Question about Apple Canon BJC 55 InkJet Printer
The colors are all wrong when I print. My ink is pretty old - could that do it?
  • 57 Answers
Hi!
if your ink is more than 2 months old and if you have not printed anything for more than 2 weeks, that would cause you issue.. you can try doing some maintenance like cleaning the cartridge or a print head test..
hope it helps.. :D
Posted on Sep 13, 2010
  • corpsvet Oct 25, 2010
    Old ink is one possibility. This problem could also occur if the ink tank was refilled at some point and the inks have bled into each other. I suggest removing th eink tank, putting 2 drops of isoprophyl ( rubbing) alcohol in each of the 3 holes for 3 different ink colors, reinstalling the ink tank and then doing a DEEP CLEANING cycle. The rubbing alcohol is very safe to use because the canon ink is 75% alcohol. If your problem is dried ink , or contaminated jets, this will clean them out and get the ink flowing. If the problem persists, replace the color ink tank. If the problem STILL persists after that, you will need to replace the BC-11E print head.
Wrong Color Printing
Type "print nozzle test" in the search box and click Search. Perform a nozzle test, and if the colors match what are on the instructions, your print head and inks are OK.
(1) If the print head and inks check out OK, type "wrong colors on print" in the search box, and you will see several troubleshooting steps you can try.
(2) If the nozzle test colors are off, confirm that you are using BCI-6 inks for all three colors and the small black tank. You should only have a BCI-3 tank in the large black position. If you have all the correct inks, your machine probably needs to be serviced/ repaired.
Thank
Jan 09, 2014 | Dell 1320c Laser Printer
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
I replaced the color cartridge with a new one. The new cartridge was the wrong size. I placed the old colour cartridge back in the printer and now the printer will not work. The ink drop for the colour...
Hp is known for being a pain with ink.
We once had a business jet that would not print because our ink had expired lol...
The printer wont work because it know's that the old cart has no ink. And since it needs all three colors along with black to print it will not do it, Usually you can set the printer to print only black under properties or print settings.
Other then that you will need another cartridge. You can also try one more thing. If you need to print in a Pinch, down on the right hand part of your screen, Is the clock. Double click it and change the date back a year from today and see if that helps you print
Oct 06, 2010 | HP Deskjet 6980 InkJet Photo Printer
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Printer is not printing colors correctly. Brown looks red. Is there a way to clear ink heads or ink area. case shows ink spillage, need to clean up area maybe will help with color printing.
You press the ink button and choose cleaning option and test print to see if colors are correct, clean again if colors are wrong. The spillage won't hurt print quality when it's around the cartridge area. If you are using generic inks they sometimes are not the correct color.
Feb 08, 2010 | Brother MFC-440CN InkJet Printer
Printing
if your problem is printer setup page in go
and select to the b & w print and ink setting
are dark print set and give your print page
problem is also
Sep 12, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Wrong color print out
check printer catridge placement and then check that the ink is not that old
Sep 11, 2009 | Brother DCP 165C Compact Color Inkjet...
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
Noise after change color cartridges
is the toner cartridge and have a manufacturing defect or the toner cartridge scouer adaptable and look
Mar 07, 2009 | Xerox Phaser 6110 Laser Printer
0% color ink
We cannot bypass the color ink check, since the all-in-one uses little amount of even the color ink to print in black. Once check the expiry date of the color cartridge and clean the copper contacts of the cartridge and reinsert it again and then try to print. If the issue still persists replace the color cartridge and check for the result, if we experience the same issue even after replacing the color cartridge then the issue is with the all-in-one.
Apr 12, 2008 | HP Officejet 7130 All-In-One InkJet...
Apple Canon BJC 55 InkJet Printer Logo
50 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Abdul Mannan
Abdul Mannan
k24674
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
