Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
The chain continues to llosen and when removing the bar and chain for resetting what position should the tension be at? by the arrow? And is continued loss of tension normal. The motor is fine. Just want to make sure when I put the bar and chain back in-it is well oiled that it will sit right and provide safe usage. Thank you. if you can send a step by step it will be appreciated
    Brigadier General:
  • 4,088 Answers
It is normal for a chain to loosen under usage, especially if the chain is dull or mis-sharpened so that the chain must be overly forced into the cut or there is insufficient oil being fed to the chain from the auto-oiler. Remove the bar and chain--start the engine and look for oil oozing out of the side port in the engine where the bar fits to. If there are thin metal plates on either side of the bar, make sure that the one with a long slot fits to the engine side. This slot allows oil to enter the bar oiling holes no matter where the bar is adjusted. Be sure to clean the two small oil passages in the drive end of the bar that run from the large holes out to the chain groove on either edge. Clean the chain groove as well as the bar and engine side. Reassemble the bar and chain making sure the adjustment 'tang' drops into one of the large bar holes. Install the cover, but leave the mounting nuts/bolts finger tight. Turn the chain adjustment screw CW until the chain just pulls up to the lower bar edge, then tighten the cover mounts. Make sure the chain can be turned by hand and is fully up to the bar with light tension. Chain filing is fairly exacting and must be consistent from tooth to tooth. If a tooth edge cuts your finger, it is considered to be sharp. (not a suggested test by the way) Look for no light reflecting from the filed edge as a good test. Once everything is ready, start the engine and run the bar tip near some cardboard--a few moments running should produce a thin line of oil. If it seems slow to cut, check the chain's sharpness. Don't worry about adjusting the chain to some mark as the chain will grow length with use. It is not necessary to remove the bar and chain when adjustment is required, just loosen the bar mounting fasteners to finger tight. Hope this helps!
Posted on Sep 13, 2010
Removing cover to changeing chains
Remove the 2 side casing nuts.
Slacken off the chain tension screw. (it may be attached to the side casing).
Remove bar and chain.
Replace chain on the bar and reposition back and the saw.
Put the side casing back on and adjust the chain tension for the new chain.
Tighten up the 2 side casing nutsonce bar is in working position.
Apr 14, 2013 | Husqvarna Garden
Tip
Chainsaw Chain Installation Directionality and Burr Removal/Repair
Chain Repair
Remove the bar & chain. Affix a piece of tape to or mark one of the upper chain links. Wear gloves, hold the bar parallel with the ground, the nose right, the tail left and the chain in the upper bar groove. Try to slowly rotate the chain CCW one complete revolution. If you cannot, it occasionally rides up and out of the bar groove or it catches there are likely burrs on the drive links.
I find it easiest to remove them by positioning the chain as displayed immediately below, so a file may be used on the exterior of the loop.
Chain Installation & Adjustment
The chainsaw chain links, on the upper part of the bar, must be installed as illustrated immediately above.
  1. Make sure the chain brake is off (wear gloves to protect your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They do not need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside center of the bar, if the bar has a sprocket nose, add a touch more (1/8 or less).
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system.
HTH
Lou
on Feb 17, 2010 | Garden
How do i reset the timing on 2001 2.7l concorde if the chain was replaced and the timing is off
Did you take pictures while removing the originals? It's always a good habit. Below are the instructions you need to follow. Your own pics are very helpful when doing a big job like this.
  1. Disconnect negative battery (1) cable.
  2. Drain cooling system.
  3. Remove upper intake manifold.
  4. Remove cylinder head covers, crankshaft vibration damper, and timing chain cover.
CAUTION: When aligning timing marks, always rotate engine by turning the crankshaft. Failure to do so will result in valve and/or piston damage.
117014297
  1. Align crankshaft sprocket timing mark to mark on oil pump housing (2). The mark on oil pump housing is 600 ATDC of #1 cylinder.
CAUTION: When the timing chain is removed and the cylinder heads are still installed, DO NOT rotate the camshafts or crankshaft without first locating the proper crankshaft position. Failure to do so will result in valve and/or piston damage.
117016938
  1. Remove primary timing chain tensioner retainer cap (2) and tensioner (1) from right cylinder head.
117016939
  1. Disconnect and remove camshaft position sensor (4) from left cylinder head.
  2. Remove timing chain guide access plugs (3) from cylinder heads.
NOTE: When camshaft sprocket bolts are removed, the camshafts will rotate in a clockwise direction.
