Question about Whirlpool Duet GHW9150P Front Load Washer
The washer will start as normal then start beeping and flash F06. we had a tech look at it and he claimed the two boards weren't communicating as they should. he never fixed it and it's still doing the same. can i order the board and replace it myself?
  • 347 Answers
F06 is a drive motor tachometer error. this error code really needs hand on diagnostics because their are many wiring and component checks ..This is usually a drive motor concern but could also be a machine control board, or the wiring associated with both components .This could become a very expensive repair without a proper diagnosis.. Sorry I couldn't be of more help
Posted on Sep 13, 2010
Front load whirlpool reads codes f06 e02 tech told me it was the pump just need to know what u guys think?
Unfortunately F06 E02 is a very bad error. It means you have an interface communication error. That means that the main control board isn't communicating with the front interface control board. You can pull the washer out and remove the 3 screws coming in from the back of the top panel. Next, the top panel will pull straight back, up, and off. Now check all the wire connections between the two control board and make sure they are all secure. If everything looks good, then the interface control board will need to be ordered and replaced.
THIS IS WHAT I HAVE FOUND OUT FOR YOU ON SEVERAL FORUMS ON THE INTERNET BUT IT WOULD BE EASIER TO RING AN EXPERT BUT I HAVE FOUND OUT IT WILL COST ABOUT 150 TO FIX
Dec 29, 2013 | Washing Machines
Frigidaire affinity front load washer, my power went out and came back on, now the washer keeps beeping 3 beeps about every 30 seconds. Error code E91 will flash up when I push any button
Hi bsful1 - Typically, E91 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
Apr 11, 2013 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool duet washer-error F06 and E02
Here is a link to the part.
Oct 19, 2012 | Whirlpool Duet Steam WFW9750WR Washer
My washing machine will lock the door, start the cycle and within a minute, it will start beeping and flash an F, then an 11. At this point, I will hit the cancel button to break the cycle. Sometimes,...
The F11 error code is a communication failure between the 2 control boards. This includes both boards & the wiring harness as potential defective components. However, this is usually the main machine control board that needs replaced.
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F6????
The F06 error code on the HE3 elite is a tachometer error. Per the tech sheet, it says to check all connections and continuity between the MCU, CCU and Drive Motor. The tech sheet says normal reading is at 6 ohms.
Apr 18, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My washer displays a flashing number F 06 and will not spin? have a tech coming monday but no help today.
not ness a bearing issue, f06 is a communication issue between the motor and the motor controlller, check the connector from thne motr to the board mounted the lower left front corner, ive even seen excessive moisture in basement( high hunmidity) or perhaops a leak from a hose up above .. last F06 i encountered a nail was lodged between ithe inner and outer tubes preventing it form free spinning.. a bad rear bearing is unmistakable, sounds as if a helicopter is landing in the laundry room
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool GHW9400L4
f06 is an error pertaining to the motor control board loacated behind the lower acess panel mounted in the left fron corner, first check for loose wire connection, sometimes alot of water/moisture will trip the control, remove and refit the wire harness leading to the control a few times and look for physiacal damage to board as well.
Nov 10, 2008 | Whirlpool GHW9400 Front Load Washer
Got a LD then a CE error
CE Communications Error If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
This can be caused by corroded pins on the control card or motor control. Most of the time this relates to a faulty machine control card.
Dec 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Het3 Washer - F06 Code
dragon, drop the bottom panel by removing the 3 screws on the bottom, pull down and off. On the right side attached to the bottom of the door switch (on the inside) is a teardrop release tab. Pull down on it and the door will open. The F06 code is a motor tachometer error. The control is unable to detect the motor speed. While you have the panel off, check the harness that goes from the motor to the motor control board. The motor control board is the one on the bottom. Reseat the harness's for a good connection. If you can use a meter, check the motor windings, pins 1 to 2, 2 to 3 and 1 to 3 should read approx 6 ohms. Next, take the top off the washer by removing the 3 screws in back and sliding the top off toward the back. The main control board is in back. Make sure all the harness's are seated good. The third harnes from the right is the motor control power, reseat it. On the left side of the board, last harness toward the back is the serial communication link. Reseat it. On the motor control board on the bottom the communication link is the one toward the bottom, the center one is the motor connector and the top one is the power supply. If this doesn't solve the problem and your motor ohms out. I would tend to believe that the motor control board is the problem. Catriver..post back.
May 26, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
105 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
