Question about Sharp AQUOS 52" Flat-Panel LCD HDTV
Hello i`ve got sharp lc46le700e, but it`s change to Dynamic fixed by itself on 30-40 minutes. I read the same problem on other people, but i didn`t see how to change from Store mode to Home mode. I didn`t see also da EZ setup... ?
In user mene go to SETUP then make it RESET tv will OFF and ON atomatically then go to SETUP again the to AUTO INSTALLATION and in than u can change setting to HOME from STORE..thanks
Posted on Sep 16, 2010
  • Mat Doctor
    Mat Doctor Jan 23, 2011
    i had same problem, i brought it to Duke Electronics, They fixed it in one day, Check there website for address infomation www.dukeelectronic.com
Can any1 help. When i connect my sky+ via scart lead 2 my lc-46le700e all i can get is sound and no picture, i tried 2 connect my dvd player via scart and it done the same, How do i get the picture up awell, Help woult be apriciated
Posted on May 30, 2011
Time synchronization not working
In thinking about this, we need to first consider what is different about those systems which gain 3 minutes from those which do not. It is obvious to me that since the auto-sync is the problem and the manual sync works, it is not that the system isn't automatically syncing to the right server, but not really syncing at all....so therefore their must be something wrong with the auto-sync.
Given that I would suggest you read http://www.thewindowsclub.com/windows-time-service-not-working-synchronization-fails-error
which, while not specifically addressing your problem gives you several palaces to look and compare the working versus non-working systems.
Jul 24, 2013 | Microsoft XP Computers & Internet
What is opc light on my sharp aquos tv
This can be called Optical picture control and it adjust to suit the room light.
Please read the text below"
Dynamic Backlight Control - One of the nice features of the Sharp AQUOS LC-32D6U is what Sharp calls OPC, a name they use for their dynamic backlight control. You might also see this feature referred to as a dynamic iris on other LCD HDTVs or disguised under some proprietary name, but fundamentally the principle is the same. Its primary function is to try and maintain a high Full On/Off contrast measures the ratio of the light output of an all white image (full on) and the light output of an all black (full off) image. 2) ANSI contrast is measured with a pattern of 16 alternating black and white rectangles. The average light output from the white rectangles is divided by the average light output of the black rectangles to determine the ANSI contrast ratio. When comparing the contrast ratio of video devices make sure you are comparing the same type of contrast. Full On/Off contrast will always be a larger number than ANSI contrast for the same video device.">contrast ratio under any lighting condition. So when room lights come on or off or the sun enters the room, with OPC enabled, the backlight in the LCD will dim or brighten depending on the amount of light in the room. This is managed by a light sensor located on the front of the unit. When OPC is enabled there can be a slight reduction in the dynamic range of the display as the display attempts to maintain contrast and color saturation as room light changes. We had a chance to compare this feature with another LCD HDTV that was of comparable size but without dynamic backlight control, and the Sharp AQUOS LC-32D6U with OPC enabled was the clear preference.
Jan 24, 2011 | Sharp Televison & Video
I used to be able to change picture mode (dynamic fixed) (standard) etc.. but now stuck on standard. I have lost the picture mode option and can't get it back to the brighter richer (dynamic fixed mode). ...
Go in the tv menu,right at bat u in the Picture mode go down the menu to reset push it.The Tuner board will reset it self.It will be set on the Dynantic fixed mode.And the AV mode button on the remote should able to changes back and fourth again Dynamic fix mode,Dynamic mode,Standard mode,User mode,Game mode.Not able to changes by pushing the remote button AV mode to changes,than ur Tuner board have problems,not working properly.
Jun 09, 2010 | Sharp AQUOS LC-52XS1U-S LCD TV
Sharp Aquos 46in LCD AV Mode switching to Dynamic(fixed) by itsel
Sorry I´cant help you, but I´ve got exact the same problem.
I´m from germany. I searched the german web, but nothing.
Did you have an answer right now?
Apr 03, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
When were these tvs produced lc46le700
Hi cyoung
To answer your question;
The official release date is june 1/2009.
And sometimes at the back of the tv you might find the actual month that the set was manufactured.
Jan 23, 2010 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
About text sharpness
The monitor shouldn't be changing the settings itself unless you changed it. Try changing the brightness and contrast. Otherwise, it might be a video card issue.
Nov 30, 2009 | Samsung SyncMaster 551 15" CRT Monitor
Sharp Aquos LC46lE700UN How do I adjust the audio. Manual says that the Output Select to Fixed, but it still does not allow me to adjust the audio
If the RCA audio out put is set to 'FIXED' it means the signal at the RCA jacks will not be controlled by the Volume control of the TV, but the TV speakers will still be controlled by the TV volume control, if you want to make the RCA AUDIO out to be adjustable by the TV volume control, you will have to set it to 'VARIABLE'.
Nov 03, 2009 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
SNOWY screen--can't find the right channel for Dish Network
Press INPUT button on your TV remote and select right input.
Nov 02, 2009 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
Sharp AQUOS 52" Flat-Panel LCD HDTV Logo
273 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