  1. Starting with the right camshaft sprocket, remove the sprocket attaching bolts. Remove camshaft damper (1) (if equipped) and sprocket.
  2. Remove left side camshaft sprocket attaching bolts and remove sprocket.
  3. Remove lower chain guide (7) and tensioner arm (8).
  4. Remove the primary timing chain (5).
  5. Remove crankshaft sprocket (6).
INSTALLATION
117016940
  1. Inspect all sprockets (4,9,11) and chain guides (2,5,10). Replace if worn.
  2. For crankshaft sprocket installation procedures Refer to CRANKSHAFT SPROCKET.
  3. If removed, install right and left side short chain guides (11). Tighten attaching bolts to 28 Nm (250 inch lbs.) .
  4. Align crankshaft sprocket timing mark to the mark on oil pump housing (3).
NOTE: Lubricate timing chain and guides with engine oil before installation.
  1. Place left side primary chain sprocket onto the chain so that the timing mark is located in-between the two (plated) timing links (1).
117016941
  1. Lower the primary chain with left side sprocket through the left cylinder head opening.
NOTE: The camshaft sprockets can be allowed to float on the camshaft hub during installation.
  1. Loosely position left side camshaft sprocket over camshaft hub.
  2. Align timing (plated) link to the crankshaft sprocket timing mark (3).
  3. Position primary chain onto water pump drive sprocket (10).
  4. Align right camshaft sprocket timing mark to the timing (plated) link on the timing chain (8) and loosely position over camshaft hub.
  5. Verify that all chain timing (plated) links are properly aligned to the timing marks on all sprockets.
  6. Install left side lower chain guide (2) and tensioner arm (5). Tighten attaching bolts to 28 Nm (250 inch lbs.) .
NOTE: Inspect O-ring on chain guide access plugs before installing. Replace O-ring as necessary.
  1. Install chain guide access plugs to cylinder heads. Tighten plugs to 20 Nm (15 ft. lbs.) .
NOTE: To reset the primary timing chain tensioner, engine oil will first need to be purged from the tensioner.
117016942
  1. Purge oil from timing chain tensioner using the following procedure:
    1. Place the check ball (2) end of tensioner into the shallow end of Special Tool 8186 (3).
    2. Using hand pressure, slowly depress tensioner until oil is purged from tensioner.
117016943
  1. Reset timing chain tensioner using the following procedure:
    1. Position cylinder plunger (4) into the deeper end of Special Tool 8186 (3).
    2. Apply a downward force until tensioner is reset.
NOTE: If oil was not first purged from the tensioner, use slight finger pressure to assist the center arm pin of Special Tool 8186 to unseat the tensioner's check ball.
CAUTION: Ensure the tensioner is properly reset. The tensioner body (4) must bottom against the top edge of Special Tool 8186 (3). Failure to properly perform the resetting procedure may cause tensioner jamming.
NOTE: Inspect the tensioner O-ring (2) for nicks or cuts and make sure the snap ring (1) is correctly installed, replace as necessary.
117016944
  1. Install the reset chain tensioner (1) into the right cylinder head.
  2. Position tensioner retaining plate (2) and tighten bolts (1) to 12 Nm (105 inch lbs.) .
117016945
  1. Starting at the right cylinder bank, first position the camshaft damper (1) (if equipped) on camshaft hub, then insert a 3/8 square drive extension with a breaker bar into intake camshaft drive hub. Rotate camshaft until the camshaft hub aligns to the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and tighten to 28 Nm (250 inch lbs.) .
  2. Turn the left side camshaft by inserting a 3/8 square drive extension with a breaker bar into intake camshaft drive hub and rotate camshaft until the sprocket attaching bolts can be installed. Tighten sprocket bolts to 28 Nm (250 inch lbs.).
  3. Rotate engine slightly clockwise to remove timing chain slack, if necessary.
117016946
  1. Activate the timing chain tensioner by using a flat bladed pry tool to gently pry tensioner arm towards the tensioner slightly. Then release the tensioner arm. Verify the tensioner is activated (extends).
