Question about Garden
I have a MTD 13AT688H131 Husky, 21 hp, and I can not keep the lower drive belt from coming off. The repair person has replaced belts twice and even the double pulley. What the heck is going on?
  • 24 Answers
SOURCE: 826LE Power Max Snowthrower_ Drive belt keeps coming off
part # 94-8812 is traction belt 106-4498 auger belt
There is a service bulltin on this I have not seen this yet, Ill paste it for you to look at .
this was issued dec 22-2003 you would think that it would have shown up as a problem by now.
UNITS AFFECTED: Model Number(s): Serial Number(s):
38620 240000001-240999999
38621 (Int'l.) 240000001-240999999
38632 240000001-240999999
38635 (Int'l.) 240000001-240999999
38642 240000001-240999999
38645 (Int'l.) 240000001-240999999
38652 240000001-240999999
SUBJECT: Traction belt jumps off the pulley.
SITUATION: Incorrect pulley alignment causes the traction belt to jump off, usually when the drive is disengaged or as a hill is crested.
CORRECTION:
1. Remove the belt cover, engine belt guide and the bolt securing the crankshaft pulley.
2. Remove the auger brake assembly.
3. Remove the crankshaft pulley and the auger belt.
4. On the left side of the machine, remove the hair pin cotter from the speed control link and slide the link out of the pulley pivot assembly. The traction belt can now be removed.
5. Shorten the pulley half nearest the engine (PN 106-7334) shown in Fig 1. Grind or machine 1/8” (.125”/3.2mm). from the hub end of the pulley. The new finished length of the pulley half should be 1.07” (2.7cm).
6. Chamfer the bore to ensure the pulley fully contacts the shoulder on the crankshaft. You can send the pulley to an outside machine shop if you do not feel that you can modify the pulley in house.
7. Reinstall the pulley with a new traction belt.
A. Chamfer edge after grinding/machining.
B. Remove 1/8”.
C. Masking tape used as a reference line.
8. With the engine off, engage both the traction and auger levers and inspect the alignment of both the auger and traction belt idler pulleys (Fig. 2). Since we have moved the crankshaft pulley it may be necessary to bend the idler arms slightly to center the belts. Adjust as needed.
9. Install the engine belt guide and test operate.
10. Install the belt covers.
PARTS: P/N 94-8812 Traction Belt
Posted on Feb 10, 2009
  • 86 Answers
SOURCE: belts slipping and breaking
If you are putting on the mtd belts and installing them right then you need to check bearings in variable speed pulley Also check idler and that no other pulley has been bent from installation.
Posted on May 16, 2009
SOURCE: MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Posted on Jun 15, 2009
lester482529
  • 226 Answers
SOURCE: drive belt diagram for mtd rideon
hi;go to partstree.com.put in your model # and make.then click on deck assembly.it will be what your looking for.hope this helps.please rate this;Thank's
Posted on Jul 04, 2009
  • 45 Answers
SOURCE: replace transmission belt on my 42" MTD Mower
You can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers.
Posted on Aug 25, 2009
Belt diagram for 46" mtd yard machine riding mower
You can find the belt diagram for the MTD Yard Machine mower in the MTD Owner Manual. The diagram is on page 21.
Feb 02, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Lt4600 huskie riding mower :the belt that drives the blades keeps comming off .The authorized repair shop has replaced this belt twice the first year and it still comes off !.It's 2 years old . I
Sounds like you either have a bad bearing in the pullys or pully or the guides that keep that belt in place are not doing their job. Any repair shop can change out a belt. However, fixing it is another thing. I had a customer who said every since he had his lawn tractor the belt wouldn't last long enough to get a summer out of it. I found the spring missing of the tensioner pully for the belt when it's engaged and also the guide for the belt was on backwards and therefore cutting the face of the belt.
Oct 20, 2017 | Mtd Garden
Drive belt size mtd 21 " 6.75hp mower
If you post the model number of the machine, I can probably find the belt dimensions..
Tim
Oct 16, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Belt for self popelled mower keeps breaking? Cannot keep a new belt on pulley
Check that the pulley isn't seizing up and causing the belt to snap, also be sure you loosen up the self propelled mechanismn by spraying down with WD 40, too much belt tension can cause this, but it rather seems like the belt pulley seizes and the engines drive pulley keeps turning causing the belt to overheat and break or stretch and come flying off.
Jun 21, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Need a repair manual for a huskee 21hp. 46" cut model#13at688h731 George`s e-mail hvg.prop@cox.net
My MTD Huskee 21 HP 46" Lawn Tractor keeps breaking the transmission belt. We have replaced it several times and it breaks again after 4 or 5 mowings.
Apr 19, 2010 | Mtd Garden
MTD front wheel drive self-propelled 21". Self-propelled does not work. Can it be fixed?
Yes it can be fixed. Try some basics first.
1) Check under belt drive cover for excess debris
2) Belt and Idler pulley condition
3) Control cable operation
a) rusted, frozen, broken, disconnected
Dec 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
114 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
