Question about Onkyo TX-SV373 Receiver
Hi, I have a TX-8511 Onkyo. The left channel is silent. It's not the speakers or the wiring - checked and swapped. Using 8 ohm speakers and switch is set to 8 ohms. Does the same thing on both A & B - no left channel. Any ideas? Thanks, Bill
  • 1,525 Answers
Hello 1 of the transistor could be dry jointed if joint ok then you may a leak on the transistor also check the capacitor around the transistor for bulging all the best
regards
shaun
Posted on Sep 13, 2010
ONKYO tx-sr605 HDMI CHANNEL 2 INTERMITTENTLY SWITCHES TO STANDBY
Check the Ohm value (4, 8, 16...) on the speaker and on the ONKYO too.
If not the same that is the (big) problem!
Nov 24, 2007 | Onkyo TX-SR604 Receiver
ONKYO TX-DS484: \r\nI am not getting any sound out of my left speaker on stereo. I cannot find a balance adjustment. I do not have the remote control. Thanks
It sounds like you also need the manual.
http://www.retrevo.com/support/Onkyo-TX-DS484-Receivers-manual/id/365dj182/t/2/
The remote is an RC-4278. You WILL need it.
$25.10 on eBay expiring tonight so jump on it. 3h 35m 40s (Sep 06, 201120:16:46 PDT)
http://www.ebay.com/itm/ONKYO-RECEIVER-REMOTE-CONTROL-RC-385S-RC-373M-RC-371M-/290597112430?pt=LH_DefaultDomain_0&hash=item43a8f00a6e
As far as the left speaker goes, swap it to decide if it's the speaker, wire or the amp channel. There are no control settings that would make one of the front pair go silent.
Sep 06, 2011 | Onkyo TX-DS484 Receiver
My speaker "B" channel has gone out. Is this an
Maybe I'm misunderstanding the problem...
One speaker? Why would you have one speaker attached to A or B? A and B represent speaker pairs and are driven by the same two amps.
It's also not clear if you're saying the speaker is failing or the channel. You CAN swap them to find out.
Either way, the amps are common to both speaker pair connections so if only the B pair isn't working at worst you have a switch problem.
Jul 01, 2011 | Onkyo TX-8511 Receiver
I must have hit some buttons on the remote unintentionally - all of a sudden I lost the sound out of the left speakers on my Onkyo TX-8511
Reverse left and right speakers at back of unit
to verify if a speaker/wire problem. Also check
all functions for same problem!
Jan 30, 2010 | Onkyo TX-8511 Receiver
How many watts does a r-30 put out to each of the 2 speakers at what ohms?
2 ohms is a heavy load should run into 4 ohms but what ever the ohm age 30watts into 8 ohms is 30 watts assuming this is rms 30 into 4 will give 60 rms do not recommend going any lower almost a dead short will damage amp
Nov 06, 2009 | Onkyo TX-8511 Receiver
Onkyo tx8511. Receiver working fine, power went out
Is channel B switch turned on? If so turn it off .
Feb 27, 2009 | Onkyo TX-8511 Receiver
Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Jan 28, 2009 | Onkyo TX-8511 Receiver
Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
Jan 09, 2008 | Onkyo TX-SR500 Receiver
Onkyo TX-SV373 Receiver Logo
163 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