117016947
  1. Install camshaft position sensor (2) and connect electrical connector.
  2. Install the timing chain cover, crankshaft vibration damper, and cylinder head covers.
  3. Install upper intake manifold.
NOTE: After installation of a reset tensioner, engine noise will occur after initial start-up. This noise will normally disappear within 5-10 seconds.
  1. Fill cooling system.
Mar 27, 2013 | 2001 Chrysler Concorde
How to change a chain
First of all, make sure the saw is off. Also, before removing bolts, make sure the chain brake is not engaged (the chain should move freely).
Remove the guide bar side panel. Using a scwrench or wrench, unscrew the nuts and remove the plate to access the chain.
The side plate on most chainsaws will be held on by two nuts. Loosen the blade adjustment screw (a pin that is usually driven by a screw and pushes the blade out from the chainsaw to keep the chain tension tight).
The old chain is ready to be removed now that the sprocket plate is off of the saw. Pull the nose of the chainsaw's bar away from the chainsaw to release it from the tensioner.
Remove the old chainsaw chain.
The chain will easily remove from the guide bar with all that slack in it. Note the orientation of the cutting edges of the chain so you put the new one on the same way.
Pull the drive links out of the guide bar and slip the other end of the chain around the clutch drum.
Steps to Install a New Chainsaw Chain
Thread the new chain onto the saw.
Carefully thread your new or recently sharpened chainsaw chain around the chainsaw's clutch drum, making sure that the drive links engage in the sprocket.
Thread the rest of the drive links into the guide bar and around its nose, making sure all links are in the guide bar slot.
Align the guide bar.
With the chain properly threaded along the clutch drum and guide bar, put some tension into it by pulling on the nose of the guide bar away from the chainsaw.
While pulling the guide bar, make sure to seat it onto the saw's adjustment pin.
Replace the side plate.
The side plate is ready to go back on as long as the guide bar is properly positioned beneath.
Replace the plate and the nuts that hold it into position, but do not tighten the nuts down all the way yet. The guide bar must be allowed to move a little while the chain is tightened to the correct tension.
Tighten the chain to the correct tension. Use the tensioning screw to the side of the guide bar to adjust the tension on the chainsaw chain.
Finish tightening the side plate nuts.
The chainsaw chain replacement is now complete.
And here is a great overall reference guide to keeping a chainsaw sharp and running. Sharpening a chainsaw chain is a great way to extend the life and is less expensive and easier than replacing a chain. There are small grinding tools (like a dremel) that can be run off a small 12v battery or your vehicle battery that allow for quick 'tune-ups' on your chain if you are out cutting and need to sharpen your chain.
http://www.pcta.org/pdf/STUCHAP2_web.pdf
Aug 28, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need to put a new chain on a Husqvara 235 14 inch chain saw?
Check that the chain brake is in disengaged position by
moving the front hand guard towards the front handle.
Remove the bar nuts and remove the clutch cover (chain
brake). Take off the transportation ring.
Fit the bar over the bar bolts. Place the bar in its rearmost
position. Place the chain over the drive sprocket locate it in
the groove on the bar. Begin on the top edge of the bar.
Make sure that the edges of the cutting links are facing
forward on the top edge of the bar.
Fit the clutch cover (chain brake) and locate the chain
adjuster pin in the cut-out in the bar. Check that the drive
links of the chain fit correctly on the drive sprocket and that
the chain is in the groove on the bar. Tighten the bar nuts
finger-tight.
Tension the chain by turning the chain tensioning screw
clockwise using the combination spanner. The chain
should be tensioned until it does not sag from the
underside of the bar.
The chain is correctly tensioned when it does not sag from
the underside of the bar, but can still be turned easily by
hand. Hold up the bar tip and tighten the bar nuts with the
When fitting a new chain, the chain tension has to be
checked frequently until the chain is run-in. Check the
chain tension regularly. A correctly tensioned chain
ensures good cutting performance and long life.
Jun 27, 2011 | Husqvarna Garden
I would like to have a diagram of the timing comfiguration of a 2002 dodge intrepid 2.7 .....i am very interested in the timining marks for the camshafts
Hi, this engine uses plated links in the chain to match marks on the gears. See figure and installation procedure below. Let me know if you have any questions and thanks for using FixYa.
