Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
GE Refrig GSL251SRFBS. Ice maker is freezing over and making huge ice berg in back of freezer over the whole ice maker. I use a hair dryer and melted it down on Saturday and by Sunday afternoon it was froze over agian. It looked as if a small drip of water was continueously coming out of the pipie over the ice tray. Maybe the problem??
  • 351 Answers
SOURCE: Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Posted on Apr 19, 2009
tborn6
  • 700 Answers
SOURCE: water coming from ice maker freezing down back wall of freezer
check for levelness of the ice maker also make sure that the fill tube is inserted all the way into the unit
Posted on Apr 25, 2009
SOURCE: GE ice maker, solid ice in ice maker
ice clumps up in the ice bucket
Posted on Jul 24, 2009
Sea Breeze
  • 4654 Answers
SOURCE: We have a GE Profile refrig, circa 1995. The ice
If you are sure it is caused by the ice maker or if it is not it can be fixed. The only way an ice maker would leak like that is if ice is blocking the inlet tube and when the water comes on the water is spewed in a different direction than the ice maker. Most times this is caused by a slow leak in the water control valve for the ice maker side at the rear of the refrigerator. You can stop the problem by melting the ice in the fill tube with a hair dryer and keeping an eye on it until you see ice beginning to build up there again. That would indicate a slow leak in the water control valve that is not closing all the way when off. The other reason for large pools of ice in the freezer is a frozen over defrost condensate drain behind the cover in the rear of the freezer and would require you to unplug power and remove the rear panel. I will try to get some photos and a link shortly that covers that problem a lot more in just a few minutes. Sea Breeze
Posted on Aug 20, 2009
  • 415 Answers
SOURCE: The water to the ice maker continues to drip then freezes up.
the loud noise is from the water freezing and hitting the fan blade in the freezer, is the imkr level? have you replace the filter if has one? is it hooked to an R/O water drinking system? if so remove the filter in frig. last thing to do if others questions ok if the shutoff to that water line going to frig is on the bottom of the pipe shut all the way off then turn back on if you have a dispenser and water is really slow to come out this may clear up the low water pressure. If on most units if you do not have appx 35psi it will not allow the valve inside the watervalve to seat and allows water to dribble by
Posted on Sep 03, 2009
Ice maker quit
if ice maker is cycleing then it is either water frozen at the tube where water comes in. if it is then shut off refrig. remove icemaker and thaw tube out with a hair dryer. makeing sure not to melt plastic in the back panel of freezer. if it is plastic. if it is not plugged then it is either a bad water valve or the watervalve switch in the icemaker.
May 26, 2012 | KitchenAid Refrigerators
My KTRC22E kitchen aid refrig. stopped making ice. I replaced the valve that ties into ties into the cold water line. The drinking water in the refrig is working properly. I'm told it may be th
sounds like you have a problem with the fill tube at the Ice Maker. remove the IM and then the back wall ( evaporator cover ) , the fill tube is probably frozen. use a hair dyer to melt ice, be careful, the hair dyer can melt the fill tube and other plastic.
Jan 07, 2012 | KitchenAid KTRS22EM Top Freezer...
My ice maker keeps freezing up and then it won't make ice cubes, water comes out, but no ice. We have taken a hair dryer and melted the ice but it came back. Why does it keep freezing up? It is a side by...
If your talking about the ice dispenser freezing up, check that the doop flap is closing properly. Sometimes a plastic eyelet will break and the flap will sit ackward. They make a kit to fix that even though they say you have to buy the whole door.
Oct 28, 2010 | KitchenAid Refrigerators
I have a side by side GE Profile refrigerator with ice and water in door which is about 10 years old. I just noticed a thin layer of ice in the bottom of the freezer. I removed it but it returned a few...
hi look to the back of inside of freezer lower part just above where you saw ice you will see a gap that the freezer drain there a hole in the middle may be cover with ice take hair dryer and melt ice and blow out drain that should do it jim
Oct 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PDS20MCP - the Ice maker is not making ice. Took out full tray of ice and has not made any since? Is there some reset button or something?
Before you the Water Valver - Shut your water off - disconnect the water line to the from the back of the refrigerator at the top where it goes into the icemaker. I used zip tie or something flexable to see if it would go all the way through to the
tube inside the refrig. If you have obstruction - use your hair dryer
to thaw the ice from inside the refrigerator tube. When the flexable item goes all the way through. Hook back the water line to the icemaker. You will have ice soon. If still not working, replace the inlet water valve at bottom back of refrig.
Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/93259-ice-maker-repair.html#post227249#ixzz0pzmjhvPC
Jun 05, 2010 | GE Profile PDS20SFS Bottom Freezer...
The line to our ice maker is frozen solid with ice. Do you know how to get the ice out of it? I'd prefer to not have to defrost the whole thing.
Pull the refrig out from the wall and you will see where the single tube to the ice maker goes . Try removing the line housing straight out the back , and thawing at the sink . Or , 2 screws hold the ice maker on . Remove the ice maker and thaw the line with a hair dryer . You will need to replace the water valve ( the piece the wall water line connects to on the refrig ) due to a seeping problem . When the valve does not close completely , drops will seep into the fill tube and freeze , thereby , blocking the normal rate of water , entering the ice maker .
Nov 11, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
MY ICE MAKER FEELER ARM IS STUCK IN THE UP POSITION. CAN YOU PLEASE TELL ME HOW I CAN FIX THIS? MODEL LFX25950SB LG REFRIG
Water is getting into the area where the arm pivots and freezing. This prevents the arm from dropping down when it should. I use a hair dryer to melt the ice in the area of where the arms comes out of the base. As soon as the arm drops, the ice maker will make more ice. This LG in the door icemaker is junk.
Jul 14, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
