Question about Dryers
GE Fabricare dryer takes a long time to day, but the top gets very warm. Exhaust seems clear and is cleaned ofter. Rich Prim
jsrock516
  • 5911 Answers
SOURCE: dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Posted on Jul 28, 2007
  • 178 Answers
SOURCE: Taking the back off a GE dryer
You typically don't remove the back of a GE dryer. The Top comes off with 2 screws located in the top of the door opening and then the front has 2 screws that are located on the inside wall. Remove those screws and pull the front of the dryer out towards you from the top to expose the door switch and wires, disconnect those, lift up on the front and you have access to the entire inside of the shell.
Posted on Mar 28, 2008
  • 70 Answers
SOURCE: no heat, dryer exhaust vent cleaned, still no heat, gas line is on
I think you have a gas dryer, and a bad ignitor.
Posted on Apr 23, 2009
milten1
  • 1304 Answers
SOURCE: My Bosch Axxis electric dryer Mod. # WTA3510UC
i would check the actual electrical connections, to both the unit, and the downline connections to that actual element itself, its unusual for an elemnt to only go a lilttle bit... it works or it doesn't...
since you seemed to be very knowlegable, ohm
out the element as well as your plug and outlet
ther emay be a loose connection somewhere
Posted on Oct 13, 2009
localwonder
  • 6784 Answers
SOURCE: Takes forever to dry clothes GE Spacemaker DSHX43AE1WW
HI. There are a few areas i would advise to check to resolve this issue.
The dryer uses multiple thermostats to regulate the temperature. When the temperature is higher than the preset limit of a particular thermostat, the thermostat breaks the circuit and the heater goes off. When the temperature cools enough, the thermostat closes the circuit again and the heat can come on.
Most dryers have a choice of temperature settings, therefore a separate thermostat is used for each setting. The selector switch or timer control then routes the circuit through the appropriate thermostat.
If a thermostat fails, it may prevent the heat from coming on, This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.
A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, This is called a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again. The most common cause of overheating will be a clogged ventilation assembly. Be sure to inspect the entire ventilation assembly for build up. This will cause issues, if obstructions exist.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
NOTE(If the Thermostats and fuse check out ok, replace the element. Element failure is uncommon but, it may fail in certain cases))
Posted on Nov 25, 2009
Condo bldg.: GE dryer emits warm-humid exhaust
If it does have a one way flap then its stuck open due to lint. They more than likely need to get the ventilation cleaned out
Jun 09, 2012 | GE Dryers
My GE dryer DBXR463 electric dryer doesn't dry the clothes all the way anymore? What could be the problem? I have cleaned all of the lint and checked the venting on the back. It used to worked fine for...
Check the entire vent (exhaust ) system start the dryer and go outside to the exhaust vent ,you should feel a good amount of warm airflow.bet you will fine low airflow. You need good air circulation to help remove the moisture from the clothing warm or hot temps alone would take longer if ever to dry ..this generally happens slowly over time and the next thing you realize is that its running much longer than it use to... plus it cost more....if you still have a concern you may have a thermostat that is short cycling not letting it get hot enough long enough... Hope this helps GOOD LUCK
Aug 21, 2010 | GE DBXR463EBWW Electric Dryer
Dryer seems to run OK and it heats up but the clothes are damp. Even after running them thru two or three times. Exhaust is clean and clear but there is not much lint build up either.
I know you say the exhaust is clear but please check again.start unit and go outside to vent and check for good warm airflow..80% of clothes drying concerns are related to restricted air flow not helping to get rid of the moisture in the clothes
Aug 10, 2010 | Dryers
Has anyone heard of a rodent getting into the GE Harmony dryer and stopping the dryer from drying? The drum still rotates, but there isn't any heat.
Yes. Rodents are notorious for building nests inside the exhaust vent ducting on dryers because of the warm air and abundance of bedding material (lint). The nest will form a clog in the vent line which will cause the heating circuits to overheat, which results in poor efficiency and longer dry times. Eventually the dryer will overheat to the point of failure. The most common fail item is the Thermal Cut-Out (TCO), or Thermister on some dryer models. This can also cause the heating element to burn out. For best results, ensure the dryer exhaust vent is cleaned thoroughly several times per year and the exhaust port at the exit point of your home is at least 12 inches from the ground. For added safety you can purchase a cover for the end of the dryer exhaust. Use the louvered exhaust covers and DO NOT use a screen. Screens will trap lint and cause clogs. Last of all, it is recommended that you use the semi-rigid metal type of ducting. It resists crushing, kinking, heat and rodent infestation. If you have questions, please let me know. I hope this helps you.
Sep 23, 2009 | GE Profile Harmony DPGT750EC Electric...
My ge dryer takes 5hrs to dry a load of clothes, it seems hot enough inside when i open it but the clothes used to dry in 90mins or so now its hours
Have you checked your lint filter? Do you empty your lint filter after every load? If it is hot inside the dryer then the most likely suspect is a clogged exhaust vent. Check the lint filter, if it is clean pull the dryer out from the wall and disconnect the exhaust hose. You may have to clear out the exhaust hose...compressed air usually does the trick. After you have done this, put everything back together and your problem should be gone.
Sep 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
GE Harmony Dryer dries fine one time won't quit sensing the next
The thermostatic fuse is getting hot during the run cycle and then staying open until the dryer cools down completely.
You may fix just by cleaning out the entire dryer. Remove the top cover and vacuum out thoroughly. Replace a torn lint screen and make sure your exhaust conduit is not leaking lint everywhere.
If you can't fix by cleaning, you will have to replace the thermostat which is a $5 part byt a $100 repair.
Jun 19, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer warm but not hot, long dry times
some times there are multiple heating elements in there and if one is out it does not get as hot. another simpler place to start would be to make sure your line is clear of debries all the way from dryer to out doors. this is a good idea any way since lint build up can cause the occasional house fire.
Jan 23, 2009 | Dryers
Kenmore elite smartheat quitpak electric dyer
try drying load with vent tube disconnected may get warm and dusty but if works ok recheck vent completely also be sure vent is not being flattened when dryer is pushed back to wall also remove lower panel(clips along top edge each corner about 3-4 inches in)remove blower housing 2-3 screws and clean housing
Dec 12, 2008 | Dryers
Dryer takes more than one cycle to dry clothes
Jul 28, 2007 | GE DBSR453EBWW Electric Dryer
Dryers Logo
67 people viewed this question
Top Dryers Experts
