Question about Siemens WFXD8400UC Front Load Washer
I have siemens S-16-38. It stops in the middle of the wash and shows error F18.could not open the door as well. what should i do?
4 Suggested Answers
  • 6277 Answers
SOURCE: Front door not opening, Washing
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 03, 2011
SOURCE: Siemens s14-38 washing machine has
We have the same problem. How did you sort it?
Posted on May 09, 2011
  • 6277 Answers
SOURCE: F18 error message siemens washing
For most models- you do not say which yours is- Bosch's 'F18' states 'drainage (filter) problem.
I advise you read through these guidance notes and check the filter AND the operation of the drain pump itself- it could be jammed.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
John C
Posted on Sep 12, 2011
My whirlpool high energy washing machine style master #907675 just stopped working in the middle of the wash cycle. What can I do to get it to start working again?
not a good model # check on face of opening inside door frame.
door lock switch maybe your problem depending on model#
washer should show error code on electronic display by lights flashing or led read out if not lighting up can be control board check your home power first
Jul 03, 2016 | Whirlpool Washing Machines
Siemens front load washing machine. Cloth stuck between the door and the panel. Can't open the door. F23 appears.
the tub beneath the washer is full and is not draining. the clothes have probably opened up the seal between the door and washer allowing water to leak. tip the machine and empty the sump to clear error.
Jun 09, 2016 | Siemens Washing Machines
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
My Siemens Extraclasse 1300 Washer/dryer just stopped as though no power. Fuse is ok.
check door inter lock by putting mech on leave 4 five mins go and try to open door imeditlaty if if opens straight away its the inter lock
Feb 22, 2015 | Siemens Washing Machines
F18 error code on Bosch Exxcel washer/dryer, and water pouring out the bottom - any ideas on how to fix? Filter is clean.
Sump hose has fallen off Unplug tilt machine back have a look underside to check also could be the soap dispenser hose Hole in it.This rubs away on side of machine 5yrs old.
Sep 13, 2017 | Bosch Logixx WFT 2806 Front Load...
This might help you with the pump its on a bosch Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2013 | Bosch Logixx WFT 2806 Front Load...
While washing program stops showing f18 flashing
f 18 means your unit has a drain issue If the washer doesn't drain properly within a specific amount of time, you'll get the F18 error. A common fix is to remove the panel covering your drain and examine it for any sort of debris that may be obstructing it if this doesnt not alleviate the issue then you would have to check the entire drain line itself. if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks Rick
Apr 24, 2011 | Bosch Washing Machines
Error Code F11
TRY UNPLUGING IT FOR A MIN OR TWO. I THINK F11 IS A CONTROL MODULE. CALL A TECH
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Siemens WFXD8400UC Front Load Washer Logo
434 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
