a link for user guide u can download this to udnerstand other features that there in you router..
vedhick
Posted on Feb 26, 2009
compucure
  • 61 Answers
SOURCE: I need a dd-wrt firmware for belkin f5d7132. Or if
Have you tried here:
http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D7132uk&aid=6357&scid=0
Posted on Mar 15, 2009
  • 122 Answers
SOURCE: Connecting two routers to extend network
Router A is connected to the modem. Setup router B to run as access point only. assign an un-used IP address to router B. Turn off the DHCP server on router B. connect a LAN port of router B with a LAN port of router A .do not use the Internet port of router B. do not configure WAN settings in router B. both routers must have the same wireless settings except for the wireless channel which should be different. Set the same SSID and the same wireless security settings on both routers. Good Luck
Posted on Jul 23, 2009
How to create wireless bridge
DD WRT is a firmware upgrade sight you can find wonderful firmware upgrades that make your router come to life and Evan worth more than you payed for your original router, check the router database and see if your router is listed and capable for an upgrade to dd wrt, i did it with my dir615 and it gave me a whole host of additional optins for configurations , it was a long search for "dd wrt" but well worth it.
Oct 12, 2013 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
No connection display on ethernet connections
DD-WRT firmware is very specialized. Can you ask on a site that provides support for DD-WRT ? Can you log in to the console ?
Sep 09, 2012 | Linksys E3000 Wireless Router
Client Mode or 2nd Wireless Router with new Subnet Mask?
The original firmware does not have this option, but you can get a custom firmware at http://www.dd-wrt.com/
DD-WRT is not supported by linksys, so a little caution there as this could ruin your router if it is not installed properly. Fortuately they have plenty of documentation on installation and troubleshooting if needed.
Also found this on how to setup Client Mode through DD-WRT - http://www.dd-wrt.com/wiki/index.php/Client_Mode_Wireless
May 20, 2012 | Linksys WRT54G Wireless-G Broadband Router...
Just bought this Router ASUS RT N16. I upgraded the firmware to DD-WRT. Then upgraded to Tomato firmware following instructions found on the net. Router worked fine with DD-WRT but when I did the install...
If the device is dead in the water as a result of flashing the firmware - then I'd bring it back for either my money back or even exchange. I'd explain that during a firmware update, it became unresponsive. That's it.
I'd flash the replacement to DD-WRT firmware for your particular router again. Make sure you've got the right firmware file for your router's hardware revision too. I'd hold off on flashing to Tomato. (I use DD-WRT to perform wireless bridging w/ two Linky WRT54Gs and haven't had to do a thing to them in 3 years now - I must admit that I'm not familiar with Tomato). There's got to be an issue with the Tomato upgrade procedure you followed, firmware file or a mismatch on hardware revision of the router. I'd want to find out what that problem is before attempting it again. I doubt the store would be very understanding if you showed up with yet another dead router.
I hope this helps & good luck! Please rate my reply. Thank you.
Apr 04, 2011 | Computers & Internet
I have a linksys wrt160Nv3 and was told by explorer it was version 3.0.02 build 004 and should be updated but cannot get info from linksys, what should I do?
Here is a link that will download the latest firmware for your model router.
http://www.dd-wrt.com/routerdb/de/download/Linksys/WRT160N/3.0/dd-wrt.v24-13309_NEWD-2_K2.6_mini_wrt160nv3.bin/2294
I hope this helped
Thank you,
Norse
May 16, 2010 | Linksys WRT160N Wireless Router
I have linskey wrt160 router the router work on my desktop not my laptop it will not connect
I have heard alot of people having this type of problem. The best would be to upgrade your firmware to another firmware such as
dd-wrt and tomato
I prefer you choose DD-WRT just go to www.dd-wrt.com and click on supported devices and just type in the last 3 digits of your router then download the firmware depending on the type of your specification. Then on the wireless make sure you put the Wireless Network Mode on Mixed.
If you need more setting please let me know i will be able to assist you much better on this..
Thanks
Mar 09, 2009 | Linksys WRT160N Wireless Router
Wrt150n dd-wrt firmware slow loading pages
Jei
Dec 15, 2008 | Linksys Wireless-N WRT150N Router
Router to use as relay.
Linksys WRT54GL with DD-WRT firmware. Now, DD-WRT will void the warranty, but it has been incredible for my uses when configuring WDS. A the WRT54GS has also been said to be an excellent router, but I cannot say.
Dec 22, 2007 | D-Link AirPlus DI-524 Wireless Router
Zyxel Prestige P-330W Wireless Router (P330W) Logo
1,751 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
