Whirlpool SM8535079 seems to have no power.i CheCked the reset on plug and that is fine. it filled up with water then stopped. any thoughts of what the problem Could be. also where is the button on lid that stops washer when lid is open.
aborcass
  • 2651 Answers
SOURCE: How to open washer to check and fix lid switch
the lid switch can be changed without removing from closet for sure,you can remove the angular access panel between the2 units youll see 2 brass clips holding the cabinet to the top, slide the entire top toward you to remove. its located under there. there may be 2 screws across the rear of main top holding down as well but yea pulling out will get you kn more access to any component
Posted on Mar 16, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet Washer fills with water when not being used
Water accumulating in the tub is usually caused by two things:
Leak by - which is caused by a water inlet valve malfunction. The valve has an electronically controlled diaphragm that closes to shut the water off when not in use. Over time the valve can accumulate sediment and debris causing the valve not to seat all the way. This is especially true if you live in an area that has hard water, or if you use well water. This will cause water to leak by when the valve is not in use and accumulate over time in the wash tub. You can attempt to clean the valve with distilled vinegar to remove any sediments and flush it with clean water. You will need to remove the valve in order to do this. Sometimes a good cleaning is all it takes to correct the problem. If not, I would recommend replacing it.
Siphoning - siphoning occurs when the drain line is installed incorrectly. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although the problem usually describes a condition where a washer constantly fills and drains, or cannot maintain the proper water level, it can also cause back flow from the drain. Double check your drain line installation to ensure there is a proper air gap to allow for proper draining. If not, a vacuum is created and drain water can back flow into the washer.
A simple test would be to shut the water supply off when not in use. If the washer STILL accumulates water, you know you have a drain problem. If it does NOT, then you know you have an inlet valve issue.
If you need to replace the water inlet valve, replacements can be ordered on line at searspartsdirect.com. Just type in your model number and look under the "Dispenser Parts" heading for item number 1 (part #8181694).
It is a very simple process to replace. Just follow these steps:
1. Shut off water supply and unplug washer.
2. Disconnect fill hoses from the back of the washer.
3. Remove washer top panel by removing the three screws that hold it in place in the rear. With the screws removed, the panel slides back, then off.
4. The water inlet valve is located in the left rear of the washer (as viewed from the front with panel removed).
5. Disconnect the dispenser hose from the valve and the mounting screw(s) and the valve is removed.
6. Install new valve using the steps above in reverse order.
It really is a very simple repair. I hope you find this information helpful. Let me know if you still require assistance.
Posted on Nov 18, 2008
smartr10U
  • 1305 Answers
SOURCE: Washer is "dead." Was stopped after fill up, and now no power.
Try pushing firmly on the center of the lid.... with the lid closed... it could be that the lid switch isn't making proper contact to turn the machine on.
If this is the case, you can open the lid, and while holding the lid open with one hand, put firm pressure on the rear lip of the lid right in the center..where it makes contact with switch...
This was a common occurence at my laundromats because people would sit/stand on the machines..
Hope this gets ya up and runnin'
Posted on Jun 20, 2009
  • 4044 Answers
SOURCE: whirlpool commercial washer stopped running mid
If the timer and lid switches are funtional and the machine is filling and shutting off correctly that only leaves the motor. Have the motor tested or replace it. Even though the timer is running it is possible that it is still at fault. If you have access to another timer try switching them to make sure it isn't the timer. This does sound like a faulty motor and I would start with that assumption.
Posted on Oct 30, 2009
  • 572 Answers
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Posted on Feb 06, 2010
Filling with Water and then stops
replace the tub motor drive belt
Dec 03, 2013 | Whirlpool Washing Machines
Cabrio washer won't fill normally but diagnostic shows valves are fine
when doing the diagnostic testing machine fill up almost full and stop display an ol mode
Apr 17, 2013 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool Whirlpool WTW5560SQ Top Load: Stopped working after filling with water. Checked electric and circuits. First thought was lid switch, but no part number in manual. So where do I go from here?
The lid switch is likely the culprit. However, make certain the LH lid hinge screws are tight. If you cannot hear it click when you open and close the lid, it is bad.
Kelly
Mar 23, 2011 | Whirlpool WTW5560SQ Top Load Washer
Washer seems to cycle fine but the water will over fill
Hello, fill the washing machine with water and when the water is about 1/2 full of water,unplug the washers power cord from the wall outlet.if the water keeps flowing into the washing machine with the power cord pulled the "fill valve"(where the hot and cold hoses are attached to the washer) has mechanically stuck open and will have to be replaced. if the water shuts off when you remove it's power cord from the wall outlet,try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good.
Thanks
May 21, 2010 | Washing Machines
Washing machine overflowing
the valve on your inlet pipe may be faulty, have the valve checked or buy a new valve, not very dear, around $30 australian
May 30, 2009 | Whirlpool AWZ412 Front Load Washer
I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Apr 05, 2008 | Washing Machines
Whirlpool fridge 18top freezer 1999
Dvan,
Did you blow through drain hose? If so take back plate off youl be able to watch what it is doing.
Yours truly Fxit
Feb 20, 2008 | Refrigerators
Washing Machines Logo
Top Washing Machines Experts
