Question about Lexmark Office Equipment & Supplies
Have just changed ink cartridge for first time. will not print now everything on ok
  • 2,785 Answers
Have you carry out allingment test
Posted on May 15, 2008
Won't Print Color Ink
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
I have a 4 month old epson sx215 printer... everything was working fine two days ago and today i went to print some very important documents and my black ink wont work... the inks are all full, I have done...
you have two option, can do nozzle check and head clean , many time can repeat, there is any improvement you can continue the same will work
2.change print head(better go for new printer,you should understand one thing, Epson print head along with printer so, you have to take printout at least every day one copy,if you are using HP inkjet printer,this kind of problem you can solve every easily, just change cartridge only,because hp cartridge along with print head not with printer.
Sep 25, 2017 | Epson Office Equipment & Supplies
How do i change ink?
If iam not wrong you want to replace the Ink Cartridge. Please follow the below mentioned instruction.
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Oct 08, 2009 | HP Officejet 5510 All-In-One Thermal...
I have changed all the ink cartridges on my Brother MFC5440CN it
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Jun 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
Pixma MP830 is printing things green that should be red
when you change all new cartridges (make sure all cartridge ok, and the cartridge pins connection ok) still red color lost, it is the trouble at print head ink chanel some of that is too dry for longer time less using , most CANON printer head is separated from the ink cartridge, two way you may try:
1) take out the ink cartridge, drop down a little the special cleaner (best clean tools buy from dealer), to the head ink chanel hole, then set back the ink cartridge and waiting minutes
2) try put the print head bottom surface touch a little cleaner or water 1-2 hrs, if you can take out the print head unit. still not fixed for some case that should change the print head unit.
Feb 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
Hp office jet 7210 all-in-one printer
Hi , this is definitely a print head issue of the printer. You can just try one more thing - press set up on the printer - go to print reports - press ok / enter - go to self test report - press ok / enter
If the report comes entirely in red the printer needs servicing from the local service centre.Ithappens only if the nozzles of the cartridges are blocked and they do not let the ink pass out how many ever times you replace the cartridges.
Mar 26, 2008 | HP Officejet 7210 All-In-One InkJet...
No text
Check that your black ink cartridge has ink inside, eventually try a new cartridge , as ink may have dried up in old cartridge.
If you use a new cartridge ensure you removed cellotape from cartrige.
If cartridge is ok, then it is printer nozzle/head for black ink.
In this case do nozzle check / head cleaning in printer tools a couple of times.
If problem persist you may need to check and clean printer's head with cotton and solvent.
Mar 20, 2008 | Computers & Internet
Printer problem with 6210 all in one.
Try to print a self test page from the printer itself, do these:
  1. Press and hold the Cancel and the Color buttons at the same time.
  2. Release both buttons.
  3. The Self Test Report will be printed.
and check if it is the same output, if yes then follow the steps below:
  1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below:
  2. Verify that there is plain white paper in the Input tray.
  3. Press Setup .
  4. Press c00712200.gif or c00712201.gif to select Tools and then press OK .
  5. Press c00712200.gif or c00712201.gif to select Clean Print Cartridge and then press OK . The unit prints a test page.
  6. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  1. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  2. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
  3. Open HP Solution Center .
  4. Click Settings .
  5. Click Print Settings .
  6. Click Printer Toolbox .
  7. Click the Estimated Ink Levels tab
  • Replace any ink cartridge that is low on ink.
  • If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    1. Open the front of the unit to access the ink cartridges.
    2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them.
  • With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
  • Allow the cartridges to dry before reinserting them.
  • Close the unit, and plug the power cord back in.
  • Print a self-test page to check the results. Follow the steps below to print a self-test page.
    1. Press Setup .
    2. Press c00712200.gif or c00712201.gif until Print Report displays and then press OK .
    3. Press c00712200.gif or c00712201.gif until Self-Test Report displays and then press OK . The self-test report prints.
    If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s).
    Dec 19, 2007 | HP OfficeJet 6210 All-In-One InkJet...
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
