Question about Polaris Pb4 - 60 Booster Pump
My pump is making a loud screeching sound, do i need a new one or can i fix it? something in the impeller?
Just fixed two myself. One I caught early enough - not too much collateral damage. Both needed the mechanical seals on the pump replaced and both needed new impellers (damaged due to heat build up when seal went bad. Impeller cost at pool store is about $23-$28. Seal at pool store is about $10. Of course, both can be had cheaper online if you can wait for them to be shipped. Easy job really.
If yours has been running a while in this condition, you probably have toasted your motor bearings. They too can be replaced somewhat easily but if I were you, call a local electric motor repair shop to have them inspect and repair, as necessary. Will probably cost you $50-$75. Still, cheaper than purchasing a whole new pump
Posted on Sep 14, 2010
FDB1050remo Making a squeaking sound almost as if a belt slipping. Not overloaded and nothing rubbing on washer blades. My only guess is that it may be related to low water pressure. Is that possible?
please make this test and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 18, 2013 | Dishwashers
Ariston li 700
follow the steps and fix it. God bless you
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
Jul 06, 2013 | Dishwashers
My pool pump is making a screeching noise
Chances are you either have something stuck in the impeller (not likely), or your motor bearings are worn out. If the latter is true, you are about to lose the use of your motor.
Depending on your motor, you may be able to have the bearings replaced. Otherwise, you may be looking at a new motor.
When the bearings on mine were going out (mine are non-serviceable), I just continued to run the motor til it completely failed. Then I replaced it.
If you are the "do-it-yourself-er" type, it is much cheaper to order a new motor online and change it out yourself. Takes less than 30 minutes. Be sure to replace the shaft seal when you change out the motor. I replaced my Sta-Rite Duraglas (A.O.Smith) motor and seal for $150.
Hope this helps.
Jun 15, 2013 | Speck Pumps Pool & Spa
Sudden loud vibration from the door of my Whirlpool dishwasher. Replacing the part didn't help.
see this causes and fix it. God bless you
Drain Pump If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 28, 2012 | Whirlpool Dishwashers
I have a Frigidaire Gallery dishwasher with model # GLDB958JB0 and it started to make a screeching noise only after a few mins into the wash cycle. I took out the filter and made sure there was noting...
Hello & Welcome to FixYa
The problem is with the impeller or the chopper assembly that is causing this screeching noise. You can take apart the bottom front access panel and clean the drain pump assembly completely and check for any broken parts inside that need replacement. If the problem returns then replacing the impeller/drain pump-motor assembly is recommended repair. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | Frigidaire Dishwashers
Pump motor makes loud noise when pump comes on
If this is a high pitched sound, then this sounds like you have bearings that are starting to go out.  There is not much that you can do to prevent eventual failure.
The only other option that I see is that there is something causing friction inside the pump between the impeller and diffuser.
Dec 28, 2008 | Pentair 1.0 Hp Whisperflo Pump
Mine is a FDB635RFS4 model - issue is loud screeching noise
i recently had the same problem of a loud screeching noise. my unit was installed new in 1999 and has worked well up to this point.
when i disassembled the tub water filter i found the filter was heavily clogged (it is supposed to be self cleaning), and i also found glass shards from a broken wine glass. i further disassembled the plastic housing under the filter ( held in place by three torx drive screws ) which covers the pump impeller and holds the lower spray arm. while i did not find any blockage in the pump area, and no abnormal sound when i turned the impeller by hand, i did find that one of the pump impeller vanes has a small chip which probably makes the impeller unbalanced resulting in more than normal vibration. i cleaned the water filter and reassembled the parts and the original screeching noise is now gone.
Sep 03, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Screeching Noise From Fisher & Paykel GWL115 Washer While Filling
if its while filling may be water pressure try turning tap down (hot)
Apr 04, 2008 | Washing Machines
Polaris Pb4 - 60 Booster Pump Logo
516 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
