Question about Kenmore Dryers
80 Series dryer not turning/tumbling. Has heat. The belt around the drum appears tight.
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be the belt could have slipped off of the motor pulley, or idler arm pulley or faulty motor.
If you have to check/replace/repair your drum,motor or belt and if you have a front loading machine:
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Posted on Sep 13, 2010
  • 5zBravo Sep 14, 2010
    Thank you for sharing your expertise... appreciated by one who understands why tradesmen (gender not implied) prefer to hold skill/craft secrets close the the vest. It won't get you to heaven, but those of us elsewhere sincerely appreciate your help. Thx again.
I have Kenmore 80 series dryer. The drum is not tumbling, but the belt is fine. It heats up and the vent still blows. Help!
Does it sound like the motor is starting? If the belt is good, but the drum won't spin, it sounds like the motor is gone or the drum has seized.
Feb 20, 2015 | Kenmore Dryers
Kenmore 80 series dryer does not tumble
check the belt underneath the dryer or if it is gear driv be sure it is free of any debree...
Oct 09, 2012 | Kenmore Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Does a Kenmore Series 80 have a drum belt . The dryer does not spin. Can't find the drum belt
Yes, it has a drum belt. If you can't see the belt wrapped around the exterior of the drum, more than likely it has broken and is wrapped around the drive motor shaft, or lying on the interior cabinet bottom. If the dryer still heats, but the drum does not turn, this is probably why. Please post back with your model number (located on a nameplate around the door opening) and I can tell you how to access it and/or replace it.
Dec 29, 2009 | Dryers
I have a kenmore 80 series dryer that heats up and will not tumble. The model # is 66822692. Can you please help?
Open the back panel to access the belt. There is a motor to make the drum tumble by the belt. If the belt is not intact then motor turns but not the drum. If the belt is in good place then motor is not working. Check out the continuity of the motor, if there is then there is a problem with the circuitry. If there is not continuity from the motor terminals then the motor is burnt.
Dec 28, 2009 | Dryers
I have a kenmore 80 series electric dryer. It gets
If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks for choosing fixya...Regards, Joe
Nov 13, 2009 | Cars & Trucks
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Dryer wont turn
Yes, it will save you alot of money and work just fine. You will have to shut off the dryer, turn off the gas and/or electric(disconnect it to be sure it is power free). Look at dryer carefully as you may be able to access the belt from the lower front. The belt is easily available at Sears Parts Stores. Do not use it until fixed as it might overheat!
Dec 09, 2008 | Kenmore 63942 Dryer
Tumble dryer
pull the front off then put the belt around the drum then pull the idler pulley back to put tension on it and put the belt around the motor pulley let the idler pulley back against the belt to keep it tight replace the front and your done
Mar 12, 2008 | Dryers
Dryers Logo
120 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
