Question about HP Office Equipment & Supplies
Hp deskjet F2180 All in one We purchased it today the printer doesnt work properly when turned on the paper feeder jams and scrunches and folds paper as it pulls it through also the catridge holder doesnt slide to the middle ready for cartridge insert so we cannot print or even do the set up for it. Can you please help.Can We please have a return number so we can exchange for another one. Mr G
  • donnap1234 Jan 23, 2009
    ive got the same prob , useless!!!!!!
    Genius:
  • 2,785 Answers
Just ask your vendor for the problem
Posted on May 15, 2008
Paper feeder pulls multiple sheets of paper
PULL ALL PAPER OUT OF MACHINE EVEN THE SUPPLY, UNPLUG OR TURN OFF THE POWER TO THE UNIT, PUT A STACK OF PAPER IN THE SUPPLY TRAY & GENTLY PUSH FORWARD NOT FORCING IT UNTIL IT STOPS. TURN POWER BACK ON & TRY AGAIN. YOU MAY HAVE TO REPEAT THIS 2-4 TIMES BUT IT WORKED FOR MY HP DESKJET F4180 ALL IN ONE.
Dec 28, 2012 | Canon PIXMA MP460 All-In-One InkJet...
It seems my F2180 can not print photo paper. Are they too thick? I get paper jam all the time. Regards Loyd
Photo paper usually needs to be loaded SINGLE SHEET, or it will jamb, and this is commonly stated on the packaging of the paper...Just load single sheets, and no more problem.
Aug 28, 2011 | HP Deskjet F2180 All-In-One InkJet Printer
Paper is coming out scrunched (folded) and sometimes torn at the top left corner.
Make sure the printer is clear of any paper jams and don't load the tray full of paper, load it 75% full but not 100%.
Feb 28, 2011 | HP LaserJet 3380 All-In-One Printer
LEXMARK x 2650 -- PAPER WILL NOT FEED INTO PRINTER CORRECTLY- WILL STOP AND SCRUNCH UP ON THE LEFT SIDE OF PRINTER FEEDER
Look very carefully inside where it scrunches up. you'll probably see another small piece of paper from a previous jam... remove it
Jan 23, 2011 | Lexmark Office Equipment & Supplies
HP Deskjet F2180 gives error "cover open"
Make sure your printer cover and the paper tray is properly closed. If they are, see if the sensor for the cover has any deffects
Jan 11, 2010 | HP Deskjet 2360 InkJet Printer
Documnet feeder jam
Check input paper feeder at top too - easy to miss. Top flips open with a firm (but not excessive) pull, so you can look there.
If you are sure you've opened and looked under every available panel on the printer (there are many!), turn it off and unplug for half a minute. Make sure all panels are back properly in place, but leave out the paper tray (and no paper either in the rear input paper feeder).
Plug in and turn on. Wait for it to finish its start-up sequence - it should complain about no paper.
Check the paper is flat and straight in the paper tray, and no excess room between paper and guides, and put it in again.
Print test page.
How is it now?
Sep 15, 2009 | HP LaserJet 3055 All-In-One Printer
Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Thanks
Newton
Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
110 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