    1. Install the timing chain by performing the following procedure:
    1. Verify that the crankshaft sprocket timing mark is aligned with the mark on the oil pump housing.
    2. Place the left side primary timing chain sprocket onto the chain, while aligning the timing mark on the sprocket to the 2 plated links on the chain.
    3. Lower the chain with the left sprocket through the left cylinder head opening.
    4. Loosely position the left camshaft sprocket over the camshaft hub.
    5. Align the plated link to the crankshaft sprocket timing mark.
    6. Position the timing chain around the water pump drive sprocket.
    7. Align the right camshaft sprocket timing mark to the plated link on the timing chain and loosely position the sprocket over the camshaft hub.
    8. Verify that all the plated links are aligned to their proper timing marks.
    1. Install the left lower timing chain guide and tensioner. Torque the bolts to 21 ft. lbs. (28 Nm).
      NOTE Inspect the timing chain guide access plug O-rings before installing. Replace damaged O-rings as necessary.
    2. Install the timing chain guide access plug to the left cylinder head and torque to 15 ft. lbs. (20 Nm).
      NOTE To reset the timing chain tensioner, oil will first need to be purged from the tensioner.
    1. Purge oil from the timing chain tensioner using the following procedure:
    1. Remove the tensioner from the tensioner housing.
    2. Place the check ball end of the tensioner into the shallow end of the Tensioner Resetting Special tool 8186.
    3. Using hand pressure, slowly depress the tensioner until oil is purged from the cylinder.
    4. Reinstall the tensioner into the tensioner housing.
    1. Reset the timing chain tensioner using the following procedure:
    1. Position the cylinder plunger into the deeper side of the Tensioner Resetting special tool 8186. Apply a downward force until the tensioner is reset.
    WARNING
    Ensure that the tensioner is properly reset. The tensioner body must be bottomed against the top edge of the Tensioner Resetting Special tool 8186. Failure to properly perform the resetting procedure may cause tensioner jamming.
    1. Install the chain tensioner into the right cylinder head.
    2. At the right cylinder head, insert a 3 / 8 in. square drive extension with a breaker bar into the intake camshaft drive hub. Rotate the camshaft until the camshaft hub aligns with the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and torque to 21 ft. lbs. (28 Nm).
    3. Turn the left camshaft by inserting a 3 / 8 in. square drive extension with a breaker bar into the intake camshaft drive hub. Rotate the camshaft until the camshaft hub aligns with the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and torque to 21 ft. lbs. (28 Nm).
    4. If necessary, rotate the engine slightly clockwise to remove any slack in the timing chain.
    5. To arm the timing chain tensioner: Use a flat-bladed prytool to gently pry the tensioner arm towards the tensioner slightly. Then, release the tensioner arm. Verify the tensioner extends.
    6. Inspect and replace the timing chain cover gasket and oil seal.
    7. Apply a 1 / 8 in. (3mm) bead of sealer at the parting line of the oil pan and engine block.
      NOTE When installing the timing cover, guide the seal over the crankshaft to prevent damage to the seal-s lip.
    Install or connect the following:
    Timing cover and gasket and torque the M10 bolts to 40 ft. lbs. (54 Nm) and the M6 bolts to 105 inch lbs. (12 Nm)
    Accessory drive belt tensioner pulley
    Power steering pump
    Crankshaft damper
    Crankshaft center bolt and torque the bolt to 125 ft. lbs. (170 Nm) using tool 8191
    Accessory drive belts
    Fan module and electrical wiring harness
    Upper radiator crossmember
    Negative battery cable
    Dec 25, 2010 | Dodge Intrepid Cars & Trucks
    Setting blade tension withouty gauge
    With the chainsaw positioned and with the bar/chain combo loosely assembled properly on the chainsaw power-head. With the guide bar/chain adjuster inserted properly into the bar. Using a rag or wearing gloves. Notice how much up and down movement is at the guide bar tip. You must use this to your best advantage!! With the chain adjuster loose. finger tighten the bar nut or nuts. Hold the bar-chain assembly in the up position. To tension the chain, turn the adjuster in the correct direction to tighten the chain. DO NOT LOOSEN YOUR HOLD ON THE BAR, KEEP THE BAR IN THE UP POSITION. Rotate the chain along the bar to make sure it is free to move back and forth, KEEP THE BAR UP. Tighten the tensioner until the chain just touches the bottom of the guide bar. Check for back and forth movement again. Tighten the tensioner no more than a quarter of a turn. CONTINUE TO HOLD THE BAR UP. Now tighten the bar buts or nut snugly against the sprocket & chain guard cover. Check for movement again. If satisfactorily tight and free movement is attained the chain bar combination is properly adjusted.
