My washing machine kelvinator aqua extreme shows "err2" since a couple of days and i cannot open it (since there is still water inside) nor start or complete any other program successfully. sigrid.hahn@web.de
  • sigrid_hahn Sep 14, 2010
    i wasn't able to fix the problem myself but at least it gave me the right idea to get a mechanic on the problem. it is fixed now - thankfully!
    President:
  • 632 Answers
Unplug the machine then drain the water manually by gravity. Place the drain hose into a bucket or shallow basin on the floor to drain the water. Water should gush down the drain hose if the drain system including the drain hose is clear. This signifies that the drain pump is not working. Check to make sure that the drain hose is not clogged or kinked and the drain pump filter, if there's any, is clear if water does not flow down the drain hose. Also check the drain pump for any sign of degradation or damage.
Posted on Sep 13, 2010
  • Sindy-ann Esterhuizen
    Sindy-ann Esterhuizen Aug 23, 2017
    I have the same problem. Checked the pumping, it is turning and water gushes out when the plug is removed. If I turn the plug back in, err2 happens.
Kelvinator 085 Smart Drive. Why won't it start?
kelvinator smart drive 085 washing Questions & Answers ...
www.fixya.com > Forum > Tags
smart drive 085 not filling with water when start button depressed Could be the magnetic latch on the lid that tells the machine when its closed you can by pass
Sep 30, 2015 | Washing Machines
I have Kelvinator AQUA EXTREME KL600FL lost manual and now dont know how to do the various settings for washing programmes
I am including a link to the kelvinator support center. It seems that KL600FL may not be the complete model number because the site does not answer anything for that number. . Open the lid or door and look around the frame for a model number label.
Support centre
Oct 03, 2014 | Washing Machines
Kelvinator aqua error 1
Possible that the main program controller unit has failed or is having faults within the system.
Dec 31, 2012 | Washing Machines
Fisher and paykel toploader washing machine fault 49 water valves all show 60 ohms next step?
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse on it's overload, A common thing in Aqua-Smart Machines i always keep seeing,
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Nov 26, 2012 | Fisher and Paykel Washing Machines
Washing machine doesnt work kelvinator smartdrive 085 0.5kg
you have to check 1- water pressure switch (wps) , 2- the hose which fixed between wps and drum may disconnected or broken.
Jun 12, 2017 | Kelvinator Washing Machines
Fisher@paykel aqua smart washer shows fault code49.
Fault 49 on F&P agitator models is bad cold water valve or wires on it disconnected.
Apr 25, 2012 | Fisher and Paykel Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
How do I reset the EFO Aqua Control system?
Thanks Guest! It worked perfectly lifting the face of your machine by 45 degrees
The washing machine was full of powder (this was the cause)
Aug 16, 2008 | AEG Lavamat 88840 Front Load Washer
Washing machine.Fisher and Paykell Kelvinator
check the lid switch under the lower board they rust and the fault is normally not starting,or the display board can rust inside near the start/pause button if so try and unsolder a button you dont use and replace the start button.
Mar 03, 2008 | Washing Machines
Washing Machines Logo
221 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
