Question about GPS
Sir, One person said their Rosen LR3 DVD doesn't play discs - you said clean the optical head - how do I do this?
    Guru:
  • 317 Answers
Open the device and clean the lens with cotton
Posted on Sep 13, 2010
I have a Rosen entertainment DVD system and it keeps displaying Damaged Disc every time I put a disc in the player. It won't play any discs.
It has either a dirty or bad optical pickup unit (the part that reads the disc) and usually parts are not sold (only a complete DVD section if even available)
If not dirty may be cheaper just to replace the player itself.
Apr 16, 2012 | Televison & Video
I've got VW Passat b6 2006. Rosen-VW0710-H11 is installed in it. When I try to play DVD (no matter audio or video) system displays message: "Password Fail". What can be the reason of this...
I would recommend resetting the Rosen unit. This is done by entering the "Menu" and pressing "Settings". From this screen, you select "Keypad" in the top right corner of the screen and then enter "7-5-2-3" and press "Enter". This should erase any code for Parental Control (levels 0 - 8). Also, the Rosen product states to only use "Store bought media" for CD's and DVD's meaning that it won't play all 'burned' discs. Hope this helps.- Elliot
Sep 29, 2011 | Car Audio & Video
Hello, I have Rosen car DVD player; it works good with CD disks but when I insert DVD disks it often says 'disk damage.' However, those DVD's sometimes work, but not always. So I'm...
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Thank you for using Fixya
Aug 27, 2011 | Car Audio & Video
My handheld dvd player isn't reading the disc-they just spin really fast
Spray an small drop of safe window cleaner onto a Q-tip. Clean the laser lens carefully and then use the other end of the Q-tip to dry it. Use compressed air on and around the laser lens (do not blow on it). Clean your DVD disc and try again. If it fails again, try using a CD, if it will play a CD and not a DVD your optical pickup assembly is defective. If the CD wont play at all, your optical sled or spindle motor and/or drive is defective.
Most cases if cleaning doesn't fix it, it's cheaper to replace the entire DVD player. All portable DVD players are junk, regardless of brand.
Jul 18, 2011 | Video Game Consoles & Games
Unable to read the disc.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
May 07, 2011 | Video Game Consoles & Games
MY DVD PLAYER DOESNT PLAY AND I TRIED TO CLEAN IT BUT SINCE THAT I GOT THE DVD CLEANER IT DOESNT PLAY STILL AT ALL
It is possible that the optical head assmebly must be changed as it might be damaged or weak.
Look to see if the Disc is being detected or the laser trying to read, if so the optical head is weak and needs a change.
Sep 27, 2010 | Durabrand Televison & Video
My player doesn't play any disc(vcd dvd mp3) and display shows "no disc". what is the problem ?
Failure of the Optical head assembly. You can try to clean the head lens eye as a last resort.
If not the optical head must be changed, get the same type model OE component.
If not familiar change the Head with the help of an expert as the procedure to remove the static proof, solder short must be removed.
Sep 13, 2010 | Televison & Video
Dvd player hangs up while playing
Sir I dont think its the dvd that is not working I thisnk its the screen that is starting to fail, it can be that the dvd is not sending the video signal to the screen when you open it and thatt is why you only get the blue screen and nothing else, because if the dvd was not working let it be the laser or a motor the most common message that you get in the screen is no disc, but that is not your case so I would have the screen check on that portable dvd.
Jul 23, 2010 | Rosen CV8081D Portable DVD Player
Rosen dvd player will not turn on - just purchased 2005 land rover lr3
check the owners manual for fuse locations and find the fuse for your dvd system. make sure it isnt blown. if it is, replace it and see if it blows again. if it does, or if the fuse isnt blown, take it back to the dealer and get it checked out on their dime
Jan 12, 2010 | Rosen CV7080D Portable DVD Player
Panasonic DMR-E55 DVD Recorder won't read most dvd-r brands
Hello jancinn,
This might be due to a dirty pickup or scan laser head, or the optics as a whole might be going bad (both are common problems). A qualified TV repair person should be able to determine if the scan laser or pickup head are bad by doing a laser power test. If the optical devices are dirty it is just a simple matter of cleaning them with a DVD cleaning disk, however if the optics are bad, then replacing them is actually cost inefficient, and you may want to think about getting a new DVD player/recorder.
I hope this helps,
Thank you,
Shuttle83
Jun 02, 2008 | Panasonic DMR-E55 DVD Recorder
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
