Question about Cell Phones
The side buttons,option button,call button some time does not works.... i keep pressing the button but it do not works... what's the problem
  • 358 Answers
Hi, there is a switch inside the phone that controls the side button. You will need to unscrew the phone to see if the button has not pulled out, cause it's a little bit fragile and can pull out easily from the board of the phone.
When you unscrew, if it has pull out, and the press button is still intact, you can use a soldering iron and a lead to put it back, but if it is damaged, that means you will need to get another press button and fix it back soldering it back to the board of the phone.
If no knowledge about how to fix it,please do calla skill personnel for assistance. thank you.
Have a nice day.
Posted on Sep 13, 2010
My computer keeps shutting down irreglarly
Hey Henry,
Try reseting your PRAM and SMC.
Here's how to reset your PRAM:
  1. Shut down your machine. Yes, all the way down, not sleep or logging out.
  2. Press the power button and then press command-option-p-r. You have to make sure you get those keys pressed before the gray screen comes up or it won't work.
  3. Hold those keys down until your Mac reboots again and you here the startup chime.
  4. Let go of the keys and let your Mac reboot normally.
For SMC:
  1. Turn off your machine
  2. Keep the MagSafe adapter plugged in.
  3. Press at the same time shift-option-control (on the left side of the machine) and the power button
  4. Let go
  5. Turn your machine back on with the power button.
Nov 16, 2013 | Apple MacBook Pro Laptop Computer with...
My Brother printer will not find an IP on the router. I've tried multiple ports, but all I ever get is zeroes, no IP, but the router works fine, I'm connected to it right now. Everything else thats...
The best way to have this printer work is to connect it with an lan cable. Here are some steps to check if the printer will work again.
Disconnect the lan cable from both ends. Make sure that the printer shows the blue solid light, Try to do the factory and network card reset. First turn off the printer by pressing he switch button on the right side. Press and hold the GO button while turning it on, then press go button 8 times as fast as you can without delay. Once you see the blue light solid again turn off the printer and do the network card reset. Turn off the printer by pressing the switch button on the right side. Press and hold the GO button while turning it on, then press go button 7 times as fast as you can without delay. After 1 minute reconnect the lan cable from the router to the printer. Wait 1 minute again the press the GO button 3 times without delay, it should printer the printer setting page that shows the correct IP address.
Hope this will help.
Feb 27, 2011 | Brother HL-2170W Laser Printer
How do you get the time from military to normal? and how do yo set the date and time?
  1. Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  2. Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  3. Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  4. Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  5. Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
Sep 19, 2010 | Watches
How do I get my WR 100 ft model # AW60724W off army time.
Aug 31, 2010 | Watches
Trying to convert to military time
Best regards. Jewel
Aug 30, 2010 | Watches
How to change from military time back to regular time on a digital indigo watch with 4 adjustment buttons?
Thank you for contacting FixYa.<br /> <ol id="ecxintelliTxt"> <li id="ecxjsArticleStep1"> Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.<br /></li> <li id="ecxjsArticleStep2"> Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.<br /></li> <li id="ecxjsArticleStep3"> Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.<br /></li> <li id="ecxjsArticleStep4"> Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.<br /></li> <li id="ecxjsArticleStep5"> Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.<br /></li></ol> Contact TIMEX for further assistance at:<br /> http://www.timex.com/info/Product_Instruction_Guides_Downloads
Aug 25, 2010 | Timex 1440 Nylon watch
I have a Nexxtech Watch that is both digital and hand driven. I have somehow switched the regular time to a 24 hour clock and don't know how to switch it back. The manual says nothing about it. Any help...
These basic instructions are for most digital watches (and these are for regular to military but you can just follow same instructions to get to oposite) Hope this helps!
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 21, 2010 | Watches
How do you change the time on the gucci 237944
I assume that you do not have any instructions, so the first thought is that you should be able to get some from your nearest Gucci dealer, or at least get them to explain how to do it.
If this is not practical, then try the following :-
(From the web site I couldn't see both sides of the watch but I am working on the assumption that there are two buttons on each side).
One of the buttons will be a "mode" button, which changes the watch into various setting modes (try the lower left(?) when you press the mode button the display should change e.g. the hours flashes; to change the time try the buttons on the right side.
Keep pressing the mode button to reach the location setting function. I expect that you will be able to scroll through a number of options (again, using the right side buttons).
When you have finished setting up, keep pressing the mode button until the normal display is reached.
Some experimenting may be required, have patience and good luck!
Mar 06, 2010 | Bulova Watch
How dp you alter the time of the hands
  1. Press the Bottom Left side button until you reach time keeping mode.
  2. Press the Bottom Left side button 6 times to reach hand setting mode.
  3. Hold down the Top Left side button until the digital time starts to flash.
  4. Press the Bottom Right side button to advance the analog time by 20 seconds; Holding the button down will advance the time faster. Pressing both of the Right side buttons will lock the time into advancing quickly without holding buttons down; this will continue until you press a button or the clock advances 12 hours.
  5. Press the Top Left side button to exit the settings screen.
  6. Press the Bottom Left side button to return to timekeeping mode.
Mar 12, 2009 | Casio Watches
TURN OFF PROGRESSINE SCAN ON ZENITH XBV443
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 16, 2005 | Zenith XBV443 DVD Player/VCR
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
