Question about Kodak EKTAGRAPHIC III A Slide Projector
Projector will not hold the slides down when advance button is pressed.
    President:
  • Kodak Master
  • 412 Answers
By your description, it sounds like a continuous cycle problem. It could be an adjustment, or possibly need to have a part in the slide change mechanism replaced. Either way, these both are problems best left to people trained to affect such repairs. Contact a qualified service dealer.
Posted on Nov 03, 2010
L can't get the tray into the 570 slide projector.
Press down the advance button and spin the tray until it seats.
Oct 17, 2016 | Office Equipment & Supplies
Change a carosul for 35 mm slide projector
Hi Richard, Turn the projector on, press & hold down the "Select" button. While holding the "Select" button down, rotate the slide tray to the "Zero" position. You will then be able to lift the tray from the projector. Good Luck!! Jim
Sep 23, 2014 | Office Equipment & Supplies
Kodak carousel 760h projector
Dirt or dust accumulation can retard the gear mechanism. If you get Canned Air at WalMart, blow out all open areas and see if you can dislodge the material collected inside.
Mar 25, 2014 | Office Equipment & Supplies
Can I advance my slide tray manually?
A Kodak Carousel 600 has no Forward/Reverse buttons for tray movement. The only way to advance the tray with the slide change mechanism is by LIGHTLY depressing the SELECT bar. To manually advance the tray, push and hold the SELECT bar down fully.While holding the SELECT bar, you should be able to rotate the tray by hand. Good Luck!! Jim
Aug 08, 2013 | Kodak Carousel 600 Slide Projector
Kodak 600 projector has not advance button
You're correct!! The Kodak Carousel 600 does not have an ADVANCE button. To advance the tray you LIGHTLY depress the SELECT bar on the edge of the projector. There is no reverse capability, other than holding the SELECT bar down fully and rotating the tray by hand. Enjoy your projector!! Jim
Mar 09, 2013 | Kodak Carousel 600 Slide Projector
Slides won't advance or reverse
The AF-2 is suffering from old age! The problem you are experiencing is "continuous cycle", and is caused by the cycle contact either being bent or worn to the point it can't stop the cycle camstack at the end of a slide change. If you are familiar with projector repair, I can give you specific instructions. Otherwise, I suggest you locate an authorized repair dealer. Even though the projector is old, all the necessary parts are available from: www.micro-tools.com
Good Luck !! Jim
Dec 15, 2011 | Kodak Office Equipment & Supplies
The reverse forward feature doesn't work
To advance the slides forward just tap the advance button. To revers it hold the advance button down. If that doesn't do it it will need service.
Nov 12, 2010 | Braun Novamat 330 Slide Projector
2 days ago my Kodak Carousel 760H projector started going backward or forward at will, inspite of which button was pushed. Now it will not go forward or backward with either the handheld or the side...
This is not an easy repair. It would probably be more cost-effective (if you will NEVER use the projector again) to rent one for the remainder of your project.
The problem you are describing is most likely a broken "link". The "link" connects the cycle solenoid to the slide change mechanism. Over time, this plastic "link" gets hard & brittle, and cracks, giving the failure you describe. It is a significant tear-down of the projector by a trained technician.
Nov 06, 2010 | Kodak Office Equipment & Supplies
MODEL 760h WILL NO LONGER ADVANCE SLIDES
The KODAK Carousel 760H was manufactured approximately between 1971 & 1981.
The problem you are describing is most likely a broken cycle solenoid "link". This "link" connects the cycle solenoid and the slide change mechanism. Repair parts are still available, but this is a repair best left to a factory-trained technician. Contact an Authorized Repair Dealer.
Jul 25, 2010 | Kodak Carousel 4400 Slide Projector
We have a Kodak Carousel 650A projector. (140 slide carousel) Cannot advance the slides using the remote or the select bar. Putting in the individual slides with the carousel off the select bar will eject...
The purpose of the "SELECT BAR" on a Carousel 650H is to eject the slide. If you press & hold the select bar it allows you to rotate the tray to the slide you want (or Zero & remove the tray). If you can not advance or reverse the slide tray using either the remote buttons or the buttons on the side of the projector, then chances are you have a broken part in the slide change mechanism. The possibilities are numerous, and really requires a trained tech to analyze your specific failure. Sorry the news isn't better (or simpler!).
Jun 20, 2010 | Office Equipment & Supplies
Kodak EKTAGRAPHIC III A Slide Projector Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