    This scenario will change with different types and brands of chainsaws. It is always very helpful if posters would include a modicum of make, model information with their queries.
    Waltster
    Oct 28, 2010 | Garden
    I just had my water pump changed and when everything was all finished I was told to start my car. Well it started right up but it sounded like the chain was dragging on metal. I opened the front plate and...
    here is the procedure for the tensioner:
    2. Apply a downward force until the tensioner is reset.
      WARNING Ensure that the tensioner is properly reset. The tensioner body must be bottomed against the top edge of the Tensioner Resetting Special tool 8186. Failure to properly perform the resetting procedure may cause tensioner jamming.
    Oct 04, 2010 | 2002 Dodge Intrepid
    Can i get instructions to download on how to change the chain on my homelite 33cc chainsaw with 14.35 chains
    Got to homelite.com and input your model number.
    WARNING:
    When servicing, use only identical Homelite
    replacement parts. Use of any other parts may
    create a hazard or cause product damage.
    WARNING:
    Always wear safety goggles or safety glasses
    with side shields during power tool operation or
    when blowing dust. If operation is dusty, also
    wear a dust mask.
    GENERAL MAINTENANCE
    Avoid using solvents when cleaning plastic parts.
    Most plastics are susceptible to damage from
    various types of commercial solvents and may be
    damaged by their use. Use clean cloths to remove
    dirt, dust, lubricant, grease, etc.
    WARNING:
    Do not at any time let brake fluids, gasoline,
    petroleum-based products, penetrating
    oils, etc., come in contact with
    plastic parts. Chemicals can damage, weaken or
    destroy plastic which may result in serious
    personal injury.
    LUBRICATION
    All of the bearings in this product are lubricated with
    a sufficient amount of high grade lubricant for the
    life of the unit under normal operating conditions.
    Therefore, no further lubrication is required.
    REPLACING THE guide BAR AND
    CHAIN
    See Figures 34 - 43.
    DANGER:
    Never start the engine before installing the
    guide bar, chain, clutch cover, and clutch drum.
    Without all these parts in place, the clutch can
    fly off or explode, exposing the user to possible
    serious injury.
    maintenance
    Fig. 34
    Fig. 35
    Fig. 36
    WARNING:
    To avoid serious personal injury, read and
    understand all the safety instructions in this
    section.
    n Always place the switch in the stop “ ” position
    before you work on the saw.
    clutch
    cover
    Run
    Position
    sprocket
    Page 26 — English
    cutters
    bar
    groove
    chain drive links
    Fig. 38
    maintenance
    chain rotation
    chain drive links
    Fig. 37
    n Make sure the chain brake is not set by pulling
    the chain brake lever/hand guard towards the
    front handle to the run position.
    NOTE: When replacing the guide bar and chain,
    always use the specified bar and chain listed in
    the Bar and Chain Combinations section later
    in this manual.
    n Wear gloves when handling the chain and bar.
    These components are sharp and may contain
    burrs.
    n Press in on the clutch cover lock knob and rotate
    counterclockwise until the clutch cover can be
    removed.
    n Remove the bar and chain from the mounting
    surface.
    n Remove the old chain from the bar.
    n Lay out the new saw chain in a loop and
    straighten any kinks. The cutters should face
    in the direction of chain rotation. If they face
    backwards, turn the loop over.
    n Place the chain drive links into the bar groove
    as shown.
    n Position the chain so there is a loop at the back
    of the bar.
    n Hold the chain in position on the bar and place
    the loop around the sprocket.
    n Fit the bar flush against the mounting surface
    so that the bar studs are in the long slot of the
    bar.
    n Replace the clutch cover ensuring that the
    adjusting pin in the clutch cover is in the bar
    chain tensioning pin hole and that both bar
    studs are securely in their respective holes in
    the clutch cover.
    NOTE: The adjusting pin may need to be slightly
    repositioned with the chain tensioning dial so
    that it is aligned with the position of the bar chain
    tensioning pin hole.
    n Replace the clutch cover and rotate clutch
    cover lock knob just enough to hold the cover
    in position.
