Question about KitchenAid KBMC140H Convection Microwave Oven
How to replace light bulb in microwave - KitchenAid KBMC140H Convection Microwave Oven
  • 490 Answers
Howdy. KitchenAid states that is not a user replaceable part and must be done by a service technician. I have included the link to the manual in the event you have other use for it.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20(Micro)%20-%208300890.pdf
If you have difficulty locating a reliable service technician in your area, we will gladly help locate one.
Thanks for using FixYa.com
Farmerbear
Posted on Sep 13, 2010
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: panasonic genius microwave light bulb
Does your microwave front display lite?
Posted on Aug 27, 2008
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
Replace light bulb.
http://www.ehow.com/how_7614605_replace-chef-microwave-light-bulb.html
Here is one link that i've found. It didn't mentioned the exact model but i hope this one helps...
Mar 07, 2015 | Magic Chef CMV1000B Microwave Oven
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
Interior light bulb burned out
make this test and fix it. GOD BLESS YOU
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Oct 31, 2013 | Samsung SMH8165STE Microwave Oven
Light bulb
follow this steps and fix it. God bless you
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    The range-top light blew and now replacement bulbs
    My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
    Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
    Light bulb burned out in microwave oven
    Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
    It won't hurt to run the microwave without a bulb.
    Feb 03, 2009 | Whirlpool GH7145XF Microwave Oven
    Replacing GE Spacemaker Light Bulb inside Microwave Oven...
    Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
    http://genet.geappliances.com/DocSearch/Dispatcher
    Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    KitchenAid KBMC140H Convection Microwave Oven Logo
    94 people viewed this question
    Top KitchenAid Microwave Ovens Experts
    William Miller
    William Miller
    Stu Ungar
    Darial Jr Lasaria
    Darial Jr Lasaria
    Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