    NOTE: The bar must be free to move for chain
    tension adjustment.
    n Lift the tip of the guide bar up to check for sag.
    n Remove all slack from the chain by rotating the
    chain tensioning dial clockwise until the chain
    seats snugly against the bar with the drive links
    in the bar groove.
    n Release the tip of the guide bar and, if the chain
    sags, turn the chain tensioning dial clockwise.
    Repeat this process until sag does not exist.
    n Hold the tip of the guide bar up and tighten the
    clutch cover lock knob securely.
    Jun 25, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
    I have a 99 dodge intrepid that threw a rod and my father-in-law and I have been trying to time the car for a year now. We get number one piston up but the mark on the oil pump doesnt line up with the mark...
    I'm not sure what you may be "doing wrong", but here is the manufacturer procedure for aligning the timing marks.
    ^Refer to this diagram during step 12.
    ^Refer to this diagram during step 13.
    ^Refer to this diagram for step 19.
    1. Align crankshaft sprocket timing mark to the mark on oil pump housing. NOTE: Lubricate timing chain and guides with engine oil before installation.
    2. Place left side primary chain sprocket onto the chain so that the timing mark is located in-between the two (plated) timing links.
    3. Lower the primary chain with left side sprocket through the left cylinder head opening. NOTE: The camshaft sprockets can be allowed to float on the camshaft hub during installation.
    4. Loosely position left side camshaft sprocket over camshaft hub.
    5. Align timing (plated) link to the crankshaft sprocket timing mark.
    6. Position primary chain onto water pump drive sprocket.
    7. Align right camshaft sprocket timing mark to the timing (plated) link on the timing chain and loosely position over camshaft hub.
    8. Verify that all chain timing (plated) links are properly aligned to the timing marks on all sprockets.
    9. Install left side lower chain guide and tensioner arm. Tighten attaching bolts to 28 Nm (250 in. lbs.). NOTE: Inspect oil ring on chain guide access plug before installing. Replace O-ring as necessary.
    10. Install chain guide access plug to left side cylinder head. Tighten plug to 20 Nm (15 ft. lbs.)
    11. NOTE:
    12. Purge oil from timing chain tensioner using the following procedure:
    a) Place the check ball end of tensioner into the shallow end of Special Tool 8186.
    b) Using hand pressure, slowly depress tensioner until oil is purged from tensioner.
    13. Reset timing chain tensioner using the following procedure:
    a) Position cylinder plunger into the deeper end of Special Tool 8186.
    b) Apply a downward force until tensioner is reset. NOTE: If oil was not first purged from the tensioner, use slight finger pressure to assist the center arm pin of Special Tool 8186 to unseat the tensioner's check ball. CAUTION: Ensure the tensioner is properly reset. The tensioner body must bottom against the top edge of Special Tool 8186. Failure to properly perform the resetting procedure may cause tensioner jamming.
    14. Install the reset chain tensioner into the right cylinder head.
    15. Position tensioner retaining plate and tighten bolts to 12 Nm (105 in. lbs.).
    16. Starting at the right cylinder bank, insert a 3/8" square drive extension with a breaker bar into intake camshaft drive hub. Rotate camshaft until the camshaft hub aligns to the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and tighten to 28 Nm (250 in. lbs.).
    17. Turn the left side camshaft by inserting a 3/8" square drive extension with a breaker bar into intake camshaft drive hub and rotate camshaft until the sprocket attaching bolts can be installed. Tighten sprocket bolts to 28 Nm (250 in. lbs.).
    18. Rotate engine slightly clockwise to remove timing chain slack, if necessary.
    19. To arm the timing chain tensioner: Use a flat bladed pry tool to gently pry tensioner arm towards the tensioner slightly. Then, release the tensioner arm. Verify the tensioner is armed (extends).
    20. Install the timing chain cover, crankshaft damper, and cylinder head covers.
    21. Install camshaft position sensor and connect electrical connector.
    Hope this helps!
    Mitchell
    May 16, 2009 | 1999 Dodge Intrepid
    Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
    152 people viewed this question
    Top Homelite Garden Experts
    Jim Parker
    Jim Parker
    roeb
    Mike Squire
    Are you a Homelite Garden Expert? Answer questions, earn points and help others
